1800FP Green light on but no image on screen
  • snorlin
    • Jan 2011
    • 13
    Re: 1800FP Green light on but no image on screen
    Hello... any updates on the 1800FP? I just got one in with the same problems. Steady green light, good 12v and 5v, nothing else.
    • Welchs101
      • Sep 2008
      • 979
      no update..........other than i plan to send the board into someone for repair. I think its the eeprom andi cant change this.
      i will send an update once i finally send board in and get it back.
      • jetadm123
        • 2169
        #43
        If it is the eeprom, you can purchase a preprogrammed one. Refer to link below and read post #18:
        https://www.badcaps.net/forum/showthread.php?p=76140
        You'll have to use something like ChipQuik to remove the old eeprom.
        • snorlin
          • Jan 2011
          • 13
          Success!... I did some ESR readings of all the surface mount caps on the board, and found C817 a 100u 16v cap with 2-3 times higher value than the rest. I swapped it with a radial, and it worked! C817 is next to the two other radials on the board. Hope that helps.
          • 3D Modelka
            AOC 27 monitor Q27G2WG4 doesn't display logo or image on screen
            by 3D Modelka
            Hello. I have a problem with my AOC 27 monitor, specifically model Q27G2WG4, which I have been using for 3 years. The monitor stopped turning on: when I turn it on, the backlight turns on, the indicator starts glowing white, but the logo on the screen does not appear, and there is no image. However, if I check in the Windows system, the monitor is displayed as connected and working. I tried connecting it via HDMI and DP, but the result remains the same. If I turn the monitor on and off multiple times, it will eventually start and work. However, when the monitor is working, there are no issues....
            02-09-2024, 02:42 AM
          • matthewmcconaughey
            I need help with my friend Sony GDM-FW900 24” CRT
            by matthewmcconaughey
            Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
            I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
            1. It started with a bright and greenish picture upon starting a cold monitor.
            2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
            05-16-2023, 03:15 PM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • MOSSEP
            Monitor Audio RSW12 - Green light but no audio
            by MOSSEP
            Hi
            Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
            Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
            The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
            I have already tried replacing all of the...
            01-26-2025, 08:18 AM
          • String2016
            samsung np300e green screen
            by String2016
            I need help on this samung np300e laptop, laptop turns on but the display green screen samsung logo and no bootable device shows but all green, I have replaced good lvds cable and good screen still problem persist.anyone encounter this problem please help
            07-26-2025, 04:00 AM
