AOC E2275PWJ dead
  • Slang
    • Oct 2006
    • 49
    AOC E2275PWJ dead
    Hi
    i have 4 of these monitors dead. No sign of life when i press the switch on button.
    I think there is a problem with the PSU design.
    Anyway, i suspect a sot23-6 chip but i cant find its specs.
    on this chip i can read:
    fist row:
    73108a
    second row:
    . 559 (dot is the orientation mark).
    Anyone can help me to identify this chip?
    Thank you in advance
    Slang
  • R_J
    • Jun 2012
    • 9566
    Re: AOC E2275PWJ dead
    It is likely a OB2273MP High Performance Current Mode PWM Controller
    • alkuentrus
      • Aug 2012
      • 28
      • Portugal
      Originally posted by Slang
      Hi
      fist row:
      73108a
      second row:
      Slang
      Have you been able to fix them?
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • double_DD
        How can I be sure that my EC chip is dead?
        by double_DD
        As the title suggests, how can I be sure that my EC chip is really dead?
        I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
        Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
        03-12-2025, 07:47 AM
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        08-04-2025, 12:20 PM
        Common SPI bios chip programming Questions and Answers
        by SMDFlea
        Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
        A: If you can`t read from it how do you expect to write to it ?.
        Q: Why is my bios chip unreadable ?.
        A: The programmer is faulty or has a worn or broken zif socket.
        The USB cable is frayed,connector pins worn or some other physical damage.
        Not enough amperage or voltage to power the programmer properly.
        Bad...
        09-02-2021, 04:40 PM
      • zunasthegreat
        Dead corsair VS450 with blown TNY chip (cwt)
        by zunasthegreat
        I have this Corsair VS450 PSU which lies dead and has an exploded TNY chip. Upon removing primary side parts like mosfets, the bulk cap and the bridge rectifier I've found that the primary cap is also a goner. (Photos)
        The mosfets and the diode are fine and survived the collapse it seems. The TNY chip is shattered and from the online review/sources it was probably a TNY176~177....
        08-30-2025, 03:11 AM
