Viewsonic VE710b
  • junktv
    • Nov 2010
    • 3065
    Re: Viewsonic VE710b
    The big cap is bouncing from 171-172 on my cheap $3 dmt7 digital meter.
    I'm guessing my black to the outer black here and try the rest with red won't fry nothing? Sorry haven't done alot electric work. May have to have a beer real quick to calm my jittery hands down too.
    • retiredcaps
      • Apr 2010
      • 9271
      #62
      171-172V DC is a bit high, but let's assume it is good for now.
      Set your multimeter now to 20V DC. Check the connectors on the power board now. Use a ground screw closest to the connector for your black/negative probe. Then measure each connector pin with the red probe and report its voltages.
      --- begin sig file ---
      --- end sig file ---
      • retiredcaps
        • Apr 2010
        • 9271
        #63
        PS. Use the manage attachment for your pictures. Also please gives us an updated version of your board versus the old board. Do not post pictures inline as they slow down the loading of pages.
        For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
        Here is an example of the pictures we want.
        https://www.badcaps.net/forum/showpo...94&postcount=1
        • retiredcaps
          • Apr 2010
          • 9271
          #64
          Getting a clear focused recent/updated picture is important so we can see if you installed the caps backwards or your solder work is poor (on backside). Either will cause the monitor not to get the secondary voltages (i.e. 5V DC).
          • junktv
            • Nov 2010
            • 3065
            Ok here they are.
            yellow = 12.03
            orange = 0
            blue = 2.19
            red = 3.39
            red = 3.39
            black = 0
            black = 0
            Charging camera batteries but will get pics ASAP.
            • retiredcaps
              • Apr 2010
              • 9271
              #66
              yellow = 12.03
              orange = 0
              blue = 2.19
              red = 3.39
              red = 3.39
              black = 0
              black = 0
              Hmm, I was expecting 5V, but 3.3V DC is a voltage normally found on the logic card (via voltage regulator).
              The blue could be correct if it is BL/ON?
              • retiredcaps
                • Apr 2010
                • 9271
                #67
                Found the service manual at (which will help tremendously)
                3.3V and 12.0V are the proper voltages. See page 34.
                On page 18, the troubleshooting flow chart says check Q3 for 2.5V.
                • junktv
                  • Nov 2010
                  • 3065
                  That is funny i was just going to post that.
                  Still waiting on batteries to charge but should be close.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #69
                    You just need enough battery power to take 5 pictures at most. Here in Canada, there is only 35 minutes of sun left. Sunset is 16:35.
                    • junktv
                      • Nov 2010
                      • 3065
                      It's been dark for hours here but this is about the best i can do with my cheap older than dirt cam (fuji a200).
                      Where would q3 be and proper test method?
                      Also i was unsure on the 4 monitor plugs so maybe i had that wrong?
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #71
                        Nice clear photos, but most of us would prefer 1 picture of the top and 1 of the bottom instead of the quadrants.
                        Where are the pictures of the logic board (1 top and 1 bottom).
                        We need to verify that the logic board is getting the right voltage.
                        • mockingbird
                          • Dec 2008
                          • 5484
                          #72
                          I see a few small caps on the powerboard that have a plus vent. Are those Nichicons or did you not replace them?
                          • junktv
                            • Nov 2010
                            • 3065
                            Here ya go.
                            On the pics sorry about that but if it's not realy close then they turn out blury.
                            Mockingbird, i didn't replace them.
                            • junktv
                              • Nov 2010
                              • 3065
                              Any other suggestions? The plug i checked earlier are the one that runs to the logic board.
                              Not sure that is the right manual either. I'm still not finding anything labeled q3.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #75
                                Page 21. Q3 is a SMD transistor MMBT3906. So look for that.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #76
                                  Also page 37 show Q3 on the MCU/button schematic.
                                  • junktv
                                    • Nov 2010
                                    • 3065
                                    There is only 5 buttons, connector and a LED on the button board in mine.
                                    • alexanna
                                      • Mar 2010
                                      • 1346
                                      #78
                                      Ok here they are.
                                      yellow = 12.03
                                      orange = 0
                                      blue = 2.19
                                      red = 3.39
                                      red = 3.39
                                      black = 0
                                      black = 0
                                      Try measuring your voltages at the connector on the logic board as you try to power the monitor on, there is a possibility you could read a good voltage when no load is applied, but the voltage could momentarily go low when more load is required .It looks you will have to do this four times. I am thinking the 12v might go low.
                                      Al.
                                      • junktv
                                        • Nov 2010
                                        • 3065
                                        Getting different readings in the orange and blue with the other board plugged in.
                                        12.03
                                        .71
                                        .11
                                        3.38
                                        3.38
                                        0
                                        3.33
                                        0
                                        I hit the power button but didn't have the panel on as i wouldn't be able to get to the boards then.
                                        • alexanna
                                          • Mar 2010
                                          • 1346
                                          #80
                                          I would suggest re checking all the capacitors for poor soldering rock them back and forth look for movement at the solder pads.
                                          On the front panel switch, I would expect to see one of the pins go from a high voltage to close to 0 volts as the power button is pushed.
                                          If the manual that listed in the link retiredcaps provided is any close to being correct .there is a reset switch involved. It is listed as being U8 and is pin is connected to pin 7 of MTV312.
                                          I do not feel comfortable telling you how to test it, but maybe someone else may have some ideas.
                                          Al.
                                          • lostone
                                            Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                            by lostone
                                            Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                            First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                            When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                            05-19-2024, 11:40 AM
                                          • StefanNg
                                            Viewsonic VX2718-PC-mhd SG2701B01-8
                                            by StefanNg
                                            Hi, Badcaps.
                                            I am troubleshooting a monitor
                                            Viewsonic VX2718-PC-mhd.
                                            Panel model SG2701BSG2701-8
                                            Symptoms is no image.
                                            This panel has 2 panel board connected by a U-ribbon.
                                            When I disconnected the ribbon, I get a perfect half screen image.
                                            I took some test point voltage, when ribbon disconnected.
                                            HVAA 8.38v
                                            FVDD12 1.21v
                                            FDD33 3.3v
                                            VIN 11.79v
                                            VAA 16.85v
                                            VGHF 30.16v
                                            VGL -8.02v
                                            CK1_I ~ CK8_I 1.403v
                                            CK1_L ~ CK8_L 8.26v
                                            When I connect both panel board
                                            HVAA, VGHF, and CKx_L...
                                            05-17-2025, 01:43 AM
                                          • Fagauthier
                                            Viewsonic power supply model #EADP-64BF B Need circuit diagram…
                                            by Fagauthier
                                            I have à defective Viewsonic monitor. I can't find a circuit diagram for it' power supply.
                                            Model #EADP-64BF B
                                            The user manual have all diagram except for the power supply. I would appreciate help to find the circuit diagram, thanks...
                                            07-08-2023, 08:02 PM
                                          • Returning Buick
                                            Viewsonic G810 vertical deflection problem
                                            by Returning Buick
                                            I have a G810 monitor i've had for years but it has developed a problem with vertical collapse. Is there anybody here who has worked on these and can help me find where the circuit even is for the vertical deflection?
                                            04-01-2025, 07:57 PM
                                          • RetroComputingGrotto
                                            Viewsonic VA2010wb (High Pitch Squeal At Power On)
                                            by RetroComputingGrotto
                                            I've got a monitor on my workbench at the moment that makes a high pitch squeal (that I cant hear as my ears are too old) when you power it on and lasts a couple of seconds before quitening and apparently it can be heard at regular intervals whilst on.
                                            On opening up the monitor and looking at the PCB the usual suspects showed their heads so I have already replaced all the electrolytic capacitors.
                                            The other issue that was reported with this monitor was the fact it took ages to start displaying anything after pressing the power button.
                                            What component(s)...
                                            02-03-2025, 06:00 AM
