Sony Str-DB940 problem with rear speakers
  • vegadesigns
    • May 2010
    New at this forum, came across searching on db940 troubles.
    I have troubles with my Sony STR-DB940 amplifier and am not willing to throw it away; it really has perfect sound and power.
    The problem occurs with the rear surround speakers: they don't work .
    Well, sometimes they do. While testing with the builtin testtone I had no sound on both rear speakers. Now, while the amp is transmitting the sound to the rear speakers and I turn the volume to >80% it pops in. Like I scared him.. I have to do this with both L and R rears and they would work for some time (minutes). Then they stop producing sound again. It's annoying, can't find and don't know where to look for and how to solve this.
    Can anyone be of any help? I'd appreciate it a lot!
    Thks, Marcel
  • smason
    • 1652
    Re: Sony Str-DB940 problem with rear speakers
    I would guess that it's a bad relay contact, or dirty switch.
    Other possibility would be a bad solder joint.
    • cadiman
      • Mar 2010
      • 397
      If they come in clear at higher volume I would resolder the outputs. I always scope the signal going into the amp curcuit. Try to find the outputs that control those speakers.
      check/resolder relays as said above. check resolder outputs for said speakers. Good luck
      Cadiman
      • slidingcarlos
        • May 2010
        Hello vegadesigns!!
        ... I had exactly the same problems with my str db-940.....!!
        ...I´ve tried several things, including increasing the audio output to the rear speakers!!... this makes the overall time interval between the "audio blackouts" alot longer.... BUT I think I´ve just solved the problem with yet anoher solution... First try to play the loud sound, so that the rear speakers plays again... than change the "impedance" on the backside of the receiver to 8 ohm...... That worked for me!!!... so far... that is.... !!
        If I could get your email, we could keep in touch if the problem continues!!
        • soeren
          A2442 - No sound over internal speakers and no video playback
          by soeren
          I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
          All happened after the battery ran out of power overall several days when I was on vacation.
          I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
          07-26-2024, 01:24 AM
        • iglitare
          Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
          by iglitare
          i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
          Backlight seems to work, Sound (Setup menu after reset) works.
          If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
          Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
          With my small knowledge i would think at least the cables are good.
          Can this happen because of a bad tcon board?
          Or is it always a bad/shorted...
          09-04-2025, 07:13 AM
        • ChaosLegionnaire
          by ChaosLegionnaire
          09-13-2022, 09:02 AM
        • Akuanka
          Sony SLV-E780 Power Supply Issue – Clicking Sound, Need Help Identifying Faulty Component
          by Akuanka
          I'm troubleshooting a power supply issue with a Sony SLV-E780 VCR. The device clicks repeatedly but doesn't power up completely. I've already replaced five capacitors, but the problem persists.
          Here's a video link https://photos.app.goo.gl/3Xki6yvCLn67gLX78​ showcasing the sound. Based on your experience, could this be due to a transformer, diode, or another component? Any guidance on what to test or replace next would be greatly appreciated.
          Thanks in advance for your help!
          11-23-2024, 01:12 PM
        • KYBOSH
          Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
          by KYBOSH
          Previous owner said TV just went blank one day.
          They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
          Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
          The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
          There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
          I just downloaded the Sony KD-75X7800F Service Manual and...
          11-19-2024, 10:12 AM
