TDGAUDIO NFC-83A ceiling speaker crossover repair(no output)
  • r2digital
    • Sep 2011
    • 39
    Hey guys, im trying to figure out why my ceiling speaker has no output from the woofer or tweeter. I cannot seem to get a resistance at the main input speaker terminals but i did measure resistance at the woofer and at the tweeter wires individually and everything seems to be OK. Ive done a little bit of troubleshooting on my own and when i was probing the negative terminal in combination with any component (PTC fuse, the capacitor, and any of the resistors) on the crossover i get no continuity what so ever. However, when i take the same model speaker but a fully working one and i probe the negative terminal in combination with any of the components listed above i get continuity. What section of the crossover would cause a no output condition? I've been toying with the fact that its the PTC resettable fuse but i am unsure if its used to only protect the tweeter or if its used to protect the entire design.
    I checked all the resistors and the values are as follows
    25w2ΩJ=1.5
    25w2ΩJ=1.5
    10w2.2ΩJ=1.4
    10w2.2ΩJ=1.4
    10w2.7ΩJ=2.8
    • 31124
    Re: TDGAUDIO NFC-83A ceiling speaker crossover repair(no output)
    thats a stupid design, the vibration will fuck the soldering.
    check the joints on the back of the board.
    • r2digital
      • Sep 2011
      • 39
      I will touch up and reflow all the joints on the back of the PCB. Do the resistance values seem correct? When i check the resistance values of the same model of a working speaker the results are much closer to their rating.
      For example the
      25W2ohmJ=2.2ohms
      10W2.2ohmJ=2.3
      Should i be concerned the the different values on the non working speakers?
      • r2digital
        • Sep 2011
        • 39
        looks like some one already got to the PCB before me. Lots of deep scratches on the pcb. I think maybe one of them is deep enough to cut a trace to the negative post?
        free animated gif flag
        • petehall347
          • Jan 2015
          • 4429
          • United Kingdom
          the thermistor is there to protect the tweeter .
          • r2digital
            • Sep 2011
            • 39
            Does anyone what i should check if i have no output from the tweeter/midbass? Verified the tweeter and midbass work fine individually
              • 31124
              draw the circuit.
              it doesnt look like a crossover though - only one cap.
              • waigy
                Nikkai EAPA 450 car amplifier rear speaker output is a low level and distorts easily
                by waigy
                As the title.
                I think these used to be sold in maplins a lot of years ago, it is an antique, but it's just fine for my needs.
                It looks basic enough inside with large components so I could do a full recap pretty easily.
                Any suggestions on what component would cause the symptoms of low volume output on both left and right rear speaker outputs?
                If I turn up the rear gain level in the amp until the speakers start to distort it starts to distort quickly even though the speakers are still pretty quiet.
                I thought I had dodgy speakers as I just fitted new old stock 6x9s in...
                11-08-2024, 03:53 AM
              • FrancescoV
                Onkyo HT-R390 no sound output, video output ok
                by FrancescoV
                Good morning everyone,
                I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                The firmware reported is the following:
                M:1.00/11107BLP
                D:?.??/????????
                O:1.00/11107AL
                The DSP firmware given the question marks seems corrupt.
                On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                05-11-2025, 02:59 AM
              • 30Cal
                Peavey SP5 Speaker Crossover.
                by 30Cal
                Greetings. Having an issue with extremely low output to tweeter. Replaced driver and fuze. As far as I can tell every component has relatively low ohms and no opens. I only use the speakon connection. Woofer operation is OK. Tried tweeter on woofer connection and sounded fine. Jumped the resetting fuze, no difference.
                Considering speakers are 20+ years old (MADE IN USA) and been through hell and back I really can not complain.
                Redid a few years back with Eagles influence.
                Any information would be greatly appreciated.
                Thank you for your time.
                09-07-2025, 03:53 PM
              • Z2yzx
                Denon AVR S720W Main Speaker no output.
                by Z2yzx
                Hi everyone!
                Does anyone out there have any insight as to why my AVR will not output sound through main speakers or head phones?
                Here is the info:
                Unit powers up normal
                Relays click
                Zone 2 works fine 100% of the time.
                Main Zone sometimes works fine like .05% of the time.
                Sometimes I can plug headphones and hear scratching sound via the headphones. Once that happens I can unplug the headphones and the main speaker zone works fine.
                is there something I can inspect?
                I have somewhat moderate skills with electronics....
                12-19-2023, 01:34 PM
              • Califauna
                Help with boom box modification
                by Califauna
                Hi, this is more of a project help request than a troubleshooting question. I hope I can post it here.
                I have a W-King D8 Bluetooth boom box which I'd like to modify with some external speaker output jacks and some buttons to switch the internal speakers on and off.
                From factory the specs of the boom box are:
                -Power Input: DC 5V
                -Speaker Output Power: 2 x 25W ( confirmed by Youtube channel Hartdegen review as 12.5W RMS per channel)
                -Drivers:
                -2 x Woofer, 70mm, 10Ω, 70mm,15W
                -2 X Tweeter, 8Ω, 30mm,10W x 2
                -Frequency...
                12-04-2021, 01:53 PM
