Belinea 102035W Help
  • Rtech
    • Jul 2010
    • 1095
    Re: Belinea 102035W Help
    Well done,and the cost was ......'Not a Lot' as Paul Daniels used to say.
    • Andeh
      • Jan 2011
      • 21
      under £5
      • Andeh
        • Jan 2011
        • 21
        Ok, the monitor is working fine now, as I mentioned before, but there are a few more caps I would feel more comfortable if I replaced. Problem is, a couple of them are 125 degree caps, and esr.co.uk only seem to have 105 degree caps. Would it be ok to use 105 degree caps instead of 125?
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          125 degree caps? Darn. In that case... if it ain't broken, don't fix it.
          A working TV? How boring!
          • Andeh
            • Jan 2011
            • 21
            they're buldging though and I would expect them to fail soon, so I'd rather replace them before they do
              master hoarder
              • May 2008
              • 12164
              • Bulgaria
              #26
              Actually, that means they already have failed.
              Just use quality 105C rated caps (i.e. Panasonic, Rubycon, Nichicon, Chemicon, Samxon). As long as the ripple current and the ESR of the replacements match or exceed the specs of the original caps, everything should be fine.
              • Rtech
                • Jul 2010
                • 1095
                #27
                105C should be fine.
                • Andeh
                  • Jan 2011
                  • 21
                  #28
                  theres a couple of 6.3v caps, so im asuming that its ok to replace those with 25v caps?
                  • Rtech
                    • Jul 2010
                    • 1095
                    #29
                    Maybe a bit overkill,and would have no problem with 10v ones.Even the 25v ones will probably work,but you don't know where they are in the circuit,as I say it may fine.Will they fit ?? as the 25v ones are certainly must larger than the original 6.3 ones ??
                    • Andeh
                      • Jan 2011
                      • 21
                      #30
                      the 6.3v ones are actually not that much smaller than the 16 and 25v ones
                      • Rtech
                        • Jul 2010
                        • 1095
                        #31
                        Up to you then really.
                        • Andeh
                          • Jan 2011
                          • 21
                          #32
                          well it'll have to be 16v caps then. As long as they work, then thats good enough for me.
                          • arekkks
                            #33
                            Hey!
                            I've the same problem with this monitor... but I can't open the casing. I'm unscrewed all the screws, but still holding up ... and didn't want to broke anything. Any advice?
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #34
                              Originally posted by arekkks
                              Hey!
                              Pry it apart. See
                              https://www.badcaps.net/forum/showpo...84&postcount=2
                              --- begin sig file ---
                              --- end sig file ---
                              • arekkks
                                #35
                                Thanks a lot
                                • GougeUK
                                  • May 2011
                                  #36
                                  I too have the same problem with the same monitor but like others am struggling to remove the back. Screws are out and I did try prying it open but with little luck.
                                  Andeh can you give any help as to where the catches are located on the case to know where to pry the plastic or any other assistance for that matter.
                                  TIA
                                  G
                                  • malnon
                                    • Jan 2011
                                    #37
                                    I too have this same monitor, and problem, I just cannot remove the front bevel, I have loosened all the way round but it seems to be catching about 1/2" from the bottom on both sides and refuses to pry off, I see mention of screws but I cannot see where any screws would be located, any help in getting the front bevel off would be greatly appreciated !!
                                    • acw
                                      • Oct 2012
                                      I've just finished working on my Belinea 102036W, so I might be able to help. Once you've separated the monitor from whatever stops it from falling on the floor, there are five screws to locate and undo before you can start prising the back off. One big screw is directly behind the on/off switch and points at it from behind. (You may have to remove a plate held on with four screws to gain access to it if you use a stand for the monitor.) There are four more screws hiding under four black bungs which are disguised as decorative raised pills on the large black plastic cover. There's one in each corner and they need pulling out with pliers. Then you can do your worst with a screwdriver to lever the back off.
                                      Adrian
                                      • acw
                                        • Oct 2012
                                        I had a very similar problem to the op and solved it by replacing all five 100uf 25v capacitors on the board which is pictured in image number 4 on the first page of this thread. The blue switch light used to flash randomly and the monitor needed unplugging whenever the screen went black for a legitimate reason like going into standby, changing orientation etc. I used cheap 85 degree C caps from Maplins as I was in a hurry. They should be 105 degrees. The five original caps were all just slightly domed; no brown ooze. Hope that helps someone.
                                        Adrian
                                        • bel07
                                          • Feb 2013
                                          • 7
                                          #40
                                          Hi guys!
                                          I need some help! I had same problem so i Have decided to give it a try. I have ordered and replaced all of them faulty caps beside two. I am not sure which goes where. I have taken photo before I took them out but cant see it clearly on photo due to the light reflection.
                                          Please let me know which goes where if you have any clues.
                                          See them two on pic below.
