1800FP Green light on but no image on screen
  • jetadm123
    replied
    Re: 1800FP Green light on but no image on screen
    Originally posted by Welchs101
    do you think i need to replace those two or could i just solder two in parallel with those two 10uf caps, C739 and C207?
    Replace. Putting another cap in parallel will only increase the capacitance.
  • Welchs101
    replied
  • jetadm123
    replied
    Another update.
    I took the logic board out of the "bad" monitor and put it into my working monitor. No surprise, my working monitor with the "bad" logic board in it did not work.
    So its definite.....the logic board is the problem.
    Now, i need to figure out if its worth fixing.........any ideas?
    You can try the fix the severach used on the link below, post #12:
    https://www.badcaps.net/forum/showth...0fp+logic+card
    It involves replacing two 10uf caps, C739 and C207. You can use regular electrolytic caps as replacements.
    Eventhough your logic card is an earlier model, it might be worth a try. Just be careful when you unsolder the original surface mount caps off the board. There are two tabs, one on each side of the cap. Heat each tab and lift gently. You may have to use a rocking motion, but gently as you dont want to lift the solder pads off the board.
  • Welchs101
    replied
    Another update.
  • Welchs101
    replied
    i have a few updates this morning.
    I swapped parts between the good-working 1800FP and the non-working 1800FP.
    1) I put the power supply board from the non-working monitor into the working monitor. The logic board and the inverter board were not replaced. And the monitor came on!
    2) I put the inverter board from the non-working monitor into the working monitor. The power supply and logic board were not replaced.........and the monitor came on!
    So based on these results i would say the problem is on the logic board.
    Now the question is ........is this something i can fix or not.
    Any thoughts on how to proceed?
  • Welchs101
    replied
    steve,
    i remeasured the 5V pins on the power supply connector. the measurements i previously gave you were with the power supply disconnected from the logic board.
    with the power supply board connected to logic board and logic board connected to inverter board the 5V pins on the power supply board measured between 4.98 and 5.04V.
  • Welchs101
    replied
    steve,
    i measured the voltages coming out of the power supply board.....for the 5V pins i measured 5.11v and 5.11V.
    Regarding your comment about 5V on pin 8 of J702..........i am still trying to digest the manual and find where you say it should be 5V. I sure you're correct......just dont see it yet.
    If its the inverter board..........what do you think it might be. I have looked at the schematic but not sure i can find the inverter board.
    thanks.
  • steve2
    replied
    Are the readings on the powerboard output correct? Last page of the manual, far right. With evrything hooked up, do you have a 5vdc signal. I know you had iton pin 8 of j702 with the inverter board disconnected. The power supply board 5vdc supply may be too weak to power the inverter. IC901 is a common failure on this monitor ($6 part).
  • steve2
    replied
    Looking at your (S) test point should be your 5 vdc on pin 8 of J702 (page 33, connectors , far right on manual). Since you have the 5 vdc with the inverter plug off, then I would start at the inverter board.
  • alexanna
    replied
    Sorry my mistake the connector I asked about a, b, c, d is the connector you labeled L through S. So that is to the inverter.
    wow the service manual should help
  • steve2
    replied
    Heres the service manual with everything you need. https://cdn.badcaps-static.com/pdfs/...ee6fb5150e.pdf
  • Welchs101
    replied
    The measurements i posted already are with the monitor powered on and off.
    For powered off => NOcontroller.....ie....controller from front of monitor not connected......this means the monitor is powered off
    For powered on => Yescontroller
    For inverter board connected => YesInverter
    For inverter board not connected => NoInverter
    I am also enclosing a pic of the logic board
    is this all the info you need?
  • alexanna
    replied
    Could you provide a photo of all the boards somewhat together straight down with no flash, we really need to get some idea what all the connectors are.
    The connector you have labeled a, b, c, d ECT. What does it connect to?
    Use your test inverter or another monitor to turn at least on back light in the bad monitor to make sure no image is visible; some can be very difficult to see.
    On some monitors they identify what some of the pins are on the connector from the logic board to the inverter/power supply. An example would be
    #1 5volts
    #2 5 volts
    #3 ground
    #4 ground
    # 5 backlight on
    #6 Dim
    #7 12 volts.
    These are just examples I made up, and I realize your boards do not identify the voltages.
    On the working monitor it may be helpful to know what these voltages are, you are going to have to take two readings one with the monitor off and another as you power the monitor on.
    It also might be a good idea to adjust the brightness up and down to try to identify the dim pin on the connector. You could identify the backlight on signal by watching the voltage change on one of the pins as the monitor goes into a sleep mode. This may give an idea to what's happening.
  • Welchs101
    replied
    Anyone have any thoughts?
    I was thinking that based on the results that its the logic board that has the problem..........just not sure where............anyone have any thoughts?
  • Welchs101
    replied
    i decided to post the measurements i made. I hope they reveal something to someone.
    Note: I made measurements on the good and bad board.
    Note: I made 3 sets of measurments on the good board.
    Note: I made 3 sets of measurments on the bad board.
    Note: one set of measurements were with the inverter diconnected (NoInverter) and the controller board not connected (NoController). I am calling the controller board the one with the on/off switch on the bront of the monitor.
    Note: One set of measurements with controller connected (YesController) and inverter not connected (NoINverter)
    Note: One set of measuremetns with inverter connected and controller connected (YesInverter and YesController)
    See enclosed files. All measurements are in volts.
    Note: I placed black lead on one of the "screws" in the board and the red lead from the multimeter on the "+" of the caps.........or the red lead on specified pins in the figure.
    If you have any questions please let me know.
  • Welchs101
    replied
    bill,
    i looked on front and back of both the logic and inverter boards (see enclosed pics).
    Just wanted to recap what i have done.
    Recall, that i have a "good" and "bad" monitor. I disconnected the inverter board from "both" the good and bad monitor. Why: Because if the inverter is indeed whats causing the bad monitor to be bad then if i disconnect it then i should see similar voltages on both boards at various sites on the logic board (well this was my assumption anyway..........is it a good one?).
    What i found was that the voltages between the good and bad matched up fairly well except at two points.......granted i did not look at every possible voltage node.......but i did look at all the caps and few of the regulators. The two points where the voltage did not match up are pin7 of the connector between the logic board/inverter board and the "+" side of the cap (10uF/16V......in the pic u will see i soldered a known good cap in parallel....this cap was added after my voltage measurements were made). What i found was pin7 and this "+" side of cap were at the same node. On the good monitor the voltage reading was ~ 0.034V and on the bad monitor its ~ 3.1V.
    SO based on this i made the assumption that the inverter board was not the problem but the problem was somewhere on the logic board........is this a good assumption?
    Does this help? Or confuse the issue? let me know and i can make more measurements and put results in a table if you like.
  • PlainBill
    replied
    hi Bill,
    Not sure what you mean. This node does go to the connector as i showed inthe picture. Is this what you mean?
    We have to think system. What is connected to that connector? Yes, I know, a cable. Presumably it goes to the inverter. Is there any information on the inverter that would give us a clue as to what the signal is?
    PlainBill
  • Welchs101
    replied
    hi Bill,
  • PlainBill
    replied
    I addeda a 10uf/50V radial cap to the logic board. I did NOT remove the old one i just soldered the new 10uF cap in parallel to the suspect one.
    I turned on the monitor and nothing happens no image displayed on screen.
    WHen i connect ALL the connectors i read the following: Voltage at that node varies from ~ 3.1V to ~ 5V. Recall on the "good" monitor it did not vary at all and the value was ~ 0.034V.
    Is that node identified at the inverter?
    PlainBill
  • Welchs101
    replied
  • 3D Modelka
    AOC 27 monitor Q27G2WG4 doesn't display logo or image on screen
    by 3D Modelka
    Hello. I have a problem with my AOC 27 monitor, specifically model Q27G2WG4, which I have been using for 3 years. The monitor stopped turning on: when I turn it on, the backlight turns on, the indicator starts glowing white, but the logo on the screen does not appear, and there is no image. However, if I check in the Windows system, the monitor is displayed as connected and working. I tried connecting it via HDMI and DP, but the result remains the same. If I turn the monitor on and off multiple times, it will eventually start and work. However, when the monitor is working, there are no issues....
    02-09-2024, 02:42 AM
  • matthewmcconaughey
    I need help with my friend Sony GDM-FW900 24” CRT
    by matthewmcconaughey
    Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
    I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
    1. It started with a bright and greenish picture upon starting a cold monitor.
    2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
    05-16-2023, 03:15 PM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • MOSSEP
    Monitor Audio RSW12 - Green light but no audio
    by MOSSEP
    Hi
    Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
    Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
    The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
    I have already tried replacing all of the...
    01-26-2025, 08:18 AM
  • String2016
    samsung np300e green screen
    by String2016
    I need help on this samung np300e laptop, laptop turns on but the display green screen samsung logo and no bootable device shows but all green, I have replaced good lvds cable and good screen still problem persist.anyone encounter this problem please help
    07-26-2025, 04:00 AM
