Onkyo TX-8050 AV-Receiver no sound
  • ai.need.help
    • Dec 2022
    • 4
    I have a problem with my Onkyo TX-8050 Receiver. I got it from aftermarket and it was just delivered today.
    It doesn't play music. There is no real output from:
    pre-out
    amp-out A and B
    phones out
    The only real sound I hear is a humming from the speakers when I play a song from usb or select a analog source. And when stopping and starting songs from usb or switching sources, I hear a crack from the speakers.
    I tested with analog-input, usb and radio.
    I know that there is a common problem with the dsp with certain onkyo devices, but I don't think it has the corresponding symptoms. I have both of the menu points "network configuration" and "firmware update", usb devices are loading and the relais for amp group A and B are working (clicking when turning one group on or off).
    The previous owner says it worked and I trust him. It maybe was a damage during the delivery even tho it was protected very well in the package. But where can the problem be? Can you help me?
    Thank you very much!
  • petehall347
    • Jan 2015
    • 4439
    • United Kingdom
    Re: Onkyo TX-8050 AV-Receiver no sound
    first thing is check circuit boards for cracks ..most likely near to larger components .
    • ai.need.help
      • Dec 2022
      • 4
      Okay i will check that.
      • budwich
        • Jul 2015
        • 3097
        what troubleshooting tools do you have? scope? DDM? test signal? You might try inputting a 1khz signal (computer file, cd or otherwise) and see / look for it at a few places along the signal path. Also check supply voltages at some "labelled" points on some boards depending on access under power.
        What display are you seeing on the front panel? Maybe post a picture of the display to ensure what you are seeing, is what the forum will see.
        • ai.need.help
          • Dec 2022
          • 4
          I have a DMM and a 30$ DIY scope, but i think it would be not as helpful.
          I traced the problem down to a voltage regulator, but I'm not sure if it's the source of the problem.
          Here is a service manual for my receiver. If you want to follow please download.
          On page 10 (SCHMATIC DIAGRAM - 5 - POWER AMPLIFIER SECTION) in sector 7E, you can see the voltage regulator 78M15A from jrc (named Q911) and another regulator 79M15A (Q912). I got the data sheet for the Q911:
          It gets 22 volts and should output +15 volts. But i measured 40mV on pin-out and it gets really fast really hot, around 96° Celcius (205F) measured with my temperature sensor from my dmm.
          Power comes from the rectifier D922 (model S1NB60) which I assume is OK because both regulators Q911 and Q912 get the required voltage for operating.
          The other voltage regulator Q912 for outputting -15v works fine.
          I'm not a pro in reading circuits but i believe these voltage regulators should deliver their output to the AUDIO INPUT SECTION on Page 9. The big chip in the middle gets +15 and -15 volts. I also measured a +15v trace going there and there is also the 40mV on it.
          So I am assuming the chip doesnt get power and therefore not outputting any audio to the amp-section, is this right? Is my problem fixed when I replace the faulty regulator? Or can there be another problem in front of the regulator?
          btw. I checked the fuses and they are OK
          sorry for my bad english, I'm not a native speaker
          • petehall347
            • Jan 2015
            • 4439
            • United Kingdom
            its most likely shorted after the regulator . disconnect whatever it powers and see if regulator works then
            • budwich
              • Jul 2015
              • 3097
              looks like you are on the right track. It is rather "suspicious" that this type of fault happened with shipping.
              As suggested, check to see if something "downstream" from the regulator is shorting the output. The quick check would be to unpower (disconnect main power) the unit and then do an impedance check (to ground) of the output pin in question. It should read some "reasonable" resistance. Go from the result.
              • Sushi1808
                Onkyo TX-NR609 Sound only on USB/Internet Radio/DLNA Input
                by Sushi1808
                Hi everyone!
                I turn to you in hope someone could point me in the right direction since I lack knowledge and experience in diagnosis of audio equipment. (My experience is in computer chip level repairs.)
                I bought an Onkyo TX-NR609 receiver which initially produced no sound on speakers/headphones, there was no delayed relay click, speaker matrix icon didn't show up, USB/NET stuck in "Now initializing", instead of DSP/1st NET firmware version there were ?????????...
                There was flux residue around the D830K013BZKB4 DSP chip (Q3001) on the HDMI...
                07-01-2023, 07:53 AM
              • FrancescoV
                Onkyo HT-R390 no sound output, video output ok
                by FrancescoV
                Good morning everyone,
                I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                The firmware reported is the following:
                M:1.00/11107BLP
                D:?.??/????????
                O:1.00/11107AL
                The DSP firmware given the question marks seems corrupt.
                On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                05-11-2025, 02:59 AM
              • platinumsteel
                Onkyo HT-R960 No Sound
                by platinumsteel
                Hi guys hope you all doing fine.I have an Onkyo HT-R960 from my uncle that he says he powered it on one day and no sound at all.I took it to try and repair it.I am also using it as an opportunity to start learning how to repair units like these and also amplifiers. When i first brought it home I also realized it wasn't outputting any video and audio tru the HDMI Ports.So followed a youtube video on how to change 5 caps to get HDMI output back.Did exactly that and now i have Picture tru the HDMI Ports.But still no audio. Checked a lot of voltages according to the schematic and also visually nothing...
                06-14-2023, 12:23 PM
              • roman-hartwig
                Onkyo TX-NR828 - popping sound every 5 min
                by roman-hartwig
                Object: Onkyo TX-NR828
                Problem: Popping noises in the right surround channel every ~5min
                Service manual: available
                After I was able to bring my beloved Onkyo back to life (total failure of the power amplifiers) and it has now been doing its job for some time without any problems, it is now ailing with a new problem. It still works fully, but after about 5min it "pops" in the right surround speaker for about 0.5 sec very loud (100% volume). I am almost scared to death - sounded like a battery exploding or something. It sounds like something is discharging - a...
                07-29-2023, 08:08 AM
              • LEECH666
                Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                by LEECH666
                Good day ladies and gentleman!
                I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                01-19-2024, 05:46 PM
