sound driver compatibility
  • kolas
    • Jul 2010
    sound driver/installer compatibility on motherboard.how can we easily see or to identify the correct sound driver/installer?what are the basic things to consider?
    • 31305
    Re: sound driver compatibility
    look at the make of the sound chip.
    go to the makers website & lookup the part number.
    specially easy if it's realtek.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      what os? windows? linux? other?
      also, using your spacebar between sentences would be nice... also, try not to word things like a rant.
      sigpic
      (Insert witty quote here)
        • 31305
        it's pretty safe to say it's windoze given that Linux has all available drivers in the kernel to begin with.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          not if it is a higher end creative... my audigy 2 was hell to even make working at all, and when i did, it was a crackle-a-thon... useless.
          sigpic
          • kolas
            • Jul 2010
            windows xp2.thanks to all of you.i should try to look first to the audio chip of my cpu unit
            • kolas
              • Jul 2010
              ok sir i'll try my best
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                the chip is not in the cpu (if you mean the processor). it is either on the mainboard or on a card.
                if it is a major brand machine (dell, hp, etc.), post the brand/model... if it is custom, post the main board brand/model. if it is custom, then find the model on the card or post a pic of it... the main chip is easy to find on the card
                note- sound chips on semi-newer mainboards are TINY- the size of a wooden pencil eraser head. hence why a model no. is a better bet.
                one last trick (this is for all drivers) is to burn a live linux cd (pick a distro, ubuntu will work great), boot off it to desktop, open a termnal and type:
                Code:
                lspci
                for non-usb devices and usb controllers
                Code:
                lsusb
                for usb connected devices
                note- firewire is neither- i am not 100% sure if there is a command for that.
                and find what you need off the list. all it detects is the hardware info, so if the cd does not load the linux driver, it will still show up.
                examples from my laptop with ubuntu:
                Code:
                larry@larry-laptop:~$ lspci
                00:00.0 Host bridge: Intel Corporation 82852/82855 GM/GME/PM/GMV Processor to I/O Controller (rev 02)
                00:00.1 System peripheral: Intel Corporation 82852/82855 GM/GME/PM/GMV Processor to I/O Controller (rev 02)
                00:00.3 System peripheral: Intel Corporation 82852/82855 GM/GME/PM/GMV Processor to I/O Controller (rev 02)
                00:02.0 VGA compatible controller: Intel Corporation 82852/855GM Integrated Graphics Device (rev 02)
                00:02.1 Display controller: Intel Corporation 82852/855GM Integrated Graphics Device (rev 02)
                00:1d.0 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #1 (rev 01)
                00:1d.1 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #2 (rev 01)
                00:1d.2 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #3 (rev 01)
                00:1d.7 USB Controller: Intel Corporation 82801DB/DBM (ICH4/ICH4-M) USB2 EHCI Controller (rev 01)
                00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 81)
                00:1f.0 ISA bridge: Intel Corporation 82801DBM (ICH4-M) LPC Interface Bridge (rev 01)
                00:1f.1 IDE interface: Intel Corporation 82801DBM (ICH4-M) IDE Controller (rev 01)
                00:1f.5 Multimedia audio controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC'97 Audio Controller (rev 01)
                00:1f.6 Modem: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC'97 Modem Controller (rev 01)
                01:00.0 Ethernet controller: Broadcom Corporation NetXtreme BCM5705M Gigabit Ethernet (rev 01)
                01:01.0 CardBus bridge: Texas Instruments PCI7510 PC card Cardbus Controller (rev 01)
                01:01.1 CardBus bridge: Texas Instruments PCI7510,7610 PC card Cardbus Controller (rev 01)
                01:01.2 FireWire (IEEE 1394): Texas Instruments PCI7410,7510,7610 OHCI-Lynx Controller
                01:01.3 System peripheral: Texas Instruments PCI7410,7510,7610 PCI Firmware Loading Function
                01:03.0 Network controller: Broadcom Corporation BCM4309 802.11a/b/g (rev 03)
                Code:
                larry@larry-laptop:~$ lsusb
                Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
                Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
                Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
                Bus 001 Device 003: ID 045e:0039 Microsoft Corp. IntelliMouse Optical
                Bus 001 Device 002: ID 413c:0058 Dell Computer Corp. Port Replicator
                Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                for sound, look for "multimedia audio controller"
                example:
                Code:
                and there is your chip model. write it down and reboot back to windows.
                go to the company's website and find the driver, if not, google for it, and if you come up dry, post here about it and we will try our best to help you.
                sigpic
                • LEECH666
                  Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                  by LEECH666
                  Good day ladies and gentleman!
                  I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                  This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                  I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                  01-19-2024, 05:46 PM
                • osrex
                  LED DRIVER KEEPS DYING
                  by osrex
                  Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                  i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                  i have no datasheet at all for the LED lights, all i have is its length.
                  long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                  as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                  05-05-2025, 03:36 PM
                  HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                  This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                  09-12-2024, 02:30 PM
                  HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                  HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
