BMW F07 Top-HiFi audio amplifier
  • tehmatix
    • Nov 2012
    • 174
    I have problems to repair this device from a BMW X3 car. What I found is 4 components on the power inverter side off the amplifier which are not marked at all. All 4 items has a short between terminals 1 - 2.
    Can someone tell me what components are those 4 ?
    Thank you
  • tehmatix
    • Nov 2012
    • 174
    Re: BMW F07 Top-HiFi audio amplifier
    I keep locking onto board to understand how it works and I found a connections between output pins of UC28025D PWM controller. It's a short with a resistance value of ~20ohm between pin 11 and pin 14.
    Still I don't have any clue what type of transistors can be all 4 .
    • lotas
      • Jan 2016
      • 4623
      • Russia
      These are MOSFET transistors, they are in the inverter to get an increased bipolar power supply to the amplifier, there may be markings, just not visible, wipe the surface of the transistor with alcohol, acetone.
      • lotas
        • Jan 2016
        • 4623
        • Russia
        I will add: Transistors there are 50N06-07L
        When these Mosfets burn out, you need to check the entire wiring of these transistors and also replace the UC28025DW.
        • tehmatix
          • Nov 2012
          • 174
          Hi lotas,
          Thank you so much for your response. I placed an order on Alixxxx for transistors and also can find a kit for repair on their site.
          Waiting to come and a will keep update this post
          • tehmatix
            • Nov 2012
            • 174
            I replaced the PWM controller and 4 MOSFET transistors, working great
            • samson7point1@yahoo.com
              Help troubleshooting an audio problem with an RCA SGT-250 CED Player
              by samson7point1@yahoo.com
              The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
              The player processes the audio signal using two different reference frequencies. The "R"...
              04-30-2024, 11:22 AM
            • eccerr0r
              Frying amplifier finals... audio, not rf...
              by eccerr0r
              Well for RF transmitters, transmitting without an impedance matched antenna and if the transmitter doesn't have automatic limiting... kiss the final transistor goodbye and chalk one up to something you killed.
              But that's not the same way with audio amps for the most part, well, at least the wavelength of audio on copper is so long that you get all of it back anyway but the transistor is fine with it...
              So how are people destroying finals in their audio amplifiers then? Heh.
              Are people shorting their outputs or something, overdriving output to a too big speaker?...
              11-27-2021, 12:30 AM
            • MrCommunistGen
              Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
              by MrCommunistGen
              My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
              I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
              07-12-2021, 05:11 PM
            • Babbar
              by Babbar
              04-12-2024, 01:12 AM
            • LEECH666
              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
              by LEECH666
              Good day ladies and gentleman!
              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
              01-19-2024, 05:46 PM
