Aiwa Tape Deck Right Output Low
  • Carm99
    • Jun 2014
    • 69
    • England
    Hi
    I have an Aiwa AD-6900 mkII that I just replaced a couple of belts on.
    I haven't used it for a couple of years due to not doing the belts but when
    I put a tape in and play it ,I'm only getting output on the left channel but the VU's are the same.
    Rather ,Im getting output on the right ,but it's really really low.
    Anyone know what could be wrong with it?
    Cheers
  • Carm99
    • Jun 2014
    • 69
    • England
    Re: Aiwa Tape Deck Right Output Low
    I sussed out that Im getting both channels using the Din on the back.
    I wouldn't mind using the phono outs if anyone can figure that out.
    Cheers.
    • FrancescoV
      Onkyo HT-R390 no sound output, video output ok
      by FrancescoV
      Good morning everyone,
      I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
      The firmware reported is the following:
      M:1.00/11107BLP
      D:?.??/????????
      O:1.00/11107AL
      The DSP firmware given the question marks seems corrupt.
      On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
      05-11-2025, 02:59 AM
    • pecman
      Aiwa Z-R700 Music System has very low power when switched on, dim lighting and nothing works
      by pecman
      I was given an Aiwa Z-R700 from the 1990s era to look at by someone who said the twin tape deck did not work. The whole unit unit powered up ok but there was nothing from the tape deck. I had a look and found all the belts broken, I replaced the belts and then put the tape deck back into place and it still does not work. Also when I now power up the unit all the lighting on the front is very dim and the cd player and the tuner as well as the tape deck do not work. I have checked all the connections and ribbon cables again, there are no burnt or swollen capacitors. Maybe there are capacitors on...
      08-05-2025, 10:10 AM
    • RetroComputingGrotto
      IBM LTO 7 Tape Drive - Dust Sensors??
      by RetroComputingGrotto
      I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
      I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
      09-19-2024, 01:54 AM
      NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
      I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
      I bought this from an eBay seller but unfortunately they only had one
      I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
      I bought three of from them to also make battery packs with this output power limit in mind
      I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
      04-23-2025, 05:50 AM
      Corsair CX750M [Model 75-002019] - burned output toroid inductor
      by momaka
      Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
      So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
      09-19-2021, 08:44 PM
