Viewsonic va902 LCD recap
  • otoluk
    • Feb 2009
    • 84
    • Latvia
    Recapped power board for Viewsonic VA902(aka HannStar JG171A) vs10715
    Symptoms: The display didn't power on. When connected the green power light turns on for second and then dims as the safety circuit kicks in. Then after some time when power is disconnected it is possible to repeat. Disassembled, in some places board was brown from heat, the build quality is low.
    I was able to turn it on if the LCD panel was disconnected, then powering on and allowing it to warm up and then connect LCD. It works until display is turned on. Another way was to heat a little with gun 2 mofsets in power board and then it turned on without problems, as starting power peak was minimized. Backlight worked ok. So the caps could be the cause, although seemed ok by look.
    Board: Date: 2005.05.18 2202130701P Ver:2.01 w/o audio
    Fix: Replace C823,C825 and just in case - C906,C922 . It didn't make a big difference on my pacient. So I replaced the C824 (10V 1000uF) too, and it fixed the problem. C824 is not a typical problem for these as didn't find it mentioned on net.
    I replaced C824 with 16V 1500uF as other caps were 16V and this seems the weak spot when board is old.
    Thanks to : http://monitor.espec.ws/section33/topic90393.html
  • otoluk
    • Feb 2009
    • 84
    • Latvia
    Re: Viewsonic va902 LCD recap
    C823,C825,C906,C922 = 16V 470uF
    C824 = 10v 1000uF
    • otoluk
      • Feb 2009
      • 84
      • Latvia
      Fixed another one. Changed all Elite caps with good ones.
      Some steps for easy disassembling:
      1. Unfold the monitor horizontally. Press the caps(chromed cylinders) from sides and pull out.
      2. Unscrew the hidden screws.
      3. Undo the screws at back.
      4. Unclip the protecting cover. Better heat it with heat gun before for easy removal as it is too crisp.
      5. Neverless some of clips can break as it seems it's mean to be closed once and for all. This can be fixed by gluing around the edge of failed clips.
      see the white crack
      6. The hardest part top open is the stand. There are clips on sides.
      7. Do the magic...
      8. After that - assembly is the reverse of disassembly
      • kappo
        I have almost like same problem as you had. My VA902 just "flashes" the screen when i turn it on. So if i put my screen of, i see something about 1s but then its black again. Do you know whats the problem :O
        • retiredcaps
          • Apr 2010
          • 9271
          This could be "2 seconds to black". See posts #13 and 14 for more details at
          https://www.badcaps.net/forum/showthread.php?t=10419
          --- begin sig file ---
          --- end sig file ---
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • lostone
            Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
            by lostone
            Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
            First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
            When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
            05-19-2024, 11:40 AM
