WTF is this? Tru Tone Model 300A
  • petehall347
    • Jan 2015
    • 4440
    • United Kingdom
    Re: WTF is this? Tru Tone Model 300A
    try searching for the valve numbers 35Z5 -12SJ7 50L6 and see if it matches any schematics .
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Looking at the guts, I think this must be some sort of transmitter. Its ΒΌ" jack feeds to a pot that's capacitively coupled to the grid of the 12SJ7 grid.
      Likewise the 50L6 plate seems to be coupled to coil and the pigtail "antenna" output. It's too simple to be anything other than AM as far as I can tell. Drat, still looking for a cheap SSB transmitter.
      Next is to somehow figure out the frequency... if only I had a spectrum analyzer, that'd make it real easy...
        NVIDIA PCB ID / BOARD ID Chart
        PCB ID - Core model
        v218470 - AMD/215-0767003
        v218510 - AMD/215-0767003
        v27314s HD7850
        v27937s - HD7730
        v310440 - GM107-400-A2
        v313070 - GK208-201-B1
        v313080 - GK208-201-B1
        v313120 - GK208-201-B1
        v313130 - GK208-201-B1
        v313140 - GK208-201-B1
        v313220 - GK208-201-B1
        v31609s - GM204-200-A1
        v31615s GM204-200-A1
        v316320 - GM204-200-A1
        v317290 - GM204-200-A1
        v32002s - GM206-300-A1
        v320040 - GM206-300-A1
        v32005s - GM206-300-A1
        v32010s - GM206-300-A1
        v320115s - GM206-251-A1
        v320120s...
        10-02-2024, 09:21 AM
      • CDNBrewer
        Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
        by CDNBrewer
        Hello Everyone,
        I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
        Symptoms:
        • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
        • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
        • I swapped the Left and Right surround
        08-05-2025, 09:29 PM
      • wolf1976
        wireless receiver for 6 speeds fan control with remote control
        by wolf1976
        hi i have a receiver that is destroyed from the overvoltage i guess
        my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
        the motor fan has not label
        i have an other receiver operational
        In your opinion can i measure the voltage at the output ?
        what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
        thanks in advance...
        07-23-2025, 03:12 PM
      • Capestang
        Yamaha DSP-AX861SE Sub problem
        by Capestang
        I really hope someone will be able to help me?
        I have recently moved house and dismantled a working 5.1 home cinema
        system. Unfortunately when putting it back together again I get no
        sound out of the sub, I'll try and give you as much (probably too much)
        information to hopefully allow you to sort my problem, or at least
        point me in the right direction.
        * My system consists of a Yamaha DSP-AX861SE AV receiver connected to
        various sources and outputting through speaker cables to 4 x Monitor
        Audio Radius 90s, 1 Radius 225...
        01-24-2023, 04:00 AM
      • redwire
        Honeywell/Ademco Wave2 two-tone siren - recap, sch, pics
        by redwire
        My garage alarm siren was sounding a bit quiet and the tone was weird, like mixed with another tone.
        Powered up it draws about 14V 300mA with a spike to ~1A briefly during the low pitch yelp, seems normal.
        Teardown reveals only two electrolytic capacitors inside, so I replaced them. 100uF 25V for the warble ramp, and 47uF 16V for decoupling.
        The old ones tested OK sort of? - 100uF reads 68uF (-32%) ESR 0.80Ω, and 47uF reads 41uF ESR 0.87Ω as well so it was a bit confusing if the caps were to blame.
        The tone caps are green film caps I left alone. Newer...
        07-30-2023, 08:21 PM
