M170EG01 V.8, AU Optronics screen
  • Mr_Bodgit
    • Dec 2010
    • 47
    • doncaster
    started a new thread as the samsung screen is ok and didn't want to keep it going on a different topic,
    i have two touch screen computers
    No 1. 2 seconds black (flickers when on)
    No 2. 30 seconds black (starts fine the begins to flicker but only at bottom of screen)
    swapped inverters as one has a slightly builging cap, and the screens do exactly the same
    still
    so its not the inverters
    the screens are M170EG01 V.8, made by AU Optronics
    i'v removed the 2.S.B one to strip down, does anyone know where to get the tubes from?
    screen info here
    http://www.yslcd.com.tw/docs/product/M170EG01%20V.5.pdf
    Regs
    Rich
  • retiredcaps
    • Apr 2010
    • 9271
    Re: M170EG01 V.8, AU Optronics screen
    Members here have good feedback and experiences for ccflwarehouse.com
    --- begin sig file ---
    --- end sig file ---
    • Mr_Bodgit
      • Dec 2010
      • 47
      • doncaster
      yeah just noticed they do a set of two for that screen $29
      totally stripped the screen down and removed the holders, sure enough both top and bottom tubes have black ends
      ordered a propper set so should be sorted when they get here, just hope buy then i can remember how to put it all back together lol
      place i got the comps from were quoted £400+ each to get them repaired, total cost to me £27 lol
      Regs
      Rich
      • retiredcaps
        • Apr 2010
        • 9271
        ordered the set so should be sorted when they get here, just hope buy then i can remember how to put it all back together lol
        Take pictures.
        If you are going to get more lcds to fix, there will come a time when some of them are unfixable. Usually if the logic board with the proprietary chip is bad, then it is unfixable.
        From those unfixable monitors comes parts like ccfl tubes.
        If you are to order ccfl tubes, check ebay as well.
        • Mr_Bodgit
          • Dec 2010
          • 47
          • doncaster
          yeah i looked on ebay, sorted the best tubes out and rebuilt it, all the ones we get have been on 24/7 so 9 out of 10 will be tubes most likely.
          i broke a screen while it was out (dropped it lol) i have a m170en05 left from a samsung, does anyone have i pin out for it so i can make a loom up to replace the m170eg01 i broke? plugs are same just wired different way round
          Regs
          Rich
          • Mr_Bodgit
            • Dec 2010
            • 47
            • doncaster
            the tubes turned up yesterday from CCFL warehouse! all fitted, working and a lot brighter!
            altough one of the motherboards has now decided it wont power the screen (not the inverter the actual screen via the onboard screen connector) tested using a known working screen from a samsung syncmaster but its just a blank (white see through) screen, swapped motherboard and tested both screens and they work fine so tested faulty m/board one one last time just incase, no joy it just wont work, has a jumper for 12/5/2.5v power output for different displays so i'll check it actuall gives out a voltage
            do screens go black if they have power but no data to drive them?
            just thinking it might be ESD that killed it as i got up halfway through building it to do summat and never earthed my self when i came back oh well guess i'v got a spare m/b for another pc as the onboard 15pin vga socket still works lol
            oh and for the record AUO screens m170en05 and m170eg01 are same connection just different viewing angle etc, so guess most m170**** are interchangeable.
            Regs
            Rich
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
            • Chrissygizmo
              by Chrissygizmo
              02-10-2025, 12:33 AM
            • ipatch
              ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
              by ipatch
              i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
              08-24-2024, 02:36 PM
