HP L2208W vertical and horizontal lines
  • wenter
    • Aug 2010
    • 65
    I was given this 22" LCD monitor. The issue it has is the following:
    1) When turned on monitor shows up lots of horizontal and vertical lines
    2) When it warms up most of the lines disappearing except some lines on the top part of screen, that never go away.
    3) All capacitors on power supply/inverter board looks ok
    4) All capacitors on logic board looks ok
    5) Monitor is little over a year old.
    What can be the cause of this issue?
    What should I start troubleshooting with?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: HP L2208W vertical and horizontal lines
    Depending on how long it takes to warm up, you could using a hair dryer to see if it makes the lines disappear quicker or not.
    Try warming up sections of capacitors at a time. If the hair dryer makes a difference the caps could have high ESR or there is bad soldering.
    Caps can fail in a year as well if they were poorly made and subjected to a lot of heat.
    --- begin sig file ---
    --- end sig file ---
    • jetadm123
      • 2169
      When you see the vertical lines, try lightly pressing down on the top part of the LCD panel where the lines originate from. If the lines go away, then you may a defective LCD panel.
      Try checking the voltage regulator (U12?). Record voltages at each pin.
      If the above two check good, try replacing the the 5 caps on the logic board.
      • wenter
        • Aug 2010
        • 65
        I warmed up different sections of power board and logic board with a heat gun on a very low settings. The surface of the caps was getting warm (not hot) but there where no changes to the picture.
        Most of the lines are horizontal. After monitor warms up almost all of the lines are gone.
        However picture looks interlaced - very blurry and like it shows only every other line on the screen.
        When I press on the top part of the screen - lines do not go away.
        I could not find the voltage regulator on the board can you point me to the picture, plz?
        Thanks for replies.
        • wenter
          • Aug 2010
          • 65
          Little update: I found the voltage regulator - it is almost in the middle of the logic board.
          I was going to check the voltages, but before that I decided to hook up the monitor to another computer. As I turned on the computer LCD went white. It does not show any picture now.
          I connected it back to the laptop - but still there is no picture on the screen - just white color filled screen
          Looks like something really wrong is going on with this monitor.
          I will order all capacitors for the power board and logic board from DigiKey tomorrow. Hope it will cure everything.
          • jetadm123
            • 2169
            A white screen is a possible indication that a fuse has blown on the LCD panel controller board. This board is at the top of the panel and spans the width of the lcd panel. It may be underneath a metal cover or a clear sheet of plastic. The fuse is a surface mount device, marked Fxx and usually located near the flat ribbon cable. Also, go ahead and check the voltage regulator before you check the LCD control panel.
            • Kikerumbo
              Mi Curved Gaming Monitor 34" - Horizontal lines
              by Kikerumbo
              Thanks in advance for any help you can provide.
              I have a Mi Curved Gaming Monitor 34". A few weeks ago it started to show (or not showing) horizontal lines. Of course, it's outside of the warranty period.
              After some hours of reading and watching videos I disassembled the monitor and checked the ribbons that go from the TCON board to the panel PCB. If I disconnect the ribbon for the right side of the panel, the other half shows a perfect image. I ordered a "new" TCON, installed it and the issue persists so that tells me it must...
              03-14-2024, 02:48 PM
            • Stanley1843
              by Stanley1843
              06-29-2024, 11:54 AM
            • noisykid
              Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
              by noisykid
              5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
              12-30-2024, 07:15 PM
            • x_orange90_x
              Samsung UN46C8000XFXZA vertical bars/horizontal lines
              by x_orange90_x
              I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
              The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
              09-04-2023, 12:09 PM
            • oxi1158
              Toshiba TV 55L6200U horizontal lines + vertical bands. Any hope?
              by oxi1158
              My TV had been showing for the last year some faint horizontal lines on all of its right side, about one out of each 4 of 5 rows of pixels. Not much of a bother, they were unnoticeable when watching a movie. Then, all of a sudden the horizontal lines became much stronger and crossed the whole screen, effectively making it a pain to watch.
              I watched some youtube video where some guy "fixes" it with some tape on the ribbon cable of the t-con, so I tried that, but to no avail. Actually, after putting the TV back together again things worsened: apart...
              10-09-2020, 08:37 PM
