Samsung Syncmaster 713n problem
  • Oerg866
    • Nov 2009
    • 61
    Hi, I have a Syncmaster 713N I got for free, and well, it actually kind-of works. Whjen I have no cable plugged in, it will go all "Check input cable" or something like that. But when I put in the cable (with working output, checked on 3 other monitors) it doesn't do anything except have a black screen.
    Any ideas?
    Cheers,
    Oerg
  • PlainBill
    • Feb 2009
    • 7034
    Re: Samsung Syncmaster 713n problem
    Any ideas?
    Cheers,
    Oerg
    It's not an unusual problem with Samsungs. I'm not aware of anyone who has successfully repaired a monitor with the problem.
    One point that I have not checked - have you tried the monitor on a computer whose video card has been set to 640 x 480 resolution? Or connecting the monitor to a computer while both are unplugged, plugging in both, then turning on the monitor, then turning on the computer?
    PlainBill
    • Oerg866
      • Nov 2009
      • 61
      Nothing worked -- Except I noticed when i push MENU it will show a little area on the top left that goes "TEST OK" ...
      • EGuevarae
        • Nov 2008
        • 1336
        Firmware/flash rom corruption.
        There are 10 kind of people in this world: those that understand binary, and those who don't.
        • ASUS ROG Maximus IX Code
        • Intel Core i5-7600K 3.8GHz
        • 16gb GSKILL TridentZ RGB DDR4-3200
        • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
        • Windows 10 Pro x64
        • GeForce GT1050
          2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
        • Oerg866
          • Nov 2009
          • 61
          Fixable?
          • Oerg866
            • Nov 2009
            • 61
            Also bump
            is this actually fixable in an easy way?
            • PlainBill
              • Feb 2009
              • 7034
              Also bump
              It depends on the cause. If it's the flash memory (used to store user settings), sometimes a master reset will solve it. This involves holding down certain buttons while plugging in the monitor. If it's the firmware, it would require obtaining a good copy of the firmware, a blank prom, copying the firmware to the new prom, then installing the new prom on the board. The firmware may be difficult (or impossible) to find, the programmer will easily run $100, and replacing the IC is challenging.
              One possible alternative: I have seen ICs for sale with the firmware preloaded. The prices on these were reasonable - under $10, but they are not available for many monitors.
              PlainBill
                09-07-2024, 05:50 AM
              • howardc64
                Samsung UN55JU650DF network/streaming problem
                by howardc64
                Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                07-09-2025, 12:44 PM
              • falcontech
                Samsung Syncmaster 943B problem
                by falcontech
                Hello
                I have a problem with a samsung 943B, initially thinking it was a power problem i replaced the power board which is a bn44-00082e, i had a flashing of the ccfl lamps and the monitor would not start, i replaced the power board and the problem is remained, thinking they were the lamps I tested them with a ccfl lamp tester and they are all working, at this point I think it is the main board which is a BN41-01172B, my question is, before making a further purchase there is a way to turn on the lamps without the main board to exclude that the new power board is also broken? Of course without...
                02-16-2022, 12:54 PM
              • alro7779
                Samsung UN55MU6103F video problem; has colored stripes on the display
                by alro7779
                Hello, everyone!
                A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                09-27-2025, 11:29 PM
                09-06-2024, 11:40 PM
