Harman Kardon AVR-355 going into standby
  • unilogic
    • Aug 2010
    My AVR-355 switches itself to standby mode after a few minutes, when it becomes warm. If I turn it back on, it doesn't shut off anymore and can run for hours. If I let it cool down for a few hours and then turn it on again, it shuts off again after a few minutes. But no more problems if I turn it back on immediately. This always happens, even if the device is not connected to anything. I don't see a "protect" message or anything special. The device simply goes to standby (amber power button)
    I did a complete reset of the CPU, but the problem persists...
    I have attached the service manual, but I'm not sure which way to look. Is it a power supply problem, or is it the CPU forcing standby mode because it has detected an abnormal condition?
    Pierre-Yves Andri, Belgium.
    • 31269
    Re: Harman Kardon AVR-355 going into standby
    sounds like a bad cap,
    try using a hair dryer to narrow down which part of the board needs to be warm.
    • daron
      • May 2021
      • canada
      there are two fuses on the transformer circuit board f110 and f111, harmon kardon recommends replacing them with 3.15a 250v fuses, should solve the problem
      • unilogic
        • Aug 2010
        Hi Daron,
        After buying a new AVR (Denon), I decided to repair this old and good HK AVR-355. So I located F110 & F111, but they are already 3.15A fuses.
        To be sure, I decided to momentarily bridge them, but the problem is still there : switching to standby mode after 5..10 minutes
        (but AVR remains ON if I restart it immediately, until next cold start).
        Thanks for your suggestion anyway !
        • debruina
          • May 2020
          • 29
          • Nederland
          1. Measure AC component on every DC voltage rails. Replace / check capacitors when to high.
          2. Check IC36, IC37 voltage regulators. I have seen the negative gone bad a few times. Input selector gets hot when bad
          • PowellSkier
            Harman/Kardon AVR 645 returning to stand-by after a few seconds.
            by PowellSkier
            A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
            06-17-2024, 11:43 AM
          • madsox
            Harman Kardon AVR 171S - standby led lights up, does not turn on
            by madsox
            Greetings!
            Thank you in advance for your understanding, I am writing to you through a translator.
            A Harman Kardon AVR171S amplifier was given.
            The history of the machine is as follows:
            It was faulty when I bought it, I want to fix it.
            I replaced the HDMI switch and one of the DAC ICs in it.
            After that it worked without a problem.
            I watched a movie using the amplifier, and at the end the amplifier got really hot.
            The cooling was faulty, I will fix this later.
            I switched it to standby mode, waited for...
            09-24-2022, 10:46 AM
          • funky2x
            Harman kardon onyx studio 7 Smd code
            by funky2x
            Cant find what smd code Y0DVA.
            sitting in Harman kardon onyx studio 7. Appreciate any help.
            05-29-2025, 03:44 PM
          • PowellSkier
            Cement resistor swap in Harman Kardon AVR
            by PowellSkier
            Would I be able to swap a 0.27 Ohm Kx2 5W resistor for a 0.22 Ohm Jx2 5W resistor in a Harman/Kardon AVR? Cement type.
            06-04-2024, 06:41 PM
          • dvd4me
            Harman Kardon AVR 3700 blown standby power
            by dvd4me
            This is a new iteration of the same issue with the standby power being defective. Based on the past users experience and the AVR 370 schematic I was able to finally found all the bad parts and slowly going to put this back together. As a short pro-log, the initial state of the fuse (8A) led me to take a cautious approach to this.
            Is never good to to replace the exact fuse and power back on, this is the worst approach.
            Instead, put a small 1A fuse and use Variac to slowly increase the voltage. I did this and the 1A fuse blow quietly at very low voltage, with...
            03-30-2021, 11:54 AM
