Hannspree M19W1 2 secs on Prob
  • ceedy
    • Nov 2008
    • 76
    Not been here for a while since I Recapped an Old ProView 700P from all the ace info on here..
    Its still going great guns as my spare ..
    Actually having to use it at the moment as my 19 in Hanspree has just died on Xmas eve !and 2 weeks outside its warranty , a bummer.
    Here 's a Piccy of the offender ...
    [/IMG]
    Done a limited recap of all the obvious bulgers around the Right angle heatsink , but its still got the 2 seconds on problem.
    Seems a similar layout to a few common boards . But I've limited testing equipment now .. and the Makers have been decidedly unhelpful with a replacement ( they will only do a whole LCD repair @ some cost and not flog me a PSU ?.
    Any clues where I go go with this fella , t' was such a nice monitor.
    Happy Xmas & new year all
    Chris
  • sabre504
    • May 2010
    • 449
    Re: Hannspree M19W1 2 secs on Prob
    Hi most on here would recommend that you replace all the caps except the largest one which rarely fail (but can sometimes)
    As a lot of the caps may not bulge but will lose capacitance or go out of range on ESR
    • retiredcaps
      • Apr 2010
      • 9271
      Please do not post inline (slows things down) or offsite (lead to potential unwanted popups). Use the manage attachments instead.
      That blue cap looks like a Radio Shack cap. Radio Shack does not sell low ESR caps that are required for a SMPS application.
      See this for a list of recommended caps.
      https://www.badcaps.net/forum/showthread.php?t=2280
      For your 2 seconds to black, it could be
      1) bad caps
      2) bad inverter transformer
      3) bad ccfl or wiring
      4) something wrong in the sense circuitry
      See this guide on how to troubleshoot starting with post #13
      https://www.badcaps.net/forum/showthread.php?t=10419
      --- begin sig file ---
      --- end sig file ---
      • ceedy
        • Nov 2008
        • 76
        Happy New year all..
        Done a recap.. all except the biggun.. and no change , switch off switch on
        1-2 seconds ok then off.
        One symptom I've just noticed during playing about is .. the Screen will switch on and off during a Boot up
        so as the PC goes through the various startup screens it will go on then off .
        is this due to the various Frequencies being used ? from the Old Dos'y up to the windows ( in my case 75 mhz) screen.
        Would this indicate the probem is in the sensing circuitry just a guess?
        Where can I go now ???
        Chris
        • retiredcaps
          • Apr 2010
          • 9271
          See my suggestions in post #3. You can rule out bad caps now and move down the list.
          • ceedy
            • Nov 2008
            • 76
            Just a Pic of the Track side of the Board.. can just make out the IC's numbers and looked them up on the net .? ..
            thanks for the reply will have a go at the other area ..
            reckon I'll be back tho' ..
            • Mr_Bodgit
              • Dec 2010
              • 47
              • doncaster
              Chris
              some monitors do turn off and on during booting up windows as things change (size and refresh rate adjustment) connect the monitor to the pc after loading windows up, dual output cards are handy for testing monitors on the second output.
              does the power LED stay on after the screen goes black? does it go off compleatly or to standby?
              if the power light stays on then i would connect the CCFL tubes from your working monitor to the inverter on the one thats faulty, no need for any other connections, just the tube wires and see what happens, if they stays on then its one of the CCFL's thats the problem and causing it to turn off, like wise to test the inverter, connecting the working screen ccfl's to it and see if it still turns off, if the connections are the same its the easiest test to do,
              just sorted my first 2 faulty screens out by testing ccfl's after a few bulging caps dint sort 2 seconds black out, but they had been on for 45k hours
              Regs
              Rich
              • ceedy
                • Nov 2008
                • 76
                Regs
                Rich
                Thanks I'll try that .. I've a CCFL Driver module board I bought on Fleabay
                a while ago to try on another ( failed repair) LCD.
                It only needs a 12 v supply to drive the Tubes. that should do ?.
                I 'll dig it out tomorrow and have a go.
                I can see the display with a torch ok . and the power light does stay on all the time during the blackouts, switch on and off and the picture is back for a moment .
                I've just pulled the 3 transformers of the board, and a 4 Pin semiconductor but not quite sure which pins to test with my old Fluke 77.
                Just taking some piccys of the offenders .
                Chris
                • ceedy
                  • Nov 2008
                  • 76
                  Just powered up the tubes , all seem good .. used this module form fleabay..
                  also here's the transformers... and the one semiC i've pulled off .
                  C.
                  • ceedy
                    • Nov 2008
                    • 76
                    Small transformer ..
                    4 pins 2 coils = 1 ohm each
                    7 Mohms between windings
                    The longer one SPI 8TC00293 8 pins,
                    across the 4 pairs of pins ( shortest width )?
                    resitances are :
                    1540 ohm 1.2ohm 1.2ohm 1127ohm
                    Open circuit between pins along the long sides
                    Not sure which pins to check on the First tranny. ?
                    or how to check the 4 pins semi ?
                    C.
                    • Rtech
                      • Jul 2010
                      • 1095
                      Your 8 pin one is faulty......1.2ohms are the primaries,and they are correct, the other two readings are the secondaries(driving the Backlights)and they shoud be within 5% of each other(some people like 3%), so it looks like the 1540 one is probably the faulty one,and you will need a new one ...IF YOU CAN FIND ONE !!!!!!!
                      Good hunting
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        http://lcdparts.net/T.aspx might have them. They have 2 part numbers that are close
                        8TC00221 and 8TC00332
                        You can always give them a call or send them an email.
                        • ceedy
                          • Nov 2008
                          • 76
                          Hi again
                          many thanks for the input .. Looking to be a tricky replacement.?
                          must ask ...tho' how would a tranny secondary mismatch cause the black out on all the tubes ?? just wondering about the sequences that would happen to cause it ?.
                          wouldn't it only give a differing output to the top & bottom tubes, as they feed direct to the tubes ??
                          Chris. ( Oldish and tryin to to retire! myself! )
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Hi again
                            You are exactly right in the effect, but miss the implications. An inverter is best thought of as a constant-current AC source with over voltage and over current protection.
                            The inverter controller monitors the total current through the CCFLS, and adjusts the drive signal to maintain the proper level. It also checks the voltage across every CCFL and will shut down if any exceeds the safe level. This is to detect a broken lamp or broken wire to a lamp. It also checks the current through each lamp and will shut down if the current through any lamp rises too high (lamp current rises as the tube ages).
                            Now consider the implications of a shorted secondary. The output voltage will be reduced because the total number of turns has been reduced. The output voltage will be further reduced because the shorted turns act as a shunt, loading the primary. Since the output voltage of the transformer is reduced, the current through the CCFL will be reduced. Since the inverter is trying to maintain a constant current through all CCFLs, it increases it's drive, and the good CCFL will be handling more current, and trip the over current protection.
                            PlainBill
                            • ceedy
                              • Nov 2008
                              • 76
                              Many thanks . what a brilliant explanation.. just the thing to fill to large holes in my ole brain , ( not used as much these days ? LOL..)
                              As its looking tricky to source this lil fella .. is there much variation in specs
                              I can look for , especially as it needs to physically fit as well ?,
                              Not many adverts seem to give the dimensions , unless that is they are all the same size ??? .
                              thanks again Chris
                              PlainBill
                              • ceedy
                                • Nov 2008
                                • 76
                                Found a lot of similar ( up to a point) Boards available complete with a very close layout and specs ..same part number but a slightly differin' shape board
                                like this ..
                                http://cgi.ebay.co.uk/Power-Board-FS...item3a610d9a16
                                I thinking maybe the best way to get a small pile of sparse to test/check/replace would be to get a whole board and swap the part ??
                                they are not too expensive ?? even if I have to wait from HK, can always test it before pulling to bits ..
                                seem reasonable idea ??
                                C.
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  like this ..
                                  C.
                                  Depends on what type of personality you have.
                                  One type will cheerfully strip the board for parts, discarding it when it has no useful parts left.
                                  Another type will discard the board quickly because it's bad. Usually this occurs shortly before you need another part from the board.
                                  A third type will be compelled to repair the donor board.
                                  PlainBill
                                  • ceedy
                                    • Nov 2008
                                    • 76
                                    PlainBill
                                    So there's no major flaw in Plan A ?
                                    1 & 3 apply to me !!
                                    I'm a right old magpie!! I've boxes of odd bits I've stripped off injured stuff .. nothing to suit here tho '
                                    Usually I need a part a week or so after i've chucked it in clearup .. :p.
                                    I'll grab one of these in a last attempt ... Back in a week or so to report ??
                                    of any success.
                                    take care all
                                    C.
                                    • ceedy
                                      • Nov 2008
                                      • 76
                                      My New Donor PSU has turned up .( actually a UK supply)
                                      The 8 pins trans measures right .. so will
                                      start swapping with this.
                                      Looks a nice close layout with near indentical components.
                                      Cheap way to get the parts @ £12 delivered .
                                      • ceedy
                                        • Nov 2008
                                        • 76
                                        Touch wood ( using head as its nearest).. it switches on and stays on ?. at least 5 mins at the mo...
                                        Got a housefull of grandkids (only 2 but seem like more ) at the moment.
                                        Not a good mix with open cases and lives lectric .. so will have to wait till they clear off later, to give it a good test.
                                        heres hoping??
                                        Chris
                                        • Chivo77
                                          DELL LATITUDE 5420, ST 20TFKN3, LA-K491P REV:2.0 (A01) powers on and die about 15 secs later, no video
                                          by Chivo77
                                          hello friends, I have a DELL LATITUDE 5420---MODEL P137G, ST 20TFKN3 LA-K491P REV:2.0 (A01) and its quite a challenge. It powers on with the battery disconnected, lasts on for about 15 secs, and then shuts off. It does the same with battery only (no adapter). With battery and adapter it sometimes starts after hitting the button several times. It displays nothing in every case. Since only the Boardview is available, I guided myself with schematics similar to this laptop (I'll add them down).Some measurements:
                                          1- After receiving power SIO_SLP_S0# goes high and never changes.
                                          2-every...
                                          07-03-2025, 09:20 AM
                                        • paparazzo79
                                          Hannspree HT 273 HPB USB cable type A to type B?
                                          by paparazzo79
                                          Hi guys.
                                          I purchased the monitor from the link below:
                                          https://www.hannspree.eu/product/ht-273-hpb/
                                          Since I will be using monitor from bed, I'd need longer usB type A to type B plug cable.
                                          I got one which is 4.5m long, regular one
                                          May I use it without harm to the monitor?
                                          I suppose cable which came with monitor is regular type A to type B,not some speical cable.
                                          I could picture what is labeled on the cable, if it matters for assistance.
                                          08-12-2023, 05:28 AM
                                        • dikei
                                          China Make TV with LG Display horizontal line at top and video freezes 1-3 secs
                                          by dikei
                                          Hi guys!
                                          I'm new to TV repair and just started looking into troubleshooting guides and other online info.
                                          Right now I have a Chinese make with LG display that is faulty. If I am not wrong I see two different problems here below.
                                          1. There is a line(white/multicolored) at the very top of the display that shows thinner sometimes and slightly thicker in some occasions.
                                          2. For any video the play freezes 1-3 secs and at the same time brightness goes low and returns to high when video continue to play.
                                          From my initial research...
                                          07-06-2023, 11:53 AM
                                        • Victor Moreira Silva
                                          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                          by Victor Moreira Silva
                                          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                          Well, my decice specs are the following:
                                          Model: Acer Nitro 5 AN517-54-55T5
                                          CPU: Intel Core i5-11400H
                                          GPU: NVIDIA GeForce GTX 1650
                                          Motherboard: GH51G LA-L181P Rev:1c
                                          The symptom:
                                          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                          05-26-2025, 10:49 AM
                                        • PNI E.
                                          tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                                          by PNI E.
                                          hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                                          02-20-2025, 08:36 AM
