Another Klipsh
  • NATY
    • Jan 2010
    • 5
    Another Klipsh
    Interesting,....
    I am working on a Klipsh Powerd spkr in which I found:
    an N-ch Mosfet with a hole blown through it
    and a high temp (I think) resistor, also blown apart
    the magic smoke also has rendered a large cap (electrolytic)
    virtually unreadable, tho it appears by the circuit
    to be at least 300V in value@680** the rest of value
    is obscured so,..2 inquiries
    1. as I must replace the blown Mosfet,..should I replace
    both?
    2. the large cap is a Jamicon code on cap is: 054K0(M)
    can the cap value be identified with this info?
    thanks for the assistance
  • Agent24
    I see dead caps
    • Oct 2007
    • 4981
    • New Zealand
    Re: Another Klipsh
    The code "054K0(M)" I think is the date of manufacture as well as tolerance (M) which is 20%
    If this is powered from mains then for that capacitor 300 volts makes sense, also 680 will be in uF (microfarads) - It won't be anything else.
    You shouldn't normally have to replace the primary capacitor though, but in this case it may have been damaged - only way to know is to pull it out and test it...
    Photos would be great too, so we can see what's going on, like where exactly your blown MOSFET is etc...
    -David VanHorn
    • drscoot
      HP X360 convertible battery blown fuse error, not charging
      by drscoot
      HP Modelnumber: 14-dh0061nb​
      This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
      The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
      I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
      And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
      All these 3 batteries are charging...
      12-15-2023, 05:54 AM
    • swerg
      Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
      by swerg
      Hey everyone,
      I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
      I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
      I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
      06-06-2024, 03:39 PM
    • MrzPdlch
      Blown fuses on Gigabyte GTX 980TI 6GB
      by MrzPdlch
      Hey everyone,
      I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
      Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
      Find some pictures of the actual GPU together with a picture of how it should look like.
      I also wonder whther it might be a problem that there...
      03-10-2024, 04:14 PM
    • cheeky2
      Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
      by cheeky2
      This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
      I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
      Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
      06-15-2025, 05:12 AM
    • mattx97
      HP VICTUS 15-fa1093dx Blown Power IC
      by mattx97
      I've had a little issue with this laptop. It had a charging issue, so I replaced the charge port and tried the old charger. It was clearly damaged, and the laptop started smoking. So I ordered a new charger and tested again, but no power, and upon further inspection I noticed a power management IC was blown.
      I just wanted to know if it was in any way fixable, considering it seems it may have burned layers of the board.
      I will attach two photos of the blown one and the seemingly good IC.
      Board rev DAG3PAMB8D0
      Any help would be...
      04-25-2025, 10:30 AM
