Sony SMD-HS73
  • torin3
    replied
    Re: Sony SMD-HS73
    Ok, I tried 4 known good CCFLs all at the same time.
    Same flashing behavior.
    Caps should arrive tomorrow.
  • torin3
    replied
    Re: Sony SMD-HS73
    Ok, I tried with 2 known good CCFL lamps at a time, and got the same behavior.
    I can't try 4 at a time just yet because the only monitor I have available for this has all 4 plugs close together and this monitor has them on opposite sides of the inverter board.
    I'll order the rest of the caps to make sure they are all replaced. Should get them in by Wednesday or Thursday.
    I'll be happy to try any other tests.
  • torin3
    replied
    Re: Sony SMD-HS73
    Originally posted by retiredcaps
    Of course, I didn't do the math the other way.
    There is a possibility that the 470uF cap is still bad. Right now, I'm out of ideas and have to head out soon.
    Wel, with the 470uF cap back in, it is working the way it was before.
    I'm going to try 2 lamps at a time from another monitor, but I don't think I can get all 4 to reach.
    I'll be putting together an order for all the other caps that haven't been replaced and see if that helps.
    Have a good evening.
  • retiredcaps
    replied
    Re: Sony SMD-HS73
    Originally posted by torin3
    Well, with the 680uf cap in, it doesn't light up at all. Power light is green, but the screen stays black. Putting the 470uf cap back in now.
  • torin3
    replied
    Re: Sony SMD-HS73
    For test only purposes, I would substitute the 680uF in. This reasoning could be totally WRONG, but
    470uF * 1.20 (+/-20%) = 564uF
    680uF * 0.8 (+/-20%) = 544uF
  • torin3
    replied
    Re: Sony SMD-HS73
    Originally posted by jetadm123
    What points on T1 and T2 did you check when you first took these readings?
    The points Retiredcaps circled. I realize they weren't exactly the same, but they were less than 30 ohms apart at about 1000 ohms.
    Edit: I'm also currently letting it warm up to see if I can adjust the brightness control.. Currently it isn't staying on long enough to access the menu.
  • alexanna
    replied
    Re: Sony SMD-HS73
    Don't forget
    it is entirely possible to have more than one bad ccfl, to rule that out you could hook up all the ccfls from your good monitor, The ribbon cable does not need to be hooked up just make sure it's well insulated, A video source is required
    Al.
  • retiredcaps
    replied
    Re: Sony SMD-HS73
    That would be normal. Usually the 5V output is regulated, the 12V output floats depending on the load on the 5V supply. I'd expect the 12V output to be very close to 12V if the inverter was on, higher otherwise.
    PlainBill
    That makes sense. Arrgh, missed this reply earlier. Darn, 9 inch netbook.
  • retiredcaps
    replied
    Re: Sony SMD-HS73
    Edit: Crud, I'm out of 470uf 25V caps. I have 680uf 25V caps. Too much of step up in capacitance?
  • jetadm123
    replied
    Re: Sony SMD-HS73
    I tried checking T1 and T2. I think they are ok. Secondaries are about 1K ohm. And I get identical restances for the two units.
    I also tried 1 lamp from another montior, in each of the sockets.
    Still no change in behavior.
  • torin3
    replied
    Re: Sony SMD-HS73
    Has this one been replaced as well?
    Not yet. I'll do it now.
  • torin3
    replied
    Re: Sony SMD-HS73
    May I suggest you try turning down the brightness to see if that affects the flickering at all.
    I'll give that a try.
    Take your soldering iron and touch up the solder joints for the inverter transformer pins.
    Did that before my first post about this monitor.
    Try measuring the secondaries. I believe what I circled in red and blue are the secondaries.
    Put your mulitmeter on 2000 ohms. You should have one reading for red and one for blue. Report both.
    Red 974
    Blue 1003
  • retiredcaps
    replied
    Re: Sony SMD-HS73
    Also there is a 470uf 25V cap on the logic board I can replace as well.
  • retiredcaps
    replied
    Re: Sony SMD-HS73
    R22 -470 - 47 ohms
    R23 - 195 - 560 ohms
    R24 - 202 - 664 ohms
    R25 - 1095 - 933 ohms
    R26 - 222 - 935 ohms
    R27 - 470 - 23.5 ohms
    R28 - 470 - 23.5 ohms
    R42 - 3907 (3902?) - 1265 ohms
    R44 - 272 - 2680 ohms
    R22 and R44 are definitely correct. The others readings are affected by other components in circuit. For now, let's assume they are all okay.
    D1 is 5.05V
    D12 is 13.81V
    Hmm, I'm still confused with the 13.81V and the 12V DC connector reading, but let's assume that is correct and move on. I thought it would be closer to 12V DC at the connector area. At the diode area, I can see it being 13.81V DC.
  • jetadm123
    replied
    Re: Sony SMD-HS73
    Looks like you have good output voltages from both your power board and logic board regs.
    I see your logic about replacing the smd caps on the logic board. If others have had problems with those caps, then it might be a good idea to replace them.
  • torin3
    replied
    Re: Sony SMD-HS73
    Everyone has different troubleshooting techniques, but this is what I would do.
    1) Have the upper 4 capacitors in your picture been replaced? I know you replaced some, but I can't tell from the picture if those 4 have been replaced?
    Yes, all 4 have been replaced. But after that photo was taken.
    2) In that same area, there are 2 inductors (marked with L on the PCB). They are covered in glue. You can remove the glue. With power off and LCD unplugged, the inductors should measure less than 1.0 ohms on your multimeter.
    Yes, both of them are less than 1.0 ohms.
    3) On the backside, there are 9 SMD resistors by the connector area. With power off and LCD unplugged, measure the resistance of each one. List the values and their measurements.
    I'm not quite sure about the values, some of them were hard to read. However, I do see that not all the ones marked 470 read the same. Also, I attached a closeup photo of that area.
    R22 -470 - 47 ohms
    4) There are two, I believe, Schottky diodes mounted on the heat sink. With power on, put your black probe on a ground screw and red probe on the middle pin. Report both readings.
    D1 is 5.05V
    D12 is 13.81V
    And thank you again for helping walk me through troubleshooting this.
  • PlainBill
    replied
    Re: Sony SMD-HS73
    The legend on CN1 in the photo is a bit obscured, but if it says 12V, then 13.82V is pretty high? Was this measured with all the boards (logic and ccfl) hooked up?
    I believe the 12V DC is for the inverter section.
    PlainBill
  • retiredcaps
    replied
    Re: Sony SMD-HS73
    And yes, almost 14V out of a 12V line seems like it would be out of spec to me too.
  • torin3
    replied
    Re: Sony SMD-HS73
    CN1 legend:
    +12V
    +12V
    GND
    GND
    +5V
    +5V
    GND
    N/C
    ON/OFF
    Dimming
    N/C
    And yes, almost 14V out of a 12V line seems like it would be out of spec to me too. But I'm not sure where to look for what might be affecting it.
    Yes, all boards and lights hooked up. VGA cable not plugged in though. I don't know if that will make a difference.
  • retiredcaps
    replied
    Re: Sony SMD-HS73
    12V = 13.82V
    5V = 5.05V
  • Carlos#2003%
    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
    by Carlos#2003%
    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
    02-15-2024, 07:52 PM
  • LINCKODE
    Sony Bravia KDL-37S5600 inverted color and flickering
    by LINCKODE
    Hello!
    I have a Sony Bravia(the specific model is in the title) that is exhibiting the following behaviors:
    - Color inversion on the whole screen(or rather it has trouble displaying gray and black correctly)
    - Static-like flickering on the dark parts of an image(it will flicker between black and white on some dark parts of an image)
    - Bad image detail/sharpness
    These issues switch between each other from time to time.
    After consulting some online resources and the LCD TV troubleshooting guide I found on this forum, I believe I am...
    12-14-2022, 08:34 AM
  • reessi
    ACER BM320 Monitor - Horizonal Flickering Lines After a While
    by reessi
    The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
    They are black on the right and gradually fade to nothing on the far left.
    They start either after 5 mins or up to 2 hours after so annoying for testing.
    They flicker continuously very fast! With a slight pause milli-second every second.
    Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
    I tested each half by removing the first the left flex from...
    06-03-2025, 09:58 AM
  • storexxm
    Sony 65AG9 Oled Flickering
    by storexxm
    https://youtu.be/lIy3wANcWKA
    Does anyone have an idea what can cause this "flickering" i ve never seen something like this before on an oled TV
    Hope someone can help me :-)
    08-16-2023, 08:55 AM
  • dkneyle
    Sony KDL-46HX850 Can't upgrade/update firmware
    by dkneyle
    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
    09-25-2024, 10:44 PM
