I cant find my Parts!!!
  • delamoss
    • Sep 2010
    i have a 42" plasma monitor model # px-42vp1a and i cant find capacitors or even a power supply board for it can anyone assist me in this?! it would be well appreciated!
  • Chriso
    • Jul 2010
    • 30
    Re: I cant find my Parts!!!
    Here's the manual
    Power supply
    • Gentian
      Please help me find 7 pin smd ic 901 part number in Delta DPS-300AB-76 LED Display Power Supply
      by Gentian
      I have a 5V 55A led Delta power supply with no output. I found this 7 pin IC 901 damaged as in the photo. All other elements look ok. I checked and every other surrounding componets diodes, resistors and capacitors look ok. I have 2 identical power supplies removed from a led wall which have the same defect with this ic burned but not a working one for reference. I founded by measurements that pin 7 goes to positive hot 450V 220uF electrolytic capacitor primary side. Pin 1, 2, 3, 4 connected together to pcb cooper trace. These four pins goes to negative side of 10uF 50V electrolytic capacitor...
      09-27-2025, 11:03 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • shamsudeen
      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
      by shamsudeen
      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
      i know that in linear power supply the noise will be very low comparing to SMPS supply....
      07-19-2025, 07:14 AM
    • temyth
      Sentey ATX PSU - ERP650-PS - Trying to find out the right Standby IC
      by temyth
      Greetings! I have this ERP650-PS atx power supply, it is a relatively simple psu, the primary has a driver IC that controls the two main mosfets (two 20n60S5), together with a Classic Standby circuit with a PWM IC (not a FET like the VIper22A) , relatively similar to the SDC606P.
      The whole point is that I got this power supply years ago when I had no knowledge, apparently the PWM IC was burned because someone turned the power supply on with the switch at 110v in a 220v network (classic error). Important detail: the power supply at the time came without the primary capacitors.
      01-07-2024, 04:50 PM
    • lostone
      Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
      by lostone
      Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
      First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
      When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
      05-19-2024, 11:40 AM
