viewsonic VX724 help needed
+ More Options
Posts
  • cnkay
    • Sep 2010
    Well hello 1st post on this forum but sure seems like the place to be!
    Have a VX724 display died power light blinking. Once every 5secs or so very quick picture flicks on but would not say lite. So I opened unit and found three caps bad. 470uF (2) were like 19uF and one 330uF was 8uF. Replaced those. no dice same symptoms found two burned up transistors on back side. I believe that I found an older post with correct Rohm transistor numbers so I ordered them (.74 each) and tried it again. As soon as I plugged it in and started to lift screen from the workbench the same transistors on backside were smoking. Don't have the numbers I order handy but I remember they were marked DK. I think they were 50V 3A NPN.
    Does anyone have the schematics for this unit?? Could you help me with the correct transistor number??
    Could I have a broke or shorted bulb or something else that would take out these transistors? Looks like two identical circuits and nothing else jumping out at me. Trying to compare one side to the other.
    I do remember if I powered unit up with only two of the four CN1-4 wires plugged in that I did get a picture just not that bright. I am guessing that there are two or four bulbs inside.
    Any help would be most welcome, as I am currently unemployed and could use losing this monitor like a cracked tooth. CoL
    Thanks MUCH
    Chris
  • Solder Boy
    • Nov 2006
    • 178
    Re: viewsonic VX724 help needed
    A photo of the board would be helpful.. top and bottom shot. Something is causing the transistors to short out.
    If you do a search of this forum you will see that just replacing the obvious bad capacitors often isn't good enough.
    Sounds like you have a capacitance meter, check all of the rest of the caps..if you have an ESR meter you need to check the caps for those readings.
    Other veteran repairers will chime in I'm sure..
    www.bcrelectronics.ca
    • PlainBill
      • Feb 2009
      • 7034
      Thanks MUCH
      Chris
      Try the Belinea 101910 service manual. It's available at www.elektrotanya.com.
      The inverter uses a Royer oscillator, the same design used in the infamous Benq monitors sold under the Dell and HP labels. And it's subject to the same failures.
      The one most often mentioned - the solder joints on the transformer legs crack. Remove the old solder and replace. Referring to the Belinea schematic, the tuning caps C24, C25 (0.15uF 160V) are critical. Make sure the solder joints on them are good. The Schottky diodes D9, D10 (2A 40V) have also been mentioned as culprits.
      PlainBill
      • dasjeetu
        • Jul 2010
        • 5
        Hi!
        Happy to help. Please find it in
        Please download....
        Thanks.
        Jeetu
        • karatzdi
          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
          by karatzdi
          I know some might say... just buy another one. Sell it as parts..!
          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
          Spent some time downloading the Service...
          06-11-2024, 08:38 AM
        • lostone
          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
          by lostone
          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
          05-19-2024, 11:40 AM
        • Francesc V.
          Onkyo A8200 - Not the right voltages in some transistors
          by Francesc V.
          Hi:
          I am trying to repair this amplifier that I've bought as faulty. I've found some transistors damaged, the ones where I am drawing a red circle.
          With the final transistors not yet installed (the expensive ones), I've started to measure some voltages:
          Where I am supposed to have 1.12V (base Q524/Q523) I am reading -42V..................both channels don't seem ok.
          Where I am supposed to have -1.12V (base Q526/Q525) I am reading -44V..................both channels don't seem ok.
          I removed and tested Q514,Q516 & Q513,Q515 but the analyzer...
          04-19-2025, 07:17 AM
        • redbaron1007
          Sundown SFB-8000D What are these transistors?
          by redbaron1007
          I had a Sundown SFB-8000D amp come into the shop yesterday that wasn't giving any output. The guy who brought it in said he bought it off some crack head on Facebook marketplace for a good price, but bought it knowing it was broken. Apparently the original owner was cutting out the transistors to the right of the ones pictured whenever one would blow and take the output out. Best I can figure he also cut the legs on the S5 and S6 ic's as well and soldered them back together.
          My problem is Sundown decided in the factory to remove the original markings on the IC's and now I can't figure...
          11-12-2023, 07:30 PM
        • Bob Wong
          MSI Crosshair 15 A11UEK. Need help with Transistors!!!
          by Bob Wong
          Welcome badcaps, repairing a Crosshair 15, in need of transistor specifics. Received a broken laptop that's was perfect for repair, threw away the looser transistors in a haste... Should and could have salvaged them.
          In any case, I will be posting all my discoveries to this forum as a thanks in advance. Thanks in advance lol.
          P.S. If anyone is familiar with such things, as in, If anyone knows that MSI uses one or one of a few types of transistors when marked with a number please let me know how I can find more specifics before I start throwing hail marys.
          03-15-2025, 02:02 PM
