Samsung Syncmaster 932B
    Re: Samsung Syncmaster 932B
    The only thing I see mentioned is 14V.
    Do any of the pins on CN201 say analog?
      Retired, thanks you helped me out big time. I changed out the IC and it came back to life! Thank you for your help and insight!!!
        Wow, that was quick!! Did you get the IC from a local store?
        PS. I gave 3 possibilities to hedge my bets!
        edit: I would love to see a pic of the newly installed IC. Soldering in ICs isn't in my skill set (due to a cheap sort by lowest ebay price soldering iron).
        --- begin sig file ---
        --- end sig file ---
          I have a problem in this model, the display is bright like white washed and no images when VGA cable is connected from CPU, on disconnecting the VGA cable from CPU or monitor the screen displays and menu and all and adjustments can done, menu function is ok on screen, when no VGA cable is connected no signal cable indicator is visible on on screen, I have replaced ic 101 (DMO465r) and capacitor c107 47uf 50v, still no same problem , visually capacitors looks ok. pls help .
