LCD Backlights Driver - Unknown Component
  • Spongebob89
    • Mar 2021
    • 24
    • England
    I have an "LCD Backlights Driver" and it is not working. After measurments and checking the routes of the PCB I beleive that this component on the red circle is a choke for filtering the supply voltage and block noise from the inverter to go back to the main board. When I measured in ohm and in diode mode with multemeter shows always OL. I shortcircuit this component and it worked. The current that I measured with multemeter is 550mA, so I want rated current 1,5x550mA=825mA~1Α. Am I right that this is a choke and if yes what value do you beleive is (maybe 15uH or the 15 on the component is just an SMD marking code?)?
    Do you know in which category I have to find it?
    https://gr.mouser.com/c/?q=choke
    Chips Datasheets:
    TL5001
    https://cdn.badcaps-static.com/pdfs/...b2ebb7089e.pdf
    LA6339
  • lotas
    • Jan 2016
    • 4656
    • Russia
    Re: LCD Backlights Driver - Unknown Component
    It's actually a 1.5A fuse.
    https://www.amazon.sa/-/en/Fuse-100p.../dp/B09FJT4JFF
    • petehall347
      • Jan 2015
      • 4427
      • United Kingdom
      some have 2 amp fuse https://www.alibaba.com/product-deta...471564681.html
      • Spongebob89
        • Mar 2021
        • 24
        • England
        Thanks all of you for your replies. This type of fuse consider slow, or Medium, or Fast blow?
        Fusing characteristics: Within 1s
        https://gr.mouser.com/c/circuit-prot...16%20metric%29
        I found this below. The broken was 1.5A/75V/1sec@250%of Ampere Rating and the replacement I found is 1.5A/125V/5sec@200%of Ampere Rating. Do you beleive the difference in the time will not safe?
        https://gr.mouser.com/ProductDetail/...nbZDuW6Q%3D%3D
        • osrex
          LED DRIVER KEEPS DYING
          by osrex
          Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
          i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
          i have no datasheet at all for the LED lights, all i have is its length.
          long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
          as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
          05-05-2025, 03:36 PM
        • howardc64
          Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
          by howardc64
          Problem
          Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
          Model & Board Pics
          Conflicting Spec
          Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
          https://www.shopjimmy.com/vizio-gj-2k1...
          10-10-2024, 01:16 PM
        • charif
          Audio Driver for Thomson P14C4BK128
          by charif
          Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
          I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
          The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
          Here are the details:
          • Model: Thomson P14C4BK128
          • Operating System: Windows 10 64-bit
          If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
          Thanks in advance for your help!
          04-30-2025, 05:41 PM
        • bohaboha
          how to install gl usb2.0 uvc camera device driver on windows 10
          by bohaboha
          Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
          but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
          any help?
          01-26-2025, 08:33 PM
        • max789
          Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
          by max789
          Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
          I made the following tests:
          1. Disconnected the main board from Power Board = backlight works.
          2. Connected the main board and disconnected the T-Con = backlights does not work.
          So I ordered a main board from Ebay also BN41-02156A but from...
          01-18-2024, 06:56 AM
