Good day folks. Today I got something which I haven't worked on very often because they're falling out of fashion: a tape deck - sounds lame, but it's a challenge I'm willing to accept.
It's a rather basic one: no auto-reverse, though it's got Dolby on it, so I guess it's decent and worth saving.
There are 2 issues with it:
A) it takes its sweet time to finally output any sound after being powered on, despite the transport running and the LEDs coming on fine
B) the left channel is dead
A) I had a look at the schematic on page 49, towards the bottom-left of the page. It took me a while to understand how it works, but I THINK I got it: when you turn on the power switch at the front (S1), C52 slowly charges up via R53. Meanwhile, the emitter of Q1 gets 12v right away from the 20v rail off the bridge rectifier (stepped down to 12v by D52 and R55). Because Q51 is a PNP, at this point the emitter is still more positive than the base, because C52 has not charged enough, so the C-E path is "open" and 12v flows to point K which keeps the board in "mute" until C52 finally becomes more positive than the emitter of Q51, "releasing" mute. The way it does this is by turning on Q707, Q708 and the cascaded Q711-Q714 (don't know why they cascaded SO many of them there) which pulls to GND both the output jacks at the back and the signal paths from the head itself, if I'm not mistaken. THIS is the problem: it takes WAY too long for point K to drop low enough to release the "mute rail" and I can't quite place it. I obviously pulled C52 and C51 first, but they read fine on my meter, so I didn't replace them just yet, although I WILL just for good measure. I also did the same with C4 on the left there and the same thing happened - not out of spec in the slightest.
Taking some measurements indeed confirms the base of Q51 is slowly charging up after a cold start. At around 11v, point K "snaps" off, the LED vu-meters start dancing around and I get an output (though only the right channel - the left is dead), which brings me to:
B) No sound coming out of the left channel AT ALL -I even tried different tapes. The VU meter doesn't dance either
There's something wrong either with the head-amp circuit which sucks because it's all discrete components, or with IC501 which sucks even harder because if the signal is not making it through it, finding a replacement for that whole chip is probably not be easy :| Since I do not have a scope, I'm thinking of using a small amplified speaker to "probe" after C513 and C514 (pins 3 and 39 respectively of IC501 in the middle there) to see if I get any sound output from the head amp part directly. It will probably be very weak because it's not amplified by IC501 there, but enough to figure out if the left channel is giving IC501 anything to work with....either that, or my idea is bad and I blow something up
