ACER X221W / XW221 2 sec and off
+ More Options
Posts
  • BarrelRoll
    • Jan 2011
    • 34
    First real post here. I was thinking about recapping this but figure I would check in here first since there's no evidence of the caps busting (yet).
    I tried to read as many threads as I could about the 2 sec then off problem so I started checking a few basics. Power supply board is FSP055-2PI02A. All the electrolytics on the board I can read are TAICON HW and HH series except for 2 CapXon KFs on the low voltage outputs.
    Symptoms are power up, power light goes from amber to green and stays on green and steady. Back light comes on, see the ACER logo, then within a second or two the backlight dims slightly and then goes off completely. Since this is a four back light system I'm guessing I'm losing one of the pairs then the other.
    The low voltage power outs to the input board from the PS board are just +5, +12, back light on/off and ground.
    +5 is right on +5.0
    +12 is between +13.5 and +14 which seems a little too high to me, but maybe without the back lights running its different than it should be under a properly loaded condition?
    What can I look at next? I'm guessing it's time to start taking the panel apart and check out the CCFLs :\ Thanks for any help ahead of time!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: ACER X221W / XW221 2 sec and off
    1) Bad caps can cause 2 seconds to black. Capxon doesn't have the greatest reputation here.
    2) The voltage is a bit high because the ccfls are off.
    3) If you have a spare lcd monitor, you can use it to help test the ccfls.
    4) Other possible causes of 2 seconds to black are
    a) bad ccfl wiring
    b) bad inverter transformer
    c) bad sense circuitry
    5) All the above is explained in more detail at (starting with post #13)
    https://www.badcaps.net/forum/showthread.php?t=10419
    --- begin sig file ---
    --- end sig file ---
    • BarrelRoll
      • Jan 2011
      • 34
      Thanks, looks like I have a lot of reading and measuring to do
      These CCFL's aren't from this unit, but another TV that I just started taking apart (Polaroid branded ProView unit)
      I'm going to guess that this is pretty much not something you want to see on your CCFLs (taken with macro mode on a canon point and shoot with CCFLs active)
      Feel free to use this as a demo image if it's helpful for your thread. Three of the four ends of the two bulbs show quite a bit of blackening. Is this what I don't want to see when I take the panel apart?
      • retiredcaps
        • Apr 2010
        • 9271
        Here is a photo album showing more examples ...
        http://s807.photobucket.com/albums/y...klight%20lamp/
        • BarrelRoll
          • Jan 2011
          • 34
          I pulled the panel apart and all the CCFLs look decent. No blackening or signs of heat or burning.
          Here is the electrolytic cap inventory:
          w x l
          (2) 10mm x 16mm TAICON 680uF 25v 105C HH series - C24, C261
          (2) 10mm x 16mm TAICON 1000uF 10v 105C HW series - C244, C241
          (1) 18mm x 40mm TAICON 150uF 400v 105C AS series - C114
          (1) 5mm x 12 mm TAICON 22uF 50v 105C HW series - C123
          (1) 8mm x 12mm CapXon 220uF 25v 105C KF(?) series - C263
          (1) 8mm x 12mm CapXon 470uF 10v 105C KF series - C242
          Next on my list is to watch the backlight on/off line coming from the control board. Do I measure the voltage there between the on/off pins on the interconnect or between the on pin and ground?
          After that it'll be time to poke around with the transformers I guess.
          • Rtech
            • Jul 2010
            • 1095
            Backlight on and ground,when the lights are on, should be roughly between 3-4 volts DC
            • BarrelRoll
              • Jan 2011
              • 34
              Thanks!
              • retiredcaps
                • Apr 2010
                • 9271
                Not sure I understand your question, but I would measure between the on/off connector pin and ground.
                The secondary transformers are easy enough to test. Maybe do that first and make sure they are within 3% of each other.
                • BarrelRoll
                  • Jan 2011
                  • 34
                  Oh I didn't see that before. The power supply has an 8 pin conector to the control board
                  +12 | +12
                  Gnd | Gnd
                  +5 | +5
                  ADJ | ON/OFF
                  I thought on and off were separate pins. I didn't see the adj label. My bad.
                  • BarrelRoll
                    • Jan 2011
                    • 34
                    I think I understand the secondary test. In this case it looks like I have two transformers sharing a common core. If that's the case, something looks not right. I tested all pins to all other pins but omitted ∞ ohm readings for brevity.
                    T1 - tested in circuit with ccfls disconnected.
                    a primary coil - 1.5 ohm
                    a secondary coil - 994 ohm
                    b primary coil - 1.5 ohm
                    b secondary coil - 1.766 MegaOhm
                    T1 part ID:
                    SPI 8TC00332
                    0719 1 FC GP
                    looks like lcdparts has them and a picture of it found from another thread here:
                    http://lcdparts.net/TransformerDetai...ProductID=2796
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      Transformer "b" is bad. It should be around 1000 ohms.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Search for 8TC00332 on ebay.com.
                        There is one listed for $12. IMHO, it is worth the $12 + shipping to fix a 22 inch lcd.
                        • mockingbird
                          • Dec 2008
                          • 5484
                          Good job listing the caps. Will make it easy to look up suitable replacements. Note that I'm aware of other suitable series, but I will list those that precisely match the diameter.
                          1) HH - Nichicon HV
                          2) HW - Nichicon HE
                          3) Primary - United ChemiCon KXG
                          4) HW - Nichicon HE
                          5) Capxon KF - Nichicon HD
                          6) Capxon KF - Nichicon HD
                          Everything is in stock.
                          Let's have a look at your logic board as well... Are there only solid polymer caps on there? If there are some electrolytics, you have to replace them, or at least those with a high enough value.
                          • BarrelRoll
                            • Jan 2011
                            • 34
                            Ordered one up!
                            I did some reading here on TAICON/NichiCon joint venture and apparently there are mixed feelings on them due to the defective electrolytics that went into the Dell/Apple fiasco. I guess next on the list is reading data sheets to find replacements for those TAICON and CapXon caps.
                            • mockingbird
                              • Dec 2008
                              • 5484
                              Nichicon capacitors are just as reliable as any other quality manufacturer out there. The defective electrolyte only affected Ultra-Low ESR Nichicon HM and HN series with a datecode of 2000 to 2006 or 2005 I am not clear.
                              I should know, I have a whole bag of like 40 6.3 2200 HM I ordered from Mouser recently.
                              Good luck finding something like Nichicon HV in stock somewhere that will precisely match your Taicon HH.
                              • BarrelRoll
                                • Jan 2011
                                • 34
                                Ah ok, I was just worried these caps were from that same series.
                                • dondrusco
                                  • Apr 2009
                                  • 89
                                  T1 part ID:
                                  SPI 8TC00332
                                  0719 1 FC GP
                                  Yes, it is the right part. I had the same problem with Fujitsu - mentioned thread.
                                  Good luck!
                                  • BarrelRoll
                                    • Jan 2011
                                    • 34
                                    New transformer arrived yesterday, soldered it in and it fired right up. Awesome!
                                    What are your thoughts on the white silicone/glue that was over the transformer solder joints? Just in case to prevent arcing to something? Am I safe to not replace that or would it be a good idea to cover the terminals with something?
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      Was the transformer from ebay?
                                      My uneducated guess. I believe it is to hold part in place during assembly because it is a "heavy" component.
                                      Most inverter transformers I have personally seen have no glue on them at all.
                                      • BarrelRoll
                                        • Jan 2011
                                        • 34
                                        No, while that transformer was $12, it was located in Hong Kong. I ended up getting it from LCDparts/MoniServ for $25 shipped.
                                        Cool, I thought it might be for assembly reasons, thanks again everyone!
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                        • serious_electron
                                          Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                          by serious_electron
                                          Hello Everyone!
                                          I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                          06-28-2025, 02:57 PM
                                        • PNI E.
                                          tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                                          by PNI E.
                                          hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                                          02-20-2025, 08:36 AM
                                          09-06-2024, 05:27 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:00 AM
