Compaq FP7317 no power - caps?
  • Cerberus
    • 9
    This morning my monitor would not power on - have been noticing some "ripple" in the screen quality recently. Opened up the back and see at least 4 caps bulging or burst. I'm assuming that will cause the no power situation if they are located by the transformer?
    The 4 suspect caps are all Elite 1000uf 16v with ES(M)105C and (C)0408 listed on the other side. What is a good replacement number from Digikey that I can order?
    I did a cap replacement on a Sceptre monitor successfully, so I know I can do the work if this is the problem...
    Thanks in advance!
    Mark
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Compaq FP7317 no power - caps?
    If you have 4 bad caps, then it would be a reasonable assumption that you could have more bad caps even if the others show no visible sign of distress.
    So replace them all other than the big filter cap. If you follow PlainBill's instructions here, you can get Panasonic FM caps
    https://www.badcaps.net/forum/showpo...33&postcount=2
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      Different vendors use different designs, but the 1000uF 16V could be providing the 5V power which is required by the logic card to power on the monitor.
      If you see 25V caps on the board, they are likley providing power to the inverter section of the board (likely 12V or 19V depending on the design).
      • Cerberus
        • 9
        Thanks for the quick reply! Order already in with Digikey.
        • retiredcaps
          • Apr 2010
          • 9271
          Let us know if the new caps work or not. If you are in the USA, you should get the caps in the next 24 to 48 hours.
          BTW, I heard somewhere that Digikey does around 1 Billion in revenue/year. Amazing, that they can sell 6 caps to individuals for a company that size.
          • PlainBill
            • Feb 2009
            • 7034
            There are a couple of factors on this. Digikey is located in Thief River Falls, MN, population 8410. And it's not a suburb, it's the 'big city' of the area.
            I've been doing business with them for over 30 years, and their shipping charges have dropped significantly recently. I suspect this is due to a highly automated order filling system.
            PlainBill
            • Cerberus
              • 9
              Caps in and replaced. Power is back! Thanks for the assist.
              Mark
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
                by momaka
                03-15-2023, 10:17 PM
              • bcstedt
                LG 42LB5D, 42LB5DF-UL, 2008-01, Power On Issue, Replaced PS Caps
                by bcstedt
                LG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
                Problem:
                On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
                It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)...
                01-18-2024, 01:03 PM
              • captain150
                by captain150
                03-16-2025, 07:34 PM
