Onkyo TX-NR616, constantly clicking, no display, no light/led
  • R_J
    replied
    Re: Onkyo TX-NR616, constantly clicking, no display, no light/led
    How did you try and update it via usb if you don't have the firmware? Download it from Oink-yo
  • lcdcaps1
    replied
    Originally posted by budwich View Post
    try using a USB stick to update as opposed to a network connection.
    Hi
    All
    I have tried to update by USB and still get the same error
    5-82 on vsp and vmpu
    Please can someone send me the firmware so that I can program this myself or upload it
    alternatively can I use the UART cable
    Please can someone reply and assist me, I will be really grateful and appreciate it so much
    Many Thanks
    Kind Regards
  • lcdcaps1
    replied
    Hey all
  • lcdcaps1
    replied
    This is what i get when i check the firmware
    any help appreciated please
    I have tried to do update by using the ethernet cable
    When i try to do them individually using the menu
    it gives the following error
    error!! 5-82
    on vsp and vmpu
    not tried by usb
    I have a a uart cable and a USB CH341A chip programmer
    Many Thanks all in advance
    Please help
  • budwich
    replied
  • lcdcaps1
    replied
    Hi
    I have got My Onkyo Tx-NR616 to turn on but there is no HDMI OUT displaying on the TV
    I have gone through debug mode and the firmware check
    V and K shows no firmware details
    I have tried doing the firmware update using the key combination and using the ethernet cable but get error
    "error!! 5-82"
    Is there any way to force the firmware update please
    Or using the uart interface
    I am really stuck and need some help
  • lcdcaps1
    replied
    Originally posted by mmartell View Post
    First use your meter to check for continuity from the fuse to ground otherwise it might just blow again.
    I checked that and Will recheck again
    Will report back
    Thanks all
  • mmartell
    replied
  • lcdcaps1
    replied
    Originally posted by R_J View Post
    Look at the schematic and you will see what it is for, This is the +12VD(ANA), +12TRG and the POFF2, it is not the same 12 volts that supplies the relay.
    Thanks. Yes I saw that. Was trying to post a reply but wouldn't post. Thanks. Will put a replacement fuse
  • R_J
    replied
  • lcdcaps1
    replied
    That fuse is in the a/c input for D201 bridge rectifier that supplies +12volts to the hdmi board. It also supplies a voltage via D204 to the POFF2 line on P2800A which connects to Main Micom Q7009
    Thanks for the reply
    Can this fuse stop the unit on turning on and causing the relay to constantly click as it is
    I measured and i had 12v on pin 1 and pin 4 on jl901b
    maybe this was not enough to turn the receiver on
    I will appreciate all your help please
    Thanks again
  • R_J
    replied
  • lcdcaps1
    replied
    After some probing and testing resistors
    I came across F201, that shows no continuity.
    I am not sure how this has blown, there are no marks or anything
    Would this cause for it not to turn on
    Please someone help
  • lcdcaps1
    replied
    I have been doing more voltage measurements. The results are below
    I tested q7018
    pin 1 is gnd,
    pin 2 is 4.8v
    pin 3 is 3.3v
    also tested q7019
    pin 1 is gnd,
    pin 2 is 11.89v - 11.90v
    pin 3 is 5.6v
    Nothing is getting hot and i cant see any bulging caps
    Please will really appreciate all the help from this forum
    Many Thanks in advance
  • lcdcaps1
    replied
    The relay is working
    i have tested by jumping the wire pin 1 and pin 3
    there is a strong latch
  • lcdcaps1
    replied
    Where do i start looking
    on the power supply board or the hdmi board
    I have not worked on such amplifiers before so any help will really be much appreciated
    If there are any onkyo experts, please reply
    Thanks so much
  • ReeceyBurger123
    replied
    I’d start looking for anything shorted first just anything you can, relays don’t just click on and off like that unless there’s something wrong.
  • lcdcaps1
    replied
    I have put all the screw back for the power supply board that secures it to the chassis and I put two screws securing the hdmi board to the chassis*
    I tested ground from pin 3 from jl901b to the chassis and it was a good ground. Near to the same as when I touch my meter probes together.*
    I get voltage on the cable coming from the power supply* board that connects to the hdmi board*
    Below are measurements taken from when the cable is plugged into the hdmi board*
    Pin 1 is 12v but when relay clicks it goes down*
    Pin 2 is 0v
    Pin 3 is GND*
    Pin 4 is 12 v
    Pin 5 is 0v
    I read that if I put jumper wire from Pin 1 and Pin 3 on jl901b which is on the hdmi board the relay should latch but with the transformer cable removed*I tried this and got nothing*
    I tested the relay and got about 300 ohms*And the relay is clicking*
    I am really stuck and will appreciate some detailed help from this amazing community Please*
    Many Thanks*
  • lcdcaps1
    replied
    Originally posted by petehall347 View Post
    try and see
    Have you had similar issues in the past
  • petehall347
    replied
    try and see
