Acer AL1916
  • Borgleader
    • Sep 2010
    • 8
    Acer AL1916
    after reading a blog post I dug out my Acer AL1916 from my closet in hopes of possibly fixing it. The reason I had stopped using it in the first place is that one morning when I got up I tried to turn it on and neither the power LED or the screen itself would light up.
    So like I said I dug it out plugged it in and no surprise here, nothing happened. Now I've already checked the capacitors and I believe all of them are in order, I didn't see any bulging near the top for those that had slits and for those that didn't I couldn't see any obvious bulging either.
    Aside from that I have no clue. I am completely oblivious to anything electronic/electric which is why I came here (the bad capacitor suggestion was made by someone on another, more software oriented, forum).
    http://www.mediafire.com/?v2a385jl9e05m
    Here I uploaded pictures of the circuit boards inside the monitor. Also, I'm not sure if this can be of any help:
    It's an Acer Service Guide for this model (I assumed it was the right one, there are multiple variants of the AL1916 model but this particular guide was the only one to have pictures of the circuit board that matched mine).
    P.S: This is probably not important but if I connect the monitor to my laptop's VGA port, the laptop's display flickers to a different resolution.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Acer AL1916
    Order replacements for the Elite.
    If they aren't shot yet they will be soon enough.
    Next check for a blown fuse on the yellowish PCB.
    Mann-Made Global Warming.
    - Dr Seuss
    • Borgleader
      • Sep 2010
      • 8
      Re: Acer AL1916
      I used the search function inside the service guide with "fuse" and it came up next to "F901", and if I look at the yellow board F901 is a little red box with 3 pins. I was expecting some sort of tube shaped component with one pin on each end.
      Aside from that none of the components actually look damaged.
      • Rtech
        • Jul 2010
        • 1095
        Re: Acer AL1916
        '3' Pins ?????,should just have '2' !!!
        If that is ok,then measure DC Volts acoss the big Brown capacitor,that should be 1.4 times your mains voltage, dependant on what country you are in ??.BEWARE Mains Voltage can be dangerous, so be VERY careful.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Re: Acer AL1916
          F901 should only have two pins. [look at schematic]
          Probably looks like a resistor.
          - Dr Seuss
          • sabre504
            • May 2010
            • 449
            • United Kingdom
            Re: Acer AL1916
            Hi which model of 1916 is this (widescreen or standard)
            Only that i may have the correct pdf
            • Borgleader
              • Sep 2010
              • 8
              Re: Acer AL1916
              http://www.gbaudio.co.uk/data/mains.htm
              Canada: 120V @60Hz
              Voltage across the biggest of the capacitors is ~165V.
              It seems I was incorrect, when I looked at it last night the lighting was dim, so today I un-screwed the yellow board and flipped it over it only has 2 pins. Also, the markings on the box read "T2A" and "392". And it looks in good shape.
              http://www.mediafire.com/imgbnc.php/...1abf703c6g.jpg
              http://www.mediafire.com/imgbnc.php/...9c06cb206g.jpg
              http://www.mediafire.com/imgbnc.php/...b6c9b00d6g.jpg
              My model is AL1916AB, ration 4:3. I've taken a picture of the back sticker with P/N and all in case you need to know anything else. Like I said in the OP, out of the 4 service guides on the Acer website (e,p,v,W) the only one where the green circuit board was the same was the v (which I linked to).
              http://www.mediafire.com/imgbnc.php/...8b72360c6g.jpg
              • smason
                • 1652
                Re: Acer AL1916
                Looks in good shape, but did you measure it?
                Looking isn't going to eb enough. You'll need to measure, or replace caps, and measure fuses and voltages to fix the problem.
                • Borgleader
                  • Sep 2010
                  • 8
                  Re: Acer AL1916
                  As weird as it may be, the continuity test on my multimeter doesn't "beep", instead when I connect the two probes the value goes from 1. to ~0.
                  Since the fuse (red box) is soldered so close to the board, I can't test the two pins from the top, so I unscrewed the board again and put one probe on each of the two pins/metal patches on the bottom of the board and I got the same ~0.
                  This means it's good right?
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    Re: Acer AL1916
                    The threshold for continuity varies with multimeters. Some beep "good" if the resistance is less than 1.5k ohm.
                    A good fuse should read less than 1.0 ohms depending on the multimeter.
                    Since you measure 165V DC across the main filter capacitor that implies the main fuse is good.
                    The next step is to measure the secondary voltages between the logic board and power board. Use a ground screw for ground. You should see 5V DC and maybe 12V or 19V DC depending on the monitor.
                    If you don't, then post clear focused pictures of the backside. On the backside, there will likely be a 8 pin or 10 pin IC. We will need its part number.
                    BTW, pictures should be posted using the following method here.
                    https://www.badcaps.net/forum/showthread.php?t=1868
                    Please do not post pictures inline as they slow down the loading of pages.
                    --- begin sig file ---
                    --- end sig file ---
                    • Borgleader
                      • Sep 2010
                      • 8
                      Re: Acer AL1916
                      (I had originally uploaded my pictures to mediafire to save bandwidth to the server, but since the guidelines suggest using attachments with a max width of 700px i resized it and attached it)
                      Ok so on this picture, the cables going off to the bottom right come from the yellow circuit board. I put the black probe on the ground screw under them (from this angle) and the red probe in a few of the sockets at the end of the cables.
                      I got readings of ~4.47V DC (for brown cable), and ~4.92V (for yellow & green cables). The others I couldn't get a reading, the metal part is just too far in.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Re: Acer AL1916
                        Look at page 32 of the PDF file in your first post.
                        It tells you to measure U701 and U702 for 3.3V. You should also be seeing 12V DC on pin 5 and 6 at CN701.
                        Your pictures of the power board at the offload site have too much glare for me to see the PCB designations. We want a picture that looks like this
                        https://www.badcaps.net/forum/attach...7&d=1280167246
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          Re: Acer AL1916
                          BTW, on page 45 of the PDF, it shows F902, a fuse.
                          If this F902 is open (you need to verify with a multimeter), then you will not get 12V DC.
                          Note the fuse might be on the backside of the board if it is not on the front.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            Re: Acer AL1916
                            If the fuse F902 is less than 1.0 ohms, then test diode D921.
                            Check the diode "in circuit" first. If the readings are suspicious, then you will have to remove it and retest.
                            If it is a dual diode, it should have two diode symbols pointing at each other towards the middle pin (pin 2).
                            Put your multimeter on 2000 ohms (if manual range) scale. With power off and lcd unplugged.
                            1) put red on pin 1, black on pin 2. report ohms.
                            2) put red on pin 3, black on pin 2. report ohms.
                            3) put red on pin 1, black on pin 3. report ohms.
                            Now switch to diode mode setting on your multimeter. With power off and lcd unplugged.
                            1) put red on pin 1, black on pin 2. report volts.
                            2) put black on pin 1, red on pin 2. report volts.
                            3) put red on pin 3, black on pin 2. report volts.
                            4) put black on pin 3, red on pin 2. report volts.
                            If the diode tests good, then I suggest measuring the voltage (power on) on pin 2 on the diode (put black on a ground screw). You should get 12V DC.
                            If you are not getting 12V DC, then either one of or all C923, C931, C925 (see schematic) is bad (as per PCBONEZ back in post #2). Even though they show no visible sign of distress, they can have high ESR (ohm) or be out of uF tolerance.
                            • Borgleader
                              • Sep 2010
                              • 8
                              Re: Acer AL1916
                              I've added a new picture (in attachment) of the green circuit board. At U701 (top left), there isn't actually a component. It's been observed in another thread in this forum: https://www.badcaps.net/forum/showthread.php?t=8257
                              Even though there wasn't a component in U701, I checked the 3 spots where would've been soldered the pins had they been there (just in case it's helpful) and I also checked the 3 pins for U702. For each of these I used the top screw as my ground.
                              U701: Top pin: ~0V | Mid pin: ~0V | Bottom pin: ~4.92V
                              U702: Top pin: ~4.65V | Mid pin: ~3.3V | Bottom pin: ~0V
                              (Since top/bottom is relative, U701 is top left corner, Blue VGA port is bottom right)
                              As for CN701, pin 5 doesn't have a cable in it so I didn't manage to get a reading, but pin 6 had a reading of ~14.5V DC.
                              The fuse is indeed on the backside, and again like F901, in the continuity test I got ~0 which is the silent equivalent of "beep".
                              F902 is ~0.3 ohms (I used a scale of 200, didn't have 20).
                              D921 (ohm scale 20k, 2k was not enough):
                              1) put red on pin 1, black on pin 2: 3.96k
                              2) put red on pin 3, black on pin 2: 3.92k
                              3) put red on pin 1, black on pin 3: 0k
                              D921 (diode test):
                              1) put red on pin 1, black on pin 2: 0.232
                              2) put black on pin 1, red on pin 2: 1. (the manual says to reverse the leads if i get this, which ends up being 1) )
                              3) put red on pin 3, black on pin 2: 0.231
                              4) put black on pin 3, red on pin 2: 1.
                              Sorry for the delay, I have to pretty much google everything because I've never had to do this before.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                Re: Acer AL1916
                                Hmm, that voltage looks a bit high. It should be 12V DC.
                                D921 (diode test):
                                F902 and D921 test good.
                                Let's try measuring the voltage on D921 pin 2 (middle pin). Put your black probe on the ground screw in the top left. Red on pin 2. Report the DC V measurement.
                                Hmm, I will have to think about this. You are getting 5V DC and 14.5V DC, but there is no power LED.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  Re: Acer AL1916
                                  I just started reading the other thread it looks like 14.5V DC ish is correct. So nix the measurement on the D921.
                                  edit: okay, you may want to read about U406 as per PlainBill's posts.
                                  • Borgleader
                                    • Sep 2010
                                    • 8
                                    Re: Acer AL1916
                                    Sorry for the delay, just got back to Uni and haven't got used to my schedule yet.
                                    Ok so I Ctrl+F U406, and I took the same measurements that PlainBill asked for in the other thread, and I got the same results, that is:
                                    Left pin: 0.00V
                                    Middle pin: 4.92V
                                    Right pin: 4.30V
                                    And so I proceeded with his test (unlike the other poster I chose the battery version). And I got:
                                    Top pin: 0.4V & 0.01V (We werent able to repeat the 0.04V however, so it could be a fluke)
                                    Right pin: 0.05V
                                    I cant deduce anything from his post however since he assumed that the top pin would have 3V on it, although the fact that it doesnt may mean the part is bad, or maybe the soldering gave out?
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      Re: Acer AL1916
                                      Right pin: 0.05V
                                      I suggest retesting this again. Please try to use the same terminology as in PlainBill's post so it makes it easier for us to track and read.
                                      If you are not getting 3V on the upper pin, that means something is wrong.
                                      • jetadm123
                                        • 2169
                                        Re: Acer AL1916
                                        Left pin: 0.00V
                                        Middle pin: 4.92V
                                        Right pin: 4.30V
                                        Right pin: 0.05V
                                        If you read the entire thread, the second test suggests shorting the bottom 2 pins with a small screwdriver, while hitting the power button. This sets the reset pin to zero (ground). Some people actually removed U406 altogether (I don't recommend this). Read the entire thread and decide for yourself.
