Dell P992 19" CRT Issues
  • Sleddriver
    • Sep 2010
    • 32
    Hello! First post here.
    I've owned this monitor 9 or so years and it's performed well till recently. When cold, the display would oscillate in tilted-ovals quite rapidly when first lit, then gradually slow down as it warmed up. It would finally stabilize so I could read it after ~ 10 min. Then it began doing it after 'waking up'.
    Another symptom was that it would defocus for awhile, sometimes focusing again. Sometimes not.
    It would also tilt green at times intermittenly.
    I replaced the Dell with another monitor to check the video card and it looked fine, so I suspect it's the Dell monitor.
    I removed the case, discharged the tube and had a look around. I noticed where the HV cable had been arcing (due to dust) on the 'cage', so I dusted everything with compressed air.
    This monitor is a Sony Trinitron 19CRV chassis, equivalent to a CPD-G410R, I think. Man date is Nov. 2001. So far I've seen no bulging caps. I plan on hooking the o'scope to the power rails to check for ripple.
    Anyone had any similiar experiences/symptoms with a Dell-Sony like this before?
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Dell P992 19" CRT Issues
    Are your sure the degaussing coil isn't staying on? That can cause the display to distort but it's only supposed to fire on power up.
    The current flowing through the coil also flows through the NTC thermistor heating it up as it's temperature rises so does it's resistance until the current draw from the coil is very small (not zero but certainly not enough to effect the CRTs deflection).
    The NTC acts as a temperature controlled variable resistor limiting the current to the coil. Most of these are inside a little plastic case about the size of a fusible link on a car. Inside this case these devices have two thin wires welded to a metal disc if one of these cracks it can cause the coil to come on and off at any time. I have seen some NTCs without this case but most of them have cases.
    If the CRT is defocusing check the focus wire from the flyback it should be soldered to the neck board it's a bit smaller than the anode lead. If the solder isn't cracked remove the neck board and check the socket for any signs of arcing.
    If there are no signs of problems on the outside I'd power the monitor up and lightly tap the flyback near the focus pot with something insulated like a screwdriver to see if there is an intermittent connection on the resistive divider.
    • Sleddriver
      • Sep 2010
      • 32
      At present, I'm not sure about anything. Haven't really dug into it yet. Though I have read of many problems with these monitors on Dell's site. I'm surprised mine has lasted as long as it has.
      When it's acting up, it's as though all the desktop icons are doing tight 'back-flips'! They start out really fast, the gradually slow down and stop as it heats up. Very, very weird. I've seen a whole screen roll before, but this rolls in a small, tight loop. Now it will never calm down or stop. So the monitor is no longer usable.
      Clearly something is oscillating. . . .
      Thanks for the reply. I'll cut out some time and investigate further.
      • 133MHz
        • Jul 2006
        I've fixed this one in the past, it's caused by a dried up electrolytic capacitor. I can't remember the exact details, but it's right in front of the fins of a big heatsink near one of the corners of the main board.
        The heat dissipated by the heatsink slowly destroys the capacitor over the monitor's lifetime creating the thermal failure that you're experiencing. When I fixed this problem on my sister's P992, I moved the cap away from the heat source by extending its leads with a few inches of wire. That should prevent the problem from happening again in the future.
        Unfortunately the monitor has now developed the infamous excessive brightness problem. Other than lowering the G2 voltage either through software or by increasing the value of a resistor, nobody seems to know the cause.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          It's best to do it thru the WINDAS software, the resistor method makes the monitor unable to perform automatic calibration ("color return"). I believe that the brightness problem is caused by this very function. Every time you run it, it tends to bump the G2 a little bit.
          A working TV? How boring!
          • Sleddriver
            • Sep 2010
            • 32
            Thanks for the replies! I've been searching for an isolation transformer to protect myself & my o'scope. I found the Sony schematic and printed it out on 11 x 17 sheets. Much easier to read that way.
            133Mhz, I too experienced excessive brightness problem. Then I'd hear a loud ZAP and it would be normal. I found the HV wire was arching to the alum. cage. Also cleaning out the dust and black dirt on the back of the crt helped with this.
            I too suspect a bad cap. Will check all power rails for AC ripple with the o'scope.
            • keepread
              Dell monitor PSU vs Dell laptop PSU
              by keepread
              Hi there!
              Someone gave me their old monitor, it's Dell S2715ht.
              The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
              Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
              10-30-2025, 04:45 PM
            • Borse2008
              by Borse2008
              • There’s
              07-15-2025, 04:55 AM
            • Jesus Coder
              Issues Reviving Old Dell 2408WFPb Monitor
              by Jesus Coder
              I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
              06-25-2023, 02:33 PM
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • DanPoka
              by DanPoka
              02-15-2025, 05:05 AM
