Mitsibushi V51LCD Monitor Screen Tinted Red
  • stauffercaps
    • Sep 2010
    • 18
    I have a V51LCD monitor that turns on and works but the screen show the content but with a heavy RED tint. It can not be adjusted out using the OSD controls. Interesting enough the Menu/OSD shows up normally without the red tint.
    Any ideas what could be causing this? Will post some pictures when I get home.
  • stauffercaps
    • Sep 2010
    • 18
    Re: Mitsibushi V51LCD Monitor Screen Tinted Red
    Oh shoot, just realized that I posted this under the wrong section. Sorry!
    I tried to see if I could move it or delete it but didn't see where I could.
    • retiredcaps
      • Apr 2010
      • 9271
      A red/pinkish hue/tint means one or more of the ccfls are dying.
      --- begin sig file ---
      --- end sig file ---
      • stauffercaps
        • Sep 2010
        • 18
        Are inexpensive replacement CCFL's likely to be found? What supplier would you suggest?
        Thanks for your response retiredcaps!
        • crtfool
          • Jun 2010
          • 82
          Then, wouldn't the menu and onscreen display also be tinted red?
          • Dgtech
            E. Technician
            • Apr 2009
            • 1462
            • Steeler
            Exactly CRTfool. I seen this in a different post before and I think it had something to do with a reset on firmware if I'm not mistaken. I have to search for it now, thanks for the work. lol
            • stauffercaps
              • Sep 2010
              • 18
              Pictures of the insides, sorry in advance. (pics from an iPhone)
              • retiredcaps
                • Apr 2010
                • 9271
                I agree with your reasoning and I could be have dreaming, but I thought I saw a case here in the forum where the most of the screen showed a red tint, but due to the small size of the OSD, it wasn't affected.
                It turned out to be the ccfl in that case.
                Again, I could be dreaming or mixing up the cases.
                • Dgtech
                  E. Technician
                  • Apr 2009
                  • 1462
                  • Steeler
                  I knew I had seen this somewhere. This post here ( https://www.badcaps.net/forum/showth...osd#post105307 ) is the one where I had seen that a reset cleared up a reddish screen problem.
                  • stauffercaps
                    • Sep 2010
                    • 18
                    Awesome, Any idea how to access the service menu to do a factory reset? I can access the regular OSD fine, can I get to it from there? Thanks.
                    • Wrog
                      • Oct 2009
                      • 472
                      Page 8.
                      • stauffercaps
                        • Sep 2010
                        • 18
                        Ok, so I performed the factory reset from within the OSD. You could see the screen change from the pronounced red to a yellowish tint. After picking up the LCD to move it from the desk I noticed that when I moved the end of the VGA cable the screen would tint blue, then yellow, green, and normal. I swapped the cable and and monitor looks like back to normal.
                        I never noticed the cable causing the screen to move to a red tint.... It was just always tinted red. Not really sure if the factory reset was an issue or just a faulty VGA cable all along. Either way, thanks to everyone for the suggestions and help!!!
                        • Wrog
                          • Oct 2009
                          • 472
                          Occam's Razor!
                          Glad you got it sorted out (and congrats on the easy fix)!
                          • stauffercaps
                            • Sep 2010
                            • 18
                            Originally posted by Wrog
                            Occam's Razor!
                            I was not familiar with that phrase so I google'd it....
                            Occam's Razor: The principle is popularly interpreted as "the simplest explanation is usually the correct one".
                            I like it!
                            Thanks again everyone!
                            • turmix
                              AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                              by turmix
                              Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                              The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                              At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                              During another reassembly, I made a mistake, and...
                              01-29-2024, 03:48 AM
                            • Ryan.man
                              by Ryan.man
                              02-04-2025, 12:23 PM
                              by momaka
                              03-15-2023, 10:17 PM
                            • abajor
                              A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
                              by abajor
                              Having this very weird issue.
                              The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
                              I swapped with a working screen from an A2141 waiting for parts.
                              The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
                              The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
                              04-27-2024, 01:37 PM
                            • 3D Modelka
                              AOC 27 monitor Q27G2WG4 doesn't display logo or image on screen
                              by 3D Modelka
                              Hello. I have a problem with my AOC 27 monitor, specifically model Q27G2WG4, which I have been using for 3 years. The monitor stopped turning on: when I turn it on, the backlight turns on, the indicator starts glowing white, but the logo on the screen does not appear, and there is no image. However, if I check in the Windows system, the monitor is displayed as connected and working. I tried connecting it via HDMI and DP, but the result remains the same. If I turn the monitor on and off multiple times, it will eventually start and work. However, when the monitor is working, there are no issues....
                              02-09-2024, 02:42 AM
