Asus PA279Q wake from sleep and power issue
  • sugarfoot
    • Oct 2023
    Hi, my display no longer wakes from sleep. Half the time it won't power on at all. It also occasionally flashes black, white, red, blue, green and says "press menu and shortcut 2 to disable burn in".
    It's a great monitor, I hate to give it up without a fight.
    Are there any service manuals for this display? How do I disassemble it and see if there are any blown caps? Thanks.
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
  • bajdik
    Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
    by bajdik
    I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
    Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
    I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
    Unfortunately, I don’t have access to the schematic.
    It seems to me that when I bend the board, something changes.
    Could this...
    08-13-2025, 07:26 AM
  • MakNCheese
    ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
    by MakNCheese
    I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
    Symptoms:
    • Severe lag across the system, including BIOS navigation.
    • Slow boot times and unresponsive performance in Windows.
    • Battery charges very slowly (e.g., ~5% in 2–3 hours).
    • No error messages or BSODs, just extreme sluggishness.
    What I've Tried:
    • Replaced
    06-04-2025, 12:48 AM
  • mkdj
    ASUS X571 no power : battery issue?
    by mkdj
    Mark and model: ASUS X571
    Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
    Tests already made:
    - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
    - I have removed...
    07-14-2025, 09:16 AM
  • Christian0734
    Power Issue with ASUS A705UA.
    by Christian0734
    Hello
    The PC starts and shuts down correctly when the battery is removed. However, if I hot-plug the battery, it starts charging as if everything is normal. However, when I turn off the computer and then restart it, there is no display on the screen. The battery indicator blinks slowly, the fan runs, and the power consumption is approximately 520 mA, as if the computer is in standby mode. At this point, even if I disconnect the power supply, the computer doesn't start up normally anymore. Pressing the power button to force a shutdown works, but as soon as I release the button, the...
    09-13-2023, 03:04 PM
