Electrohome HVIN-RR75-1 Mains transformer help please
  • zen
    • 511
    Hi all
    Customer bought a retro stereo unit from Canada & didn't realise it was a 120V unit.
    Need I say more?
    Primary winding blown quite badly, therefore trying to work out the secondary AC supplies, of which there are two.
    AC2 which are the thicker BLUE wires go through a rectifier, then to a 25V cap, which narrows things down slightly.
    AC1 the yellow wires, after rectification go to regulator IC6, which may also be fried.
    The appliance is an Electrohome HVIN-RR75-1
    Last edited by SMDFlea; 10-23-2022, 01:07 AM. Reason: Added model number to thread title......
  • zen
    • 511
    Re: Mains transformer help please
    AC2 after rectification arrives at the audio out chip STA540SAN.
    Pulled up datasheet for chip & supply voltage stated as a maximum of 22V
    • zen
      • 511
      AC1 as mentioned after rectifier seems to arrive at IC6, which is a Microne ME6118A33B3G adjustable regulator.
      This one might be slightly trickier to pin down.
        • 31048
        Electrohome used to produce great service manuals - did you search?
        • zen
          • 511
          Connected a Variac to the AC2 terminals on PCB & increase supply gradually.
          An AC input of around 12V will result in DC 15V on audio chip supply pins 3 & 13. Will play it safe & start with that.
          AC1 I'm not quite sure about.
            • 31048
            so i just tried to look up that UL code on the transformer.
            it seems the UL has sold out and is just another "kosher" mark now.
            just go to the website and buy a few, but you cant check one without an account!!
            so no use anyway if they cant be verified as real by non-gangsters - i mean non-members
            • zen
              • 511
              Hi STJ no didn't even think to check. Will have a search.
                • 31048
                AC1 is probably 7v
                AC2 is probably 15v
                7v is common for driving a regulator for logic circuits.
                • zen
                  • 511
                  Thanks , i wasn't too far off then
                  Managed to dig out a transformer I had stripped out of an Onkyo AV system years ago, which has load of outputs.
                  12V to AC2
                  10V to AC1
                  Unit then powered with radio and turntable working, but no CD play.
                  Started scratching my head thinking supply not correct, or surge has damaged it.
                  Turned out to be bad contacts on CD turntable motor & a quick spray with some cleaner restored operation.
                  Result finally after a whole day on this beast.
                  • zen
                    • 511
                    Can't believe this unit.
                    Meant to be new, fully working, but CD turntable motor lazy.
                    The turntable motor has no marking to indicate type, therefore modified board to take a physically larger motor, but that didn't work.
                    As a last resort, I have immersed original motor in WD40 & will leave it overnight, which I'm hoping might restore full operation.
                      • 31048
                      wd40 is moisture remover,
                      you should use 3-in-1 oil instead.
                      • zen
                        • 511
                        Thanks STJ, worth a try.
                        • zen
                          • 511
                          Well tried it all, including injecting very fine watchmaker oil into the motor bearings.
                          This improved the functionality, but not reliable enough.
                          I then started searching for CD mechs that use same reader, which is a Sanyo SF-P101N
                          Found a generic one at ASWO that looked same, except for the spindle & sled motors which were physically larger.
                          Took a chance, as it was cheap enough.
                          Fitted & now working on test.
                          • ohren
                            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                            by ohren
                            Hello!
                            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                            Measured voltages with no load:
                            After rectifier diodes
                            12V: 6.17 V
                            5V: 5.67 V
                            Secondary transformer pins AC measurement (really don't know if this says anything)
                            12V: 2-2.5 V
                            5V: 1.04 V
                            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                            03-18-2023, 10:33 AM
                          • dicky96
                            Laminator blows fuses and trips the mains - but not when on my ispolation transformer
                            by dicky96
                            Hi guys
                            So here is a 'weird device' it is an IKON IP-450 A2 Paper laminator
                            The customer says it was warming up then suddenly tripped out the 220V mains
                            He replaced the 5A fuse which had blown but it did the same thing straight away as soon as powered on, it trips out the power in his apartment. He tried another power lead and tried it at a friends address but the same occurs
                            So he brought it to me, having fitted a new fuse again.
                            I plugged it in and it worked fine - it was drawing about 3Amps and warmed up to maximum working temperature...
                            05-26-2020, 05:24 AM
                          • mikey5791
                            Is it possible for transformer substitution?
                            by mikey5791
                            Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                            Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                            My questions are
                            1. How do i test to see if the transformer is in good working condition?
                            2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                            Hope you guys understand what i was asking. My intention is...
                            11-03-2022, 02:11 AM
                          • dennis_elx33
                            3PHASE STEP-DOWN Transformer in Check
                            by dennis_elx33
                            Hello All,
                            i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                            Problem statement: Power tripped Off
                            Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                            Action Done:
                            1) Replaced the faulty parts with good spare.
                            2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                            12-02-2024, 06:52 AM
                            ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                            This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 04:40 PM
