Onkyo HT-R960 No Sound
  • platinumsteel
    • May 2019
    • 238
    • Trinidad&Tobago
    Hi guys hope you all doing fine.I have an Onkyo HT-R960 from my uncle that he says he powered it on one day and no sound at all.I took it to try and repair it.I am also using it as an opportunity to start learning how to repair units like these and also amplifiers. When i first brought it home I also realized it wasn't outputting any video and audio tru the HDMI Ports.So followed a youtube video on how to change 5 caps to get HDMI output back.Did exactly that and now i have Picture tru the HDMI Ports.But still no audio. Checked a lot of voltages according to the schematic and also visually nothing looked burnt or any swollen caps on any of the boards. Read on another forum someone saying that if i have voltage on the ''AMUT'' and ''SMUT'' lines this will mute the audio.I measured AMUT and SBMUT and yes i had 4.9v on both lines....So removed all of the MUTE Transistors x9 of them.And measured again and 0v on SBMUT and still 4.9v on AMUT.
    I connected speakers and sent audio tru the CD Input and started getting sound on Front Speakers B only. No Sound from Front Speakers A. According to the schematic SMUT (which is 0v now) is connected to the Front Speakers B. But AMUT (which is 4.9v now) which is connected to Front Speakers A gives no sound at all. So I can't understand why AMUT still has voltage on it.Hoping you guys when u have time can check out the schematic and guide me on some things to check in case i might of missed some things. Thanks.
    I did all the basic troubleshooting already like factory resetting the unit and checking all cables.I also used a wire and touched the ends with my finger to inject 60hz frequency into the Tone Control IC output to make sure there is a connection straight to the speaker terminals. And yes all traces are fine and cables properly seated. i have a screenshot below of the schematic layout.
  • Sushi1808
    Onkyo TX-NR609 Sound only on USB/Internet Radio/DLNA Input
    by Sushi1808
    Hi everyone!
    I turn to you in hope someone could point me in the right direction since I lack knowledge and experience in diagnosis of audio equipment. (My experience is in computer chip level repairs.)
    I bought an Onkyo TX-NR609 receiver which initially produced no sound on speakers/headphones, there was no delayed relay click, speaker matrix icon didn't show up, USB/NET stuck in "Now initializing", instead of DSP/1st NET firmware version there were ?????????...
    There was flux residue around the D830K013BZKB4 DSP chip (Q3001) on the HDMI...
    07-01-2023, 07:53 AM
  • ChaosLegionnaire
    by ChaosLegionnaire
    09-13-2022, 09:02 AM
  • Sisko
    Onkyo-593 No power and now clicking sound
    by Sisko
    Hi all!!
    Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
    10-03-2025, 02:18 PM
  • FrancescoV
    Onkyo HT-R390 no sound output, video output ok
    by FrancescoV
    Good morning everyone,
    I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
    The firmware reported is the following:
    M:1.00/11107BLP
    D:?.??/????????
    O:1.00/11107AL
    The DSP firmware given the question marks seems corrupt.
    On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
    05-11-2025, 02:59 AM
  • roman-hartwig
    Onkyo TX-NR828 - popping sound every 5 min
    by roman-hartwig
    Object: Onkyo TX-NR828
    Problem: Popping noises in the right surround channel every ~5min
    Service manual: available
    After I was able to bring my beloved Onkyo back to life (total failure of the power amplifiers) and it has now been doing its job for some time without any problems, it is now ailing with a new problem. It still works fully, but after about 5min it "pops" in the right surround speaker for about 0.5 sec very loud (100% volume). I am almost scared to death - sounded like a battery exploding or something. It sounds like something is discharging - a...
    07-29-2023, 08:08 AM
