Dell 2005FPW no display, solid power lights
  • Coolbri1191
    • Dec 2010
    Hi, I have a Dell 2005FPW Monitor that I recently put 12 new caps into the power board, but it is still not working.
    What happens, is I press the power button, and the backlight comes on for about a half second, then goes away. Power lights all still work and can even choose inputs from the button panel, but still no picture or display.. the same exact problem I had before I replaced all the caps. If you guys have any insight on what I should do, that would be great. Thanks..
    Brian.
  • Toasty
    • Jul 2007
    • 4171
    Re: Dell 2005FPW no display, solid power lights
    What brand and series caps did you use?
    veritas odium parit
    • Coolbri1191
      • Dec 2010
      They were provided in a kit from a website (idk if I'm allowed to say so I removed it)
      They apparently use only the "good" caps.
      Here's a quote directly from their site..
      "We only use high quality capacitors manufactured by Panasonic, Nichicon and Rubycon in our kits. We do not use CapXon capacitors."
      The kit provided..
      2 - 10V 1000uf
      3 - 25V 820uf
      1 - 10V 680uf
      2 - 25V 470uf
      1 - 50V 100uf
      3 - 25V 47uf
      • PlainBill
        • Feb 2009
        • 7034
        Brian.
        Sounds like a 'Two seconds to black' problem. To confirm, with the monitor hooked to a working computer can you see a display (desktop) when you shine a flashlight on the screen?
        PlainBill
        • alexanna
          • Mar 2010
          • 1346
          Brian.
          This is more for information, And maybe something to put on the back burner for a while
          I have not seen a dell 2005 series monitor yet, The ones I have had are the 2001 series that have had the 2sec. to black problem .These have all been caused by bad ccfls.
          Even without a video signal present, I have noticed a Dell self check feature box floating around the screen, with a green power LED lit up, and going to 2 sec to black.
          This monitors ccfls most likely uses a slightly different style of connector for the ccfls but with a little extra work a known good ccfl can be substituted to help diagnose the 2 sec to black problem.
          I know as the old saying goes, were not comparing apples to apples, but it's something to keep in mind.
          Al
          • Coolbri1191
            • Dec 2010
            Okay, I shined a flashlight on the display and still couldn't see anything. Is there a specific way to do this?
            The screen literally flashes for half a second on power up.. it's not 2 seconds. It might even be quicker than a half second.
            If it is a dead ccfl, how can I go about fixing it from there? I'm really hoping it's just a loose wire or something, or maybe a cap on the logic board?
            EDIT: Upon further inspection, I got a white box to pop up in windows, and was able to see that with a flashlight... :/ At least we're making some progress now.
            • retiredcaps
              • Apr 2010
              • 9271
              You can read this guide starting with post #13 and #14
              https://www.badcaps.net/forum/showthread.php?t=10419
              Note we will want pictures. There is a section in the guide regarding pictures as well. Please use the manage attachments feature and do not post pictures inline.
              After you post pictures, we can make suggestions as to what might be the most likely problem.
              --- begin sig file ---
              --- end sig file ---
              • PlainBill
                • Feb 2009
                • 7034
                One little tidbit I picked up on recently. 'Two Seconds to Black' is a general term. The actual delay between detection of a fault and shutting down the inverter is controlled by a cap near the inverter controller. Some designers allow more time, some allow less. In case of an open CCFL (broken tube or broken wire), some inverter controllers will shut instantly.
                PlainBill
                • Coolbri1191
                  • Dec 2010
                  What pictures do you guys need first?
                  • alexanna
                    • Mar 2010
                    • 1346
                    start with top and bottom of the power supply and inverter
                    Al.
