Samsung Syncmaster 932B
  • Diablo_Rojo
    • 28
    Request help on a Samsung 932B. I received it as a non working unit. When I went to test it it worked, but then quit after about 5 minutes. I opened it up a discovered that one set of lamps flashes on for a fraction of a second while the other remains dark. I have a a pair of lamps(total 4 ccfl) that I then used to test with the same results no matter which lamps were plugged in , only one plug on the board would flash momentarily. I believe it may be a transformer problem but I am not sure. Thank you in advance. Sorry if photos are not great, help me get better.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Samsung Syncmaster 932B
    Interesting pictures. It's unusual to see a monitor with oval caps. :
    The symptoms indicate a defective inverter transformer or possibly bad solder joints. I've marked up the picture. Measure the resistance between the pins circled in red and between the pins circled in blue. It is not necessary to remove the transformer for this test.
    PlainBill
    • Diablo_Rojo
      • 28
      Thanks for the response PlainBill. I have read many of your posts on here and I think it is great of you to take so much of your time to share your extensive knowledge. I have re-soldered the transformer connections and measured the points indicated. I read open circuit on all points. I guess next time I will try to keep my picture ratio the same when I resize to avoid the funny oval caps
      • PlainBill
        • Feb 2009
        • 7034
        That does not make any sense. I seem to have omitted a vital bit of information. Set the DMM to the 2K ohms range. If all pins still read open, try the 20K range. If you cannot get a reading between the two pins circled in red or the two circled in blue on any range that would indicate the transformer is defective. They are available on eBay.
        PlainBill
        • Diablo_Rojo
          • 28
          OK,the plot sickens. I put the test lamps back on thinking there is no way either should work and now one set lights up and stays on. This may be what I experienced on my very first test after bringing it home when it came on for five minutes then went dead. At that time I was not able to set up a connection to see if the display seemed unusually dim. Is there something I can test now that we have it half working? Maybe I am completely confused about the transformer but don't the readings I got of open circuit with the dmm set to the lowest range(400 ohm) indicate that none of the lamps should come on?
          • PlainBill
            • Feb 2009
            • 7034
            That's the problem. The secondary of the transformers should measure about 1K ohm (in this case, about means somewhere between 700 ohms and 1500 ohms.)
            PlainBill
            • Wrog
              • Oct 2009
              • 472
              If I may interject, the OP may be doing the test incorrectly:
              What Plainbill means here is to read the resistance once across the two red pins, and once across the two blue pins and report the results. The instructions could be misinterpreted to mean measure across one of the red pins to one of the blue pins, etc.
              • Diablo_Rojo
                • 28
                OK, upon further review it has been determined that the resistance across one pair is about 1K and the other is open. I have ordered the transformer(about 10 days from China). I will post when I get it installed. Thanks for staying with me on this.
                • PlainBill
                  • Feb 2009
                  • 7034
                  Not a problem. This would be very boring (and dangerous!!!) if everyone knew exactly what I was thinking.
                  PlainBill
                  • Diablo_Rojo
                    • 28
                    Yet another big THANK YOU to PlainBill. I replaced the transformer and was rewarded with a beautiful bright display and one less monitor in the graveyard.
                    • hartpunch
                      • Jan 2011
                      • 6
                      I have a similar problem to Diablo Rojo, which, reading the posts, seems to be common. Monitor fine until last night, then on for 5-8 seconds then black - no back light, no display. Plugged Monitor into my old PC and problem follows monitor. Looking at the posts for help, I checked the transformer and got about 900 ohms across both the primary and secondary of the transformer mentioned in this post so it appears that's not the problem. There's nothing burned, nothing looks bad, I checked the caps on the board with an ohm meter and they act like caps - putting positive lead on pos side of cap and the resistance goes up, so the cap is charging. ALL caps act the same and none are bulging. I have seen reference to "bad inverter board" in other posts, I assume this power supply board is what they are talking about. I have not fired the board up with the case off, I will need to tack on a couple of wires and run them out the side so I can monitor the 5 VDC.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        1) "2" seconds to black can be caused by
                        a) bad caps
                        b) bad inverter transformer
                        c) bad ccfl
                        d) bad ccfl wiring
                        e) sense circuitry is damaged
                        2) Capacitors die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad. They can be out of tolerance uF (a 1000uF measures 20uF) and/or have high ESR (ohm). A multimeter will be insufficient to test for ESR. For that you need an ESR tester which costs between $50 and $300.
                        3) If your transformer readings are within 3% of each other, it suggest they are good.
                        4) That leaves the ccfl lamps or the wiring as the next thing to check. The easiest way to test the ccfl lamps is if you have a spare monitor that can act as a good ccfl. See post #14 section 5
                        https://www.badcaps.net/forum/showthread.php?t=10419
                        Note you don't actually have to remove the ccfl from the spare monitor for testing. Just stretch the cable from one monitor to another, but don't let the two touch.
                        --- begin sig file ---
                        --- end sig file ---
                        • hartpunch
                          • Jan 2011
                          • 6
                          Thanks for the feedback, VERY HELPFUL. It's coming down to time and money. The transformer looked like it was the most straight forward fix and that's $70 on eBay but that's not the problem. Who knows how much a back light would cost and finding, ordering and replacing a bunch of caps isn't the way I want to spend my weekend. I may suck it up and buy another monitor - maybe not Samsung this time. Any thoughts on reliability of other brands?
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            $70 is a total ripoff for the transformer. Depending on the model, some go for as low as $5 for TWO + free shipping.
                            It is up to you. If you decide not to fix it, recycle or sell it on your local kijiji/craigslist for parts.
                            • jetadm123
                              • 2169
                              Ouch! $70 for a transformer?! And there's no guarantee that replacing it will solve the problem. You can buy a fully functioning used monitor on Craigslist for that price (or less). If you buy new, then you might consider parting out the monitor and selling the individual parts (lcd panel, logic board, etc) through Ebay. This will help offset your cost of a monitor.
                              • hartpunch
                                • Jan 2011
                                • 6
                                jetadm123 -Great advice about parting out monitor - I was going to turn it in to E waste - turning it in to dollars is a MUCH better idea. Thanks !
                                • hartpunch
                                  • Jan 2011
                                  • 6
                                  Being a Lab Tech at heart, I couldn't give up on the troubleshooting. Reading other posts about the "flash light test" I did it and I have a picture, but the back light driver has gone South, I am thinking this because if a single BL went out, I would assume I would have a dim picture, ALL the back lights, I assume would mean the problem is in power supply itself, which is what all the posts point to. Thanks to all for the help, most educational.
                                  • jetadm123
                                    • 2169
                                    You have 4 CCFL tubes. It only takes one bad tube to activate the CCFL controller protection circuit, which shuts down the power to the backlight assembly and kills power to ALL tubes, not just the bad one. The question is: do you get a brief flash of light when you try powering on the screen? If yes, you could try substituting a known good CCFL tube one at a time to see if you can get the backlights to come and stay on. Also, check the wiring carefully for shorts.
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      Like jetadm123 says there have been cases here where the problem was just the ccfl wiring gone bad. See below for examples ...
                                      http://s807.photobucket.com/albums/y...klight%20lamp/
                                      • hartpunch
                                        • Jan 2011
                                        • 6
                                        The exact symptom was the monitor was in use pretty much every day for over 2 years. Then two nights ago, it went blank. No warning, no intermittent, just dark. Turning off the power and waiting, it comes on for about 5-8 seconds then back light goes dark. It does stay on a little longer, maybe 10 seconds when it's cold (off for more than an hour) and that goes down to 5 sec as it gets warmer, so sounds like a component problem or lamp
                                          09-07-2024, 05:50 AM
                                        • soopacrucial
                                          by soopacrucial
                                          Hi folks,
                                          10-29-2024, 02:40 PM
                                        • unimatrix93
                                          Replacement transformer for Samsung fridge
                                          by unimatrix93
                                          Dear forum
                                          My Samsung fridge died from a fault on the mainline and the transformer (https://www.hqelektronika.hu/hu/halo...-w8-da2600009k) died.
                                          No voltage on the secondary, measuring resistance shows open circuit. I concluded a blown fuse which is deep inside the transformer, I don't think I can disassemble it to replace the fuse.
                                          The second problem is that I cannot find an original replacement part anywhere or even If I do it's pretty expensive.
                                          My question is: Can I replace this transformer with a generic 230V to 17V one? The output has 4...
                                          07-14-2025, 02:16 AM
                                          09-06-2024, 11:40 PM
