ACER AL1713m no power
+ More Options
Posts
  • Rtech
    • Jul 2010
    • 1095
    Re: ACER AL1713m no power
    Fun with Dick and Jane !!!!!Adult movie.............lol
    • Welchs101
      • Sep 2008
      • 979
      Ok. I am now finally getting around to ordering the U850 device which is marked on the package as "SG6841S".
      I think this is manufactured by fairchild but not 100% sure. I went to this web site and fairchild no longer manufactures this product. But i am not sure what to replace it with.
      If you look on ebay you can find the "SG6841SZ" device but not "SG6841S".......what i am wondering is if the "SG6841SZ" device is an equivalent replacement. I thought i could get this info from the fairchild site but i am a little confused from its site because of the "not recommended for new designs" comment on the fairchild site.
      Could someone help me ?
      • newbie1
        • Apr 2010
        • 269
        if you look on page 2 of the SG6841 datasheet they are compatible.. SG6841SZ is the lead-free version of SG6841.. I have just used it to replace my faulty SG6841S..
        • Welchs101
          • Sep 2008
          • 979
          thanks newbie1.
          so the SG6841SZ is a valid replacement. thanks.
          One question, i tried to download the pdf you mentioned in your post.....i had issues downloading it. do you have the actual pdf file?
          thanks again.
          • newbie1
            • Apr 2010
            • 269
            Originally posted by Welchs101
            thanks newbie1.
            thanks again.
            here you go.
            • Welchs101
              • Sep 2008
              • 979
              thanks! I am going to try and place the order today or tomorrow.
              • Welchs101
                • Sep 2008
                • 979
                Part SG6841SZ finally came in. I ordered it off ebay from someone in HongKong ......took a while but i am in no rush.
                I removed the old part and put in the new SG6841SZ and BAM! Monitor came back to life.
                So you were right.......the SG6841SZ was the bad part.
                Question: Regarding the 10ohm resistor.
                I think i should replace this resistor......dont you guys?
                I have two resistors currently in my possesion that i bought years ago a radio shack for some reason or the other.
                Type1: 10-ohm Metal Oxide resistor 1 watt 5% tolerance
                Type2: 10-ohm resistor 1/2 watt 5% tolerance
                Which one of these should i use....or should i not even use one of these?
                Thanks again......
                • newbie1
                  • Apr 2010
                  • 269
                  #28
                  congrats on the job well done..
                  mine is still dead after replacing the IC..
                  As for the resistor, frankly i am not too sure.. maybe the experts here can advise you..
                  • Welchs101
                    • Sep 2008
                    • 979
                    Newbie, what are the symptoms of your monitor?
                    I also had to replace the following capacitors:
                    C867:1000UF/16v => replaced with 1000uF/25V
                    C862: 1000uf/25v => replaced with 1000uF/25V
                    C865: 470Uf/25v => replaced with 470uF/25V
                    C22 and C6: 220uF/25V => replaced with 220uF/35V
                    also the resistor R852 may need to be replaced.
                    • newbie1
                      • Apr 2010
                      • 269
                      #30
                      Well, we share the same symptom & same IC problem (initially) but mine is of different monitor. To cut the long story short, now my HP f1905 is 'dead' likely to be caused by logic card (suspected EEPROM corrupted). Its ok. I keep moving on.. Anyway, I learnt & experienced a great deal from the FANTASTIC guys here, even though the monitor was not revived..
                      • Welchs101
                        • Sep 2008
                        • 979
                        In post #27 i posted a question about a 10ohm resistor........can someone take a look at it and let me know what they think?
                        thanks. hope you all had a nice thanksgiving.
                        • PlainBill
                          • Feb 2009
                          • 7034
                          R1 is supposed to be a 10 ohm, .25 watt resistor. In this application it shouldn't make any difference if it reads slightly high, but just to stop you from bugging us, use the 1/2 watt resistor.
                          PlainBill
                          • Welchs101
                            • Sep 2008
                            • 979
                            thanks!
                            • tahir anjum
                              • Dec 2014
                              • pakistan
                              #34
                              is there any equivalent for SG6841SZ..coz i can not find it in pakistan. thanks
                                09-06-2024, 05:27 AM
                                Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                09-07-2024, 05:00 AM
                                Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-07-2024, 04:10 AM
                                Acer Swift SF314-511-511S + Pack Gold Acer 14'' Notebook 3 Specification for Upgrade or Repair
                                This specification for the Acer Swift SF314-511-511S + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF314-511-511S + Pack Gold Acer 14'' boardview and SF314-511-511S + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                09-07-2024, 03:10 AM
