Dell monitor goes crazy for a bit then warms up
  • morgan
    • Nov 2009
    • 12
    http://www.youtube.com/watch?v=UlrrqHyxfQA
    could this be caps or some other simple fix? it goes nuts for about 30 seconds then it's fine and otherwise a great monitor. i posted a video of what happens.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Dell monitor goes crazy for a bit then warms up
    That's a typical manifestation on bad caps on the 5v logic supply.
    A working TV? How boring!
    • morgan
      • Nov 2009
      • 12
      i was hoping you'd say that. then it looks like i've scored a good looking 22 inch monitor from the trash.
      • morgan
        • Nov 2009
        • 12
        btw. i forgot to say thanks... so THANKS.. your input is very much appreciated.
        • Borse2008
          Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
          by Borse2008
          Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
          I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
          • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
          • There’s
          Today, 04:55 AM
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • DanPoka
          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
          by DanPoka
          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
          02-15-2025, 05:05 AM
        • Jesus Coder
          Issues Reviving Old Dell 2408WFPb Monitor
          by Jesus Coder
          I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
          06-25-2023, 02:33 PM
        • ChristianBr01
          Dell 34 inch U3419W Monitor with thin stripes on partial screen
          by ChristianBr01
          I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
          This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
          This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
          Does someone have seen this before?...
          05-23-2025, 06:06 AM
