I have this audio card in ASUS TUSL2-C and I hear the speaker whining even if sound is muted.
My first sucpect is PCI slot - I have the card in the last PCI on the bottom of case.
The second suspect is that I overshooted PCI caps capacitance. IIRC there were 1000 uF caps and I changed them for Samxon GC 3300 uF ones (did not have lower capacitance
However there should be no drasticall current flow between CPU and PCI as I changed all the crappy caps with low capacitance in VRM for the GC Samxon's. I also added the caps which were not ocuppied so the capacitance aroud PCI slots should've risen equaly to VRM capacitance.
You guys are far more educated in this area than I am, so any idea where the problem could be?
).However there should be no drasticall current flow between CPU and PCI as I changed all the crappy caps with low capacitance in VRM for the GC Samxon's. I also added the caps which were not ocuppied so the capacitance aroud PCI slots should've risen equaly to VRM capacitance.
Half of the computer problems is caused by bad contacts
That's for the PCI problems I've been talking about...
