Help with a DELTA DAC-19M005 PS Board
  • wc101
    • Feb 2011
    I have a Delta power board that has crappy CapXon capacitors. One of them has the white crud on it to keep it in place and the value is not legable. It is the chunkyer of the three different sizes. just above and to the left of CE109 and below CE102. Also the cap i need has P722 written on the side. Probably some kind of part number.
    If it helps, the other caps i have identified as 220/25 and 1000/25
    Thanks.
  • alexanna
    • Mar 2010
    • 1346
    Re: Help with a DELTA DAC-19M005 PS Board
    10v 2200UF is the capacitor your looking for, Looks to be 12.5mmx20mm
    If you search the number of your power supply here in the forum there is a lot of information available.
    This power supply is also used in Westinghouse 20.1”and 22”w and some Acer models.
    There a lot of common problems discussed, some may be helpful to you.
    • wc101
      • Feb 2011
      Thanks.
      That's it. Works fine now. I replaced it with a slightly larger case sized nichicon 2200/16 The only problem down the road is it is now pressing up against a voltage regulator so it may overheat.
      -Bill
