Re: 900G power supply? Won't turn on (obvious blown caps)
"Do try to stay on track."
ME stay on track?
This thread is about helping geocrasher find replacement caps.
If you want to ramble on expressing you MISGUIDED ideas and theories about how caps work go open your own thread.
And more AARRGGHH!!
It ISN'T the same volts. See below or revisit post#16.
And then in post#20 you stated:
Care to point out where?
I'm not sure whether you are being deliberately obtuse, argumentative for the hell of it, or just plain don't follow. I believe everyone is worth some effort to enlighten them, so here goes. I'll give it this one last go to explain why you're mistaken. Please try to keep up - I'll go through it slowly.
The ripple (AC) output of a switcher is a CURRENT SOURCE. The ripple current is directly related to the DC load current. So in a working piece of equipment (e.g. monitor) where the DC load is established, the ripple current is substantially constant.
The low-ESR filter caps are designed to shunt the overwhelming majority of that ripple current. As I explained in post#16, as the ESR rises with deterioration of the cap(s), the current through the cap(s) doesn't reduce by anything like the same proportion, and the I²R losses in the cap(s) rise. Refer again to the sample numbers in that earlier post#16 to understand why.
If you are having trouble understanding this, I suspect you are beyond comprehending something that is fairly basic.Leave a comment:
It moves the dissipation from the cap [where you want it] to the load [where you don't want it].
1 - It reduces it -in the cap- installed.
2 - If you increase ESR it's not -THAT- cap anymore, you changed the cap.
2 - As I said, a cap with higher ESR will have less ripple current going through it.
Less current through cap, same volts, less watts. -> less heat.
It's called Ohms Law.
Please review it.
Yes, you did.
.Last edited by PCBONEZ; 09-21-2010, 09:14 AM.Leave a comment:
You were carrying on about increasing ESR lowering the dissipation in a cap.
I'm not sure why you're confused.
Perhaps it's your English comprehension.
The Ripple that doesn't go through the cap goes through the IC [load].
Less through the cap -> more through the load.
Not sure why you can't comprehend that. It's simple.
Psst - Ripple is AC.
ESR doesn't affect the DC.
DC is irrelevant to a discussion about Ripple.
ESR doesn't 'care' if the DC is 5v or 500v.
.Leave a comment:
.Last edited by PCBONEZ; 09-21-2010, 01:06 AM.Leave a comment:
- Good Plan!
Let me know if it even boots with 200 mA Ripple on your CPU.Leave a comment:
Sorry, I ain't gonna let that pass without comment.
The switcher output will have two components - the (wanted ) DC and the unavoidable AC.
The amount that gets "re-routed" away from the cap will depend on, for want of a better term, the ... (AC-coupled) ESR of the load. The cap is what provides by far the greatest contribution to the overall shunt impedance at switcher frequency - that's its role. Quadrupling the cap's ESR will not halve the current through it - do the simple maths. Say - for the sake of simplicity - 1 A of ripple with a cap of 0.1 ohm and a load with an (AC) impedance of 10 ohms at switcher freq. Then approximately 99% of the ripple current passes through the cap, I²R dissipation ~100mW.
Double the cap's ESR to 0.2 ohms - now about 98% of the ripple current is shunted by the cap. Dissipation? I²R now a tad short of 200mW.
At 99% going through the cap you have 1% going through the processor.
So you'd double the ESR.
At 98% going through the cap you now have 2% going through the processor.
Twice as much Ripple going through the Processor.
- Good Plan!
.Leave a comment:
Like for instance, a Processor.Leave a comment:
When you raise ESR the total Ripple current created at the switchers doesn't change but what isn't going through the cap to ground is now going through the load to ground.
Raising ESR reroutes Ripple to the load.
That amount of Ripple Current that gets redirected to the load isn't heating the cap by I²R anymore,
it's heating the load by I²R instead.
You could also do this experimentally by sticking say a pair of 0.1 ohm resistors in series with a known good (measured) low-ESR cap. Stick a DVM across one and monitor the (obviously AC) voltage as you apply a short across the other one. You may be surprised.
Anyway, if you don't believe me that's your choice, but it won't change my view.Leave a comment:
You don't want a working monitor?
The load - the logic card, the LCD panel, and the inverter draw whatever power they need to operate as long as the ESR of the filter caps is low enough to keep the ripple down to satisfactory levels. It doesn't matter if the ESR of the caps is right at the critical point, or if the caps are perfect - let's say 1/10 of the critical level; the load is going to be drawing the same current. However, caps at the critical level are going to be dissipating more power than perfect caps.
Now, I wouldn't expect to see a major savings on your electric bill, but I would expect to see the monitor running at a lower temperature.
PlainBillLeave a comment:
What you originally thought was correct.
Nothing changes the creation of the ripple quantitatively but the cap is NOT the load.
-> The cap is in parallel with the load.
In the meantime, the total power dissipation in the system decreases with a lower ESR capacitor.
I originally thought that way too, but it seems to generally not be the case in switcher filters. You have an AC source (the ripple component on top of the DC) which is effectively a current source - directly related to the DC current component from the upstream switcher or whatever - so the ripple current doesn't drop off materially as the ESR rises.
.Last edited by PCBONEZ; 09-20-2010, 10:10 AM.Leave a comment:
But:
Typically caps with a higher ESR rating will have a lower Ripple current rating too.
The Ripple current rating is how much Ripple current the cap can pass through without over heating internally. [Basically it's based on I²R.]
When choosing replacement caps you want:
- The same or lower ESR.
- The same or higher Ripple Current rating.
- The same or higher voltage rating.
- The same uF.
Some people play around with uF values.
It's a rare case where it's not easy to get caps with the same uF.
If you MUST change uF then it's better to go up one standard value because uF goes down as caps age.
.Leave a comment:
And as the ESR increases, so does the heating of the cap from I2R due to the ripple current. The heating accelerates the ageing (drying out) of electros and soon you have either a failed cap or a failed component in the affected circuitry. So while too low an ESR *can* in some cases create a problem, too high an ESR is fairly sure to.
As the ESR increases less Ripple current passes through the cap making the I in I²R smaller and since I [or I²] is usually bigger than R, I would expect the total of I²R to go down.
But:
You can check.
The Ripple current rating is given in the same data sheet as the ESR.
- The same uF.
.Last edited by PCBONEZ; 09-20-2010, 06:44 AM.Leave a comment:
ESR (equivalent series resistance) is basically the 'resistance' of a capacitor TO AC, that is not attributable to capacitance (uF). [As in it is not Xc.]
The Low ESR cap's job is to pass the noise left over from from the transistor switching action in the SMPS to ground. [noise = ripple in this case.]
A small ESR [small resistance] to 100 kHz will 'short' the 100 kHz noise to ground thereby removing it from the DC power sent from the supply.Leave a comment:
Use 105C caps. [Temp rating.]Leave a comment:
The values of both Xc and ESR are frequency dependent.
The Frequencies of Ripple encountered due to SMPS action are right around 100 kHz.
[Probably most have Ripple between 25kHz and 200kHz. Data sheets for Low ESR caps are standardized to 100 kHz.]
At 100 kHz the ESR has a large affect on the caps 'resistance' to AC and Xc has almost none.
That said:
It is best to stay as close to the original ESR as possible as generally there are inductors as part of the 'filter' that includes the cap.
The Inductor and Capacitor's values [uH of the inductor and ESR of the cap ] are chosen so they work together to get the best filtering.
If you go wild and jump from like .050 ohms ESR to .015 ohms ESR you may de-tune the filter and end up with more noise instead of less.
It's never good to go to a higher ESR because that will remove less ripple even without being de-tuned.
FC are a good all around cap for working with monitors [typical grade of the originals] but occasionally there will be an original crap cap with better ratings than FC.
That's why -if possible[**]- always check the specs on the old caps before choosing replacements.
If not possible then fail-safe to FM.
[**] Some crap brands simply don't have data sheets available.
.Last edited by PCBONEZ; 09-18-2010, 09:46 PM.Leave a comment:
I suggest Panansonic FM or FC caps. FM have better specs and are about the same price if you purchase through digikey.com. You can order the cap using the steps below:
Here's the best way to order from digikey:
1) Go to digikey.com
2) In the "parts search" window type: panasonic fm and select "GO" button
3) Under the Capacitor heading select "Aluminum"
4) The first two columns you see are capacitance and voltage. Highlight the value and voltage with your mouse and select the "Apply Filters" button
5) You'll see several selections available. Here's what to look for:
a) Look at the quantity available and minimum purchase. If "0" are available, then there's none to purchase. Some selections require a minumum purchase of a 1000 units, which you also don't want. I think you get the picture.
b) height and diameter. Measure the original caps and compare to what's listed.
6) If your value is out of stock, go back to the beginning and type in "panasonic fc" and go through the same process.
7) During the checkout process select USPS First Class shipping, since this will give the best ship rate.Leave a comment:
Hi Guys, thank you! I'm in the US. Reno, NV to be specific.Leave a comment:
Assuming...7 Photos -
by eryjusHello,
Channel: General Capacitor Questions & Issues
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by cheeky2This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... - Loading...
