Samsung Syncmaster 713n problem
  • Oerg866
    • Nov 2009
    • 61
    Hi, I have a Syncmaster 713N I got for free, and well, it actually kind-of works. Whjen I have no cable plugged in, it will go all "Check input cable" or something like that. But when I put in the cable (with working output, checked on 3 other monitors) it doesn't do anything except have a black screen.
    Any ideas?
    Cheers,
    Oerg
  • PlainBill
    • Feb 2009
    • 7034
    Re: Samsung Syncmaster 713n problem
    Any ideas?
    Cheers,
    Oerg
    It's not an unusual problem with Samsungs. I'm not aware of anyone who has successfully repaired a monitor with the problem.
    One point that I have not checked - have you tried the monitor on a computer whose video card has been set to 640 x 480 resolution? Or connecting the monitor to a computer while both are unplugged, plugging in both, then turning on the monitor, then turning on the computer?
    PlainBill
    • Oerg866
      • Nov 2009
      • 61
      Nothing worked -- Except I noticed when i push MENU it will show a little area on the top left that goes "TEST OK" ...
      • EGuevarae
        • Nov 2008
        • 1336
        Firmware/flash rom corruption.
        • ASUS ROG Maximus IX Code
        • Intel Core i5-7600K 3.8GHz
        • Windows 10 Pro x64
        • GeForce GT1050
        • Oerg866
          • Nov 2009
          • 61
          Fixable?
          • Oerg866
            • Nov 2009
            • 61
            Also bump
            is this actually fixable in an easy way?
            • PlainBill
              • Feb 2009
              • 7034
              Also bump
              It depends on the cause. If it's the flash memory (used to store user settings), sometimes a master reset will solve it. This involves holding down certain buttons while plugging in the monitor. If it's the firmware, it would require obtaining a good copy of the firmware, a blank prom, copying the firmware to the new prom, then installing the new prom on the board. The firmware may be difficult (or impossible) to find, the programmer will easily run $100, and replacing the IC is challenging.
              One possible alternative: I have seen ICs for sale with the firmware preloaded. The prices on these were reasonable - under $10, but they are not available for many monitors.
              PlainBill
                09-07-2024, 05:50 AM
              • falcontech
                Samsung Syncmaster 943B problem
                by falcontech
                Hello
                I have a problem with a samsung 943B, initially thinking it was a power problem i replaced the power board which is a bn44-00082e, i had a flashing of the ccfl lamps and the monitor would not start, i replaced the power board and the problem is remained, thinking they were the lamps I tested them with a ccfl lamp tester and they are all working, at this point I think it is the main board which is a BN41-01172B, my question is, before making a further purchase there is a way to turn on the lamps without the main board to exclude that the new power board is also broken? Of course without...
                02-16-2022, 12:54 PM
                09-06-2024, 11:40 PM
                09-06-2024, 08:40 PM
