Benq FP92E Capacitor specs Help!!
+ More Options
Posts
  • riverrat_67
    • Sep 2010
    Have a Benq FP92E (Q9CS) inverter board 4H.L2T02.A00 that is missing c703, c704, c707, c708. Wondering if anyone knows what uF and Volts these need to be....Thanks..
  • pedro
    • 199
    • AUSTRALIA
    Re: Benq FP92E Capacitor specs Help!!
    If they weren't ever fitted - and inspection on the solder side should tell you - then you don't need them, end of story.
    Sometimes the same board is used in different products with a different "build".
    And sometimes it is as simple as the board layout not being changed after the manufacturers discovered those extra bits allowed for by the designer aren't actually required. It's called the beancounter effect. "If it ain't needed, leave it out." and also "why change the board layout just because we are leaving bits OUT?".
    Friends don't let friends buy Samsung ....
    • riverrat_67
      • Sep 2010
      No there not empty slot you can still see the solder left over on the back of the board and holes..
      I found a schematic for a FP71e (i think that was the model) where a lot of the circuit components match up. Go buy that it looks like c703 and c704 are 470uf 35v and c707 and c708 are 1000uf 16v..
      Going to give it a try tonight or tomorrow morning i'll post the results. Whats the worst that could happen it's not working right now...Thanks
      • jetadm123
        • 2169
        Looks like they used the same values for a BenQ FP91G. For the FP91G,
        C703-4 filter the voltage fed to the inverter cicuit. C707-8 provides filtering for the 5V.
        • Bilbao
          • Nov 2010
          HI,
          I have a board 4H L2T02.A03 from a Benq T721 who don't work. On my board C708 and C707 are 1000uF 16V, C703 and C704 are 470uF 35V.
          I want to replace the board. Do you know where i can find it ?
          Merci !
          • retiredcaps
            • Apr 2010
            • 9271
            Originally posted by Bilbao
            HI,
            My standard description on how to post pictures ...
            1) Post clear focused pictures of your particular boards AFTER reading
            https://www.badcaps.net/forum/showthread.php?t=1868
            2) Please do not post pictures inline as they slow down the loading of pages.
            3) For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
            4) Here is an example of the pictures we want.
            https://www.badcaps.net/forum/showpo...94&postcount=1
            5) Also, start a new thread with the pictures requested since you have a different monitor so we don't get confused.
            --- begin sig file ---
            --- end sig file ---
            • MdMaxx
              • Jan 2011
              Please, can someone tell, what type is IC601 on that board? It have been blow off because C605 have leak and start the damage of other components.
              If you have the same board on hand, please can you send the type of ic direct to mail: md.maxx@kolumbus.fi too.
              p.s sorry my bad english, im from Finland
              Also i'm interesting if you know or have working ic or know where to buy it.
              • Gabriel
                • Jan 2010
                • 620
                • Norway
                I have a similar board and and ic601 is a 1203p60 8 pin dip.
                • hifihifi
                  • May 2011
                  • 18
                  Monitor Benq Q7C5 with same "4H L2T02.A03" works fine but after a few minutes (not seconds) momnitor goes off.
                  You can put it back on and then after a little again switches off.
                  Tested 8 big capacitors (2x 1000uF/16V 2x 470uF and 2x 1000uF/10V), soldering it out and measured ESR and capacitance, both are ok.
                  Hard to find without schema.
                  Anybody idea's or schema?
                    Acer Aspire ES1-732-C708 Notebook ES Specification for Upgrade or Repair
                    This specification for the Acer Aspire ES1-732-C708 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ES1-732-C708 boardview and ES1-732-C708 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    09-06-2024, 09:40 AM
                    Acer TravelMate B117-M-C703 Notebook B Specification for Upgrade or Repair
                    This specification for the Acer TravelMate B117-M-C703 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the B117-M-C703 boardview and B117-M-C703 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    09-06-2024, 05:59 AM
                  • seppde
                    Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                    by seppde
                    I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                    ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                    The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                    In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                    02-09-2024, 05:19 AM
                  • AJ847.63e
                    BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                    by AJ847.63e
                    Hi All.
                    Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                    The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                    09-18-2023, 06:42 PM
                  • ChatBTC
                    Benq EX3501R
                    by ChatBTC
                    Hi!
                    I am new to this site, and found it via LLM ChatGPT.
                    I got a BenQ Ex3501R monitor which i have had for a while now, it works pretty good until recently, it struggles to turn on, i can see the purple welcome screen is shown for a brief time before it vanish again, usually it stays on for a couple of seconds before the main computer screen is shown, but image is still kept black, before i just had to turn it off and on a few times and that would leave it on, but now it takes ever longer to stabilize the image on the screen, ocasionally i can see the computer desktop...
                    01-24-2025, 08:49 PM
