My Viewsonic VX924 monitor died!
  • alexanna
    replied
    Re: My Viewsonic VX924 monitor died!
    Originally posted by Perineum View Post
    So what should my next step be?
    I'm afraid that my soldering is much much better than my troubleshooting skills.
    Should I be checking ESR on the replacement caps?
    Post some in focus photos of your power supply front and back,using managed attachments.
    The blinking PLED could be caused by voltages coming and going, Maybe from an overload on the power supply causing it to start and stop.
    Are there any voltages listed at the connector from the power supply to the logic board.
    If they are printed on the board what are they and are they steady?
  • Perineum
    replied
  • Perineum
    replied
    The (C21) location I put a 35v 330uF Rubycon MHE
    The cap near the 6 pin connector is another 35v 330uF Rubycon MHE
    Beside the largest cap I placed a nichicon 10uF 50v VZ(M)
    Ok, swapped out the 35v 330uF Rubycons for ZL's of the same values.
    Then swapped the 50v 10uF Nichicon for a UCC KY of the same.
    All caps report correct capacitance according to my Fluke 12, but I have no idea if the ESR is off (No ESR meter here)
    The monitor's symptoms are slightly different now. The picture is there, but the backlight comes on.....
    "grey to dull, suddenly bright, then off, then repeating about 4 seconds later" - according to the girlfriend.
  • PlainBill
    replied
    All except the big (100 uF, 450 volt) one. OK, technically it is, but it does not have to be a low ESR cap,
    PlainBill
  • Perineum
    replied
    Okay, I found https://www.badcaps.net/forum/showthread.php?t=2280
    The nichicons and Rubycons I used aren't on that list.
    I suppose that is my issue? Which caps are part of the SMPS circuit?
  • Perineum
    replied
    I replaced the 400v 100uF with a nichicon PT(M)
    The (2) 25v 470uF caps by the MBR10100CT are UCC KZE
    Lastly, the cap near the 6 pin connector is another 35v 330uF Rubycon MHE
    The values should all be fine or overkill now except I may have messed up and not used low ESR caps where I needed to....
    Also, I went through the board and hopefully (maybe I missed a few?) touched up all the pins to make sure there wasn't a cold solder joint.
    Thank you for your help
  • pedro
    replied
    I have recapped the entire PSU and now the monitor turns on, but only for a second.
    It turns on, then turns off about once a second, repeating. The MBR10100 tested fine when I pulled it out.
    What brand/series of caps did you use in the recap?
    I have not touched the logic board yet but that is where I was about to head to.... I've read 3 or more threads on this monitor and I'm still not sure what the blinking green power LED means....
    Usually a power LED blinking about once a second is symptomatic of the SMPS attempting to start, failing, and repeating this pattern. Typical causes are faulty (or inappropriate) caps, faulty rectifiers, short on an output rail, etc.
    As a first step, address the cap replacement questions - what you used, and whether you replaced ALL the electros (other than the biggie). Don't bother with the video board yet, until the PSU is cleared of suspicion.
  • Perineum
    replied
  • jetadm123
    replied
    Originally posted by jfr1326 View Post
    Thanks PlainBill and Jetadm123. The transistors and poly caps arrived with the usual exorbitant postal costs from DigiKey. They are now soldered in and ........a lovely bright, colourful monitor. Thanks guys.
    Congrats on the repair! Yeah, I'm grateful that I have access to digikey with low cost shipping.
  • jfr1326
    replied
    Originally posted by retiredcaps View Post
    What country do you live in? Shipping for USA customers is around $2.75 USD.
    I live in the UK. Shipping for DigiKey, Mouser, RS etc etc.. are all a fixed minimum of 12GBP. If I knew of anybody shipping at a reasonable rate, I would buy from them.
  • retiredcaps
    replied
  • jfr1326
    replied
    Originally posted by PlainBill View Post
    Bingo!!! A bad poly cap will cause the transistors to fail.
    If I recall correctly, the Belinea 101910 service manual is available, and is an exact match for this monitor.
    PlainBill
  • PlainBill
    replied
    Vielen Dank.
    PlainBill
  • Scenic
    replied
    http://bambooz.pytalhost.net/badcaps...nea_101910.rar
  • jfr1326
    replied
    Originally posted by jetadm123 View Post
    If it's the orange cap, then it's a poly cap. Replace both as these have been known to fail.
    Hopefully, this makes sense. The "154" is capacitor code for:
    15 is the cap value followed by the multiplier (in this case 4 zeros) and the value is in pf. Therefore, we have:
    150,000pf = 150nf = .15uf
    J is the tolerance: +/- 5% and +/- 10%
    250=250 Volts
    Thanks Jetadm123. I have ordered caps and tr's from Digikey. I'll let you know how it goes when they arrive.
  • PlainBill
    replied
    Sorry about the missing 'v' PlainBill. I've got a sticking v key on my laptop. I have found something that looks suspicious; the capacitor C24 is not an electrolytic but it looks bulged to me. It has the markings H154JH 250MPP1. Any ideas what this is? If this had blown, would it have caused the shorting of the two tr's? I have not managed to find a circuit diagram for this board, so I'm groping in the dark a bit.
    PlainBill
  • jetadm123
    replied
    250=250 Volts
  • jfr1326
    replied
    A denture? No, but it will be an adventure. There are several possible causes for the shorted transistors. Check all points for bad solder joints, resolder the transformers, check all diodes, etc.
    I have one of these but all replacement transistors short as soon as power is turned on. The transformer passes a ring test, no diodes are shorted. I haven't been able to identify the cause YET, but it's on my 'to do' list.
    PlainBill
  • jfr1326
    replied
    The transistors marked "DK" are 2SC4672 manufactured by Rohm and are readily available at digikey.com. Also, remember to replace them in pairs.
    Thanks a lot Jetadm123. I'll go buy them.
  • PlainBill
    replied
    My vx924 has the normal flashing led symtoms and I've followed this thread with interest until I reached the above. I then found two of the four transistors marked DKQR have shorted causing the smps to keep dropping out. Any ideas what these transistors are and where to get them? Why will this be an adenture?
    PlainBill
