Chord Mojo
  • chrometsuba
    • Jun 2021
    Chord Mojo
    Does anyone have any experience with the Chord Mojo DAC/AMP? I got one for a good price that the seller reported as not holding a charge, which I assumed meant a bad battery. After replacing the battery, it seems to only be able to do a partial charge.
    I contacted Chord about this, but as it's out of warranty, the quote they gave plus what I just spent on it plus the battery is way more than a new one. They did indicate that it's likely a blown charge circuit that requires a new board to fix.
    I have a DMM, scope, and other diagnostics tools on hand to do measurements but unfortunately no schematics. If anyone is familiar or willing to help, I can post measurements and hi res photos of the PCB.
    Probably a long shot, and it works OK plugged in (apart from charging) so if I can't fix it, it will just be a desktop DAC for me.
    thanks
  • ipatch
    troubleshooting microsoft surface pro 4 no power no led charge light
    by ipatch
    hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
    10-05-2023, 11:59 AM
  • ruletero
    Acer a515-43 low battery charge voltage
    by ruletero
    Hi
    Acer A515-43
    LA-H801P
    Fail: Does not charge battery, has low voltaje on connector.
    Laptop didn't want to turn on, only charge led blinked.
    I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
    I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
    Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
    10-24-2022, 02:31 PM
  • Klevjetack
    Charge a L19D3PDA battery externally from the laptop
    by Klevjetack
    Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
    03-05-2024, 07:26 AM
  • razenxd
    How can I charge that battery pack?
    by razenxd
    it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
    At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
    Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
    Now, I have noticed a few things.
    The "dead" battery, while connected to charger and NOT Charging will...
    12-05-2024, 06:11 AM
  • Elektronror
    Asus GL702VS No charge, unstable GPU power
    by Elektronror
    First post here, second if you count the introduction thread, so don't hesitate to tell me if I'm doing something wrong.
    Bought a used Asus GL702VS which had been sitting for a while so it arrived with a dead battery. Plugging in the charger it came back to life and I didn't notice any problems with the computer. I also used it running on battery for 1-2 hours. I then played around with undervolting the CPU with the charger connected when a 10uF MLCC shorted AC_BAT_SYS. After removing the short, battery won't charge and the GPU has power limitations. I suspect that these are 2 different...
    02-05-2021, 10:39 AM
