Samsung P2450 inverter problem
  • garrymc123
    • Apr 2010
    • 336
    • United Kingdom
    Hi there i have just bought a monitor a samsung p2450 which i was told the screen would go blank after a couple of seconds. So on testing this that is the case. So i thought it would be faulty capacitors as it mostly is with samsung monitors. But when i opened the monitor up this was not the case. It has a big burn mark and a hole at CN3 ,CN4 next to a resistor and a capacitor. what would cause this,Is it repairable , or can i try and connect a universal 4 ccfl lamp inverter to this board to get the monitor working again.
    Here are some pics
    Any help appreciated
    Thanks again
    Garry
    Your never to old to learn
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Samsung P2450 inverter problem
    With some time and effort, this board could be fixed. The pins of the ccfl connector would have to be cleaned to prevent arching. The traces need repaired or replaced with wire of certain guage. I'd replace the resistor too. If it were a smaller monitor, I'd say forget it. Once the board is cleaned up and that part is replaced, you still dont know what else is bad on the board, if anything.
    • Rtech
      • Jul 2010
      • 1095
      I iamagine that my concern here,if I decided to try and repair, would be whether the transformer is 100% OK !!!!
      • jetadm123
        • 2169
        I agree with Rtech that the short drawing that much current may have damaged the inverter transformer and other surrounding components. Also, what caused the short? I'm guessing that one of the CCFL tubes shorted to the case, so that needs to be addressed by looking at the CCFL tubes and wiring.
        • Pasanyi
          • Stockholm
          Here are some pics
          Thanks again
          Garry
          How could you fix your monitor?
          • selldoor
            Slow Learner
            • 7870
            This thread is over 12 months old so I doubt that you will get a reply- If you have a similar problem with the same monitor we may be able to help.
            Welcome to the forum-
            We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
            Examples of what is needed
            https://www.badcaps.net/forum/attach...1&d=1290283049
            https://www.badcaps.net/forum/attach...7&d=1280167246
            It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
            • Rtech
              • Jul 2010
              • 1095
              If your Board is burnt as badly as the one shown,then attempted repair would probably create more problems than it would solve.If 2 Monitors have done the same thing,then even a replacement Board may also go the same way.I would probably test the screen using another 24" Monitors internal parts,and then think either about using that and the Logic Board as spares or offer them for sale.I would think a good 24" Screen ,would bring in a good price.
              • saltyscot
                • Sep 2014
                • US
                Having a problem with back-light on my Samsung P2450. Comes on for only one second at power cycle. Hoping for some guidance regarding the pry points to open the case without tearing it up. Thanks!
                • saltyscot
                  • Sep 2014
                  • US
                  Got the case off and found the power board looked like - but not quite as bad as - the pictures posted previously by garrymc123.
                  Found the whole board for $29 plus $8 shipping at http://parts-lcd.com.
                  • rcasey
                    • Aug 2017
                    • 3
                    My power board looks almost exactly like the pics posted by garrymc123!
                    saltyscot - Did the replacement board from parts-lcd.com solve your problem?
                    Thanks!
                    • rcasey
                      • Aug 2017
                      • 3
                      Thanks!
                      Oops. I posted this message twice. Can't find delete button!
                      • CptChronic
                        Samsung LU32J590UQUXEN Monitor display problem
                        by CptChronic
                        I have an intermittent display problem with my monitor, when I plug in the HDMI cable to my (or any) laptop, you see the connection screen shrink on the laptop as it usually would before displaying on the monitor but 95% of the time the monitor display stays black.
                        Before it cut out all together, tapping the monitor control button a fair few times would make the screen display, and everything work fine.
                        But now it never does it. Not sure what's going on, hoping someone can help. I'm capable of stripping the thing down and soldering in new parts if needed, or programming...
                        04-24-2023, 04:33 PM
                        09-07-2024, 05:50 AM
                      • howardc64
                        Samsung UN55JU650DF network/streaming problem
                        by howardc64
                        Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                        This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                        07-09-2025, 12:44 PM
                      • alro7779
                        Samsung UN55MU6103F video problem; has colored stripes on the display
                        by alro7779
                        Hello, everyone!
                        A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                        09-27-2025, 11:29 PM
                        09-06-2024, 11:40 PM
