Stereo speakers to mono speaker
  • tmcw
    • Oct 2010
    • 382
    • Ireland
    I picked up this set of powered PC speakers, no name brand, power cord to one of the speakers, and two audio cables coming out of it, one going to the other speaker, and the other to a 3.5mm jack for plugging into an audio out source.
    So, a typical cheap powered PC speakers setup.
    Now, the sound is pretty decent, I must admit, from the 4 ohm, 3W speaker, but I say "speaker", because it's just coming out of one of the speakers, and not the one with the power cord coming out of it. The other speaker is ok, it's just the electronics going to it has probably a fried component or two. I did remove the wire from the speaker, and moved it to the working speakers circuit, and it does work ok.
    Anyway, what I would like to do is remove one of the speakers, and wire it up so that the left and right channels come out of one speaker, so what's the best way to do this? I was thinking of getting a mono 3.5 jack and cable, wiring it up to the channel circuit side that still works (dunno if it's left or right, just that it's the one that the speaker without the power cord going to it), and then wire the other speaker to the working channel circuit.
    Will that give me both left and right channels from the one remaining speaker? Is there anything I need to be careful of? Or is there a better way to do this with what's available?
    I don't feel like trying to fix the broken channel circuit, and only want one speaker, but with both left and right channels coming from one speaker.
  • petehall347
    • Jan 2015
    • 4433
    • United Kingdom
    Re: Stereo speakers to mono speaker
    remove the wires from powered speaker and one wire from the socket where the other speaker plugs in . join one wire to the powered speaker and the other to the socket ..job done .
    best see pics first to confirm my thoughts as it may not be as i imagined it .
    basically you want to wire both speakers in series .
    • tmcw
      • Oct 2010
      • 382
      • Ireland
      Thanks for your reply.
      I've attached a couple of photos, on the trace side, you can see the jack input connections to the board to the bottom left, covered with the glue, and the other two connections at the top left of the board are going to the other speaker. Power from the transformer goes to the middle right.
      On the component side of the board, you can see the white and black wires that go to the speaker that's in the same box as the board. This is the speaker that doesn't work when it was connected to it's circuit.
      I need to scrutinise the board though, because I forget where I disconnected the white wire from! I used this wire to test the speaker on the other speakers circuit, and it worked ok, sounded like the volume decreased though, probably because the circuit was then driving 2 speakers for a moment.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Question too is do you need the amplifier still?
        If you still need the amplifier, then I think it's worth while debugging and fixing, unless if the problem was due to a speaker going open.
        Otherwise you really need to setup a mixer type circuit which will add complexity, you can't just use a mono plug unless you can tell your device to mix to one channel (left).
        • petehall347
          • Jan 2015
          • 4433
          • United Kingdom
          check this wire it looks like it might be broken
          • RetroComputingGrotto
            Behringer MS16 Speakers - Low Volume on One Speaker
            by RetroComputingGrotto
            I've had a set of speakers come in with the fault of not powering on.
            I could hear something wrattling around in the speakers so we played a game called Guess What's In The Speakers! and this is what we found:
            1 random loose nut and part of a BIC Biro pen.
            After removing these foreign objects I plugged in the speaker and powered it on and found the volume to be quite low. On plugging in the other speaker it was very loud, but only out of the other speaker, this side was still very low.
            05-20-2024, 07:29 AM
          • Califauna
            Help with boom box modification
            by Califauna
            Hi, this is more of a project help request than a troubleshooting question. I hope I can post it here.
            I have a W-King D8 Bluetooth boom box which I'd like to modify with some external speaker output jacks and some buttons to switch the internal speakers on and off.
            From factory the specs of the boom box are:
            -Power Input: DC 5V
            -Speaker Output Power: 2 x 25W ( confirmed by Youtube channel Hartdegen review as 12.5W RMS per channel)
            -Drivers:
            -2 x Woofer, 70mm, 10Ω, 70mm,15W
            -2 X Tweeter, 8Ω, 30mm,10W x 2
            -Frequency...
            12-04-2021, 01:53 PM
          • Sik_6ty_Sixx
            HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
            by Sik_6ty_Sixx
            So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
            02-18-2025, 05:06 AM
            HP ProDesk 600 G5 + Bluetooth Speaker 400 ProDesk 600 i7-9700 Specification for Upgrade or Repair
            This specification for the HP ProDesk 600 G5 + Bluetooth Speaker 400 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Bluetooth Speaker 400 boardview and ProDesk 600 G5 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
            09-12-2024, 02:30 PM
            HP EliteBook 1050 G1 + Bluetooth Speaker 400 Notebook 1000 Specification for Upgrade or Repair
            This specification for the HP EliteBook 1050 G1 + Bluetooth Speaker 400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Bluetooth Speaker 400 boardview and 1050 G1 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
            09-06-2024, 12:00 PM
