Samsung Syncmaster 932B
  • alexanna
    • Mar 2010
    • 1346
    #41
    Re: Samsung Syncmaster 932B
    The only thing I see mentioned is 14V.
    Do any of the pins on CN201 say analog?
    • waitery
      • Feb 2011
      • 69
      #42
      Retired, thanks you helped me out big time. I changed out the IC and it came back to life! Thank you for your help and insight!!!
      • retiredcaps
        • Apr 2010
        • 9271
        #43
        Wow, that was quick!! Did you get the IC from a local store?
        PS. I gave 3 possibilities to hedge my bets!
        edit: I would love to see a pic of the newly installed IC. Soldering in ICs isn't in my skill set (due to a cheap sort by lowest ebay price soldering iron).
        --- begin sig file ---
        --- end sig file ---
        • psspala
          • Oct 2011
          #44
          I have a problem in this model, the display is bright like white washed and no images when VGA cable is connected from CPU, on disconnecting the VGA cable from CPU or monitor the screen displays and menu and all and adjustments can done, menu function is ok on screen, when no VGA cable is connected no signal cable indicator is visible on on screen, I have replaced ic 101 (DMO465r) and capacitor c107 47uf 50v, still no same problem , visually capacitors looks ok. pls help .
            09-07-2024, 05:50 AM
          • soopacrucial
            by soopacrucial
            Hi folks,
            10-29-2024, 02:40 PM
          • unimatrix93
            Replacement transformer for Samsung fridge
            by unimatrix93
            Dear forum
            My Samsung fridge died from a fault on the mainline and the transformer (https://www.hqelektronika.hu/hu/halo...-w8-da2600009k) died.
            No voltage on the secondary, measuring resistance shows open circuit. I concluded a blown fuse which is deep inside the transformer, I don't think I can disassemble it to replace the fuse.
            The second problem is that I cannot find an original replacement part anywhere or even If I do it's pretty expensive.
            My question is: Can I replace this transformer with a generic 230V to 17V one? The output has 4...
            07-14-2025, 02:16 AM
            09-06-2024, 11:40 PM
