Denon AVR S720W Main Speaker no output.
  • Z2yzx
    • Dec 2023
    Hi everyone!
    Does anyone out there have any insight as to why my AVR will not output sound through main speakers or head phones?
    Here is the info:
    Unit powers up normal
    Relays click
    Zone 2 works fine 100% of the time.
    Main Zone sometimes works fine like .05% of the time.
    Sometimes I can plug headphones and hear scratching sound via the headphones. Once that happens I can unplug the headphones and the main speaker zone works fine.
    is there something I can inspect?
    I have somewhat moderate skills with electronics. I have a VM and oscilloscope ( admittedly never really used ), but I would love to bring this AVR back to life.
  • frankusb
    • Apr 2015
    • 110
    It sounds like the headphone jack is dirty and the switch needs to be cleaned.
    • gvse
      Denon avr-x2000 no sound on main zone
      by gvse
      I have a problem with the denon avr x2000 where the zone2 analog audio and am/fm works fine. But on the main zone none of the channels are getting any sound (including analog audio with direct or pure direct mode). With some debugging it appears like the input card is switching the analog audio to the hdmi board. But there is no return audio signal. The hdmi card seems fine for video. Its just the digital audio path that is having issue.
      The power amp path is fine for the main zone. When i patch the zone2 preamp signal manually to FR and FL, i can hear the audio on FR/FL.
      06-02-2021, 03:46 PM
    • FrancescoV
      Onkyo HT-R390 no sound output, video output ok
      by FrancescoV
      Good morning everyone,
      I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
      The firmware reported is the following:
      M:1.00/11107BLP
      D:?.??/????????
      O:1.00/11107AL
      The DSP firmware given the question marks seems corrupt.
      On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
      05-11-2025, 02:59 AM
    • cheeky2
      by cheeky2
      05-25-2024, 03:27 AM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • howardc64
      Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
      by howardc64
      Problem
      Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
      Model & Board Pics
      Conflicting Spec
      Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
      https://www.shopjimmy.com/vizio-gj-2k1...
      10-10-2024, 01:16 PM
