reforming nos capacitors
  • umut1001
    • 7
    Hello..I have some questions.I have some nos capacitors(siemens, sikorel ,rifa ,felsic) but I think i should reform Rifa peh169 63v 15000uf ones first.
    1)They have datecodes but i do not know their meanings.Some of them have BN8 some of them BN9 and BP2.Can you estimate or calculate their ages?I shake them.Some of them sounds more lytic water and some of them have less.What is your commands ?
    2)What is the most reliable voltage and resistor for reforming for my Rifas?
    Thank you very much.
    BR Ümit
  • sofTest
    • Aug 2008
    • 361
    Re: reforming nos capacitors
    Each manufacturer seem to have their own procedure for reforming/reconditioning. Have a look at these threads:
    https://www.badcaps.net/forum/showthread.php?t=6719
    https://www.badcaps.net/forum/showthread.php?t=5126
    As for date codes, if they are not self explanatory, you have to look up the capacitors data sheets.
    Be a mensch
    • dragon3x
      by dragon3x
      power on.
      Here are some examples :
      switching supply area).
      than 6.3 V.)
      03-21-2025, 02:46 PM
    • slybunda
      AA and AAA battery charger capacitors?
      by slybunda
      hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
      it has inside:
      2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
      2 x 470uf 16v LZ105c branded as G.Luxon
      not heard of these brands are they any good?
      iv attached photos of the charger and the board inside for an idea on the type of...
      12-24-2023, 04:41 AM
      After all of...
      07-13-2024, 08:14 PM
    • Ady2017
      Are there any datasheets available for Elna RJG capacitors?
      by Ady2017
      I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
      05-25-2025, 02:19 PM
    • ctroxtell
      Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
      by ctroxtell
      I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
      01-03-2025, 08:57 PM
